Results 1 to 13 of 13
Maintenance intervals
    Lifer Pittenger5's Avatar
    Austin
    Finally got an hour meter hooked up to the bike since we're riding more and I have 2 bikes to maintain. What hours do you guys usually do all the maintenance at? And what do I gotta do. I know I have to do oil change, check valves, clean/replace air filter, chain care, anything else Im missing?
    Zip Tie Alley #505
    Re: Maintenance intervals
    I do oil every 4hr, Filter every other oil change Air filter every 3 or 4 Rides.
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    Austin
    You change the filter every time or wash it? And we average a bit over an hour of ride time every time we go out, so you change it every 4-5 hours of ride time?
    Zip Tie Alley #505
    Change them usually I buy the Maxima pre oiled ones for $9.00. I usually do @ 2 Hours track time (Im at the track for 5 or 6 hours)
    You have to look at it before every ride and decide.
    live to ride seth399's Avatar
    Feb 2007
    CA
    You are so slow that you can just change the oil and filter at the end of the year. Lube your chain every ride though!
    LRRS #399
    MX #505
    Lifer lrrs313's Avatar
    Asheville, NC
    And make sure to DRAIN the oil before you put new oil in.
    -Brian
    15 S-Works Venge
    I know nobody ever does this (myself included), but would you consider going by the clymer, and just stretch it a little?
    I feel like most people only do enough to keep the bike running
    KB KB's Avatar
    Manchester NH
    What is maintenance?
    I fix it when it breaks.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    if it flies with me on it, I maintain it like an airplane. Follow schedule, avoid a major fucking calamity. Bike will perform better as well.
    Oh, and just wash the damn filter. New one every time is insanity.
    Austin
    How often should i be doing the top and bottom ends? I have probably 40 hours on the bike, never had to adjust clearance, and it starts up and runs fine.
    Zip Tie Alley #505
    Before you blow it up.
    Top end after it requires 2 valve adjustments in a short hour interval.
    Bottom end... never? See Seth's post above...
  1. Track Bike Maintenance Intervals
    By Manny in forum General Track Day Talk
    Last Post: 10-08-10, 01:47 PM
  2. Best motor oil / change intervals
    By CMG241 in forum Bike Maintenance
    Last Post: 08-22-07, 04:38 PM
  3. Need help with maintenance..
    By Ecooke21 in forum Bike Maintenance
    Last Post: 03-03-07, 02:37 AM
  4. Service Intervals
    By mikem317 in forum General Bike Related
    Last Post: 06-19-05, 05:38 PM
