Results 1 to 19 of 19
New MX style step stand, and a little work on the bikes
    I've been looking for a good MX stand for a while now. I had this crappy one that I bought on ebay a few years ago that worked well, but the bike was never stable and it was a bitch to lift it.
    I tried a stand that the local dealer had in stock and they said everyone that has bought one, loved them. I hated it! The only good thing was it had a shock on it so when you go to lower the bike, it doesn't slam down. It was also a pain to lift the bike and with the YZ, it wouldn't even lift both wheels off the ground.
    I returned it last weekend and ordered another one. I ordered a fully adjustable MSR-HP stand. For anyone that has ever used these style stands, this thing is the cats ass. Very stable, very heavy duty, and most importantly, it's VERY easy to lift the bike.
    The lift height is adjustable so it can be used on the quad, the motard and the MX bike. Not sure if their design was for use with a quad, but it picked my 400lb quad off the ground with ease. Best $80 I ever spent
    That extra little lever to the right allows you to keep one foot on the lowering lever, while the other releases it. It prevents the bike from slamming down.
    While I was at it, decided to do a little work to the bikes. Cleaned all the grime off the Ape chain to get set up for my normal WD-40 chain lube. I also cut the pin on the kickstand return...wish i did this the first day I had the bike home.
    Notice the bike is off the ground and the kickstand is still down. The return spring does rub the frame a bit but I can deal with it.
    And it was the YZ's turn. I needed to do a wheel swap back to the Motard stuff. Ice riding is done for me this season, plus I pulled the studs out. The trails are a mess with mud and ice so I figured i'd start prepping it for VIR in March I've also gotta give it an oil change and clean the air filter. Might do that stuff tonight between beers
    Re: New MX style step stand, and a little work on the bikes
    Where'd you find the stand? I don't see it on their site. I'm looking for a good one.
    I bought it from my local dealer. I'm not exactly sure where they got it but I can call and ask on Tuesday, they are closed tomorrow. I honestly just went by the pictures while looking at the books they had
    KB KB's Avatar
    Manchester NH
    I use a poland springs 5 gallon water jug holder that I came across at one of my accounts. I wired a 2 gang outlet into the middle of it for my tire warmers. 1 cord to the middle done deal.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    adjustable height to? Mine became a pain to use with the Motard wheels on it, and i am sure that the bike being lowered doesnt help. I think track gear is coming first
    KB KB's Avatar
    Manchester NH
    I put a piece of 1/4 inch plywood on the top. It's high enough to get both wheels of the ground to put on warmers, pull both wheels. Cheap and works good!
    LRRS/CCS EX #13
    GMD COMPUTRACK
    LRRS/CCS #627 JRide's Avatar
    Sep 2006
    Simsbury CT
    Looks like a similar one. They're on sale at Cycle Gear. I'm thinking of picking one up.
    http://www.cyclegear.com/spgm.cfm?L1...DJUSTABLE-LIFT
    John
    04 KTM 125SX
    05 CBR600RR
    07 KTM 250XC-W
    Your idea is the best way for use at the track, no question. I still have mine around somewhere and it worked well. I had to put plywood on the top of mine to keep the bike stable when I put the tire warmers on.
    The problem with the 08 YZ, it doesn't have the "love handles" like my older 450 had. Why they changed that style, I don't know.
    Quote Originally Posted by MysteriousR1 View Post
    Yes, the height is adjustable...though you have to remove 2 bolts to make that type of change.
    The one you have is a nice one, and that's the style I was looking for when I found this one. The easiest way to deal yours now with the motard wheels on is to place the stand in front of the engine case (between the front tire and the engine), hold the bike up by the handle bars with one hand and pick up on the front wheel with the other and pull the bike forward on the stand. Sounds complicated but it's easy
    Quote Originally Posted by JRide View Post
    It's close!
    The top isn't big enough IMO, which is the key to keeping the bike stable. Aluminum is soft and bends easy when you screw up and the bike slams down on the stand as you let it down
    hmm, that looks nice. i just picked up a FMF stand for around $70 but it only has three feet, i like how this MSR one has four. still havent put mine together yet but hoping it works OK for the Husky and Ape.
    (your machines are freekin' clean)
    I have one of those It sucks, Not really high enough for anything.
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    My aluminum one is bent and getting unstable. I'll try yo find this one in my dealer's catalog. Thanks.
    Old and Slow Sheppo's Avatar
    Westford, Ma
    Tucker Rocky carries that line. I found something very similar in my book it's about $90.00
    Posted by Jane in BoxChat
    The only problem with the Ape is the lower part of the frame isn't even so the bike doesn't sit level. It's stable but leans to the left (if standing behind the bike).
    The machines look clean in the pictures anyways
    KB KB's Avatar
    Manchester NH
    You still using the one I gave you? That thing is sketchy.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    KB KB's Avatar
    Manchester NH
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Ya man, It was OK for the 125, but the new SMC isn't going up on that thing!
    Member out thumped's Avatar
    Dec 2006
    VT
    How do you get them THAT clean! My bikes were not that clean when new!.
    I try to keep up with the hose, degreaser, etc. But yours are beyond that.
    Either you need a therapest,or you have some new product I need to know about.
    Nice job,
    OT
    Do you go to Roadside marine? I love those guys.
    It pays to play.
    Ride fast,
    You will get farther before it is over!
    KB KB's Avatar
    Manchester NH
    Quote Originally Posted by out thumped View Post
    Nice job,
    OT
    He doesn't have a girlfriend and saves all his loads in a jar. Then before each ride he coats the bike with load. When the grim hit's it is sits on top of the dried load. hit it with some WD-40 a hose (not your's silly) and viola'. Clean as your pipe!!!
    LRRS/CCS EX #13
    GMD COMPUTRACK
    You make me wonder sometimes Keith
    My cleaning tools are simple and work well. A garden hose, bottle of simple green and a 4" quality soft paint brush for the wash. An electric leaf blower to dry them. And WD-40 and ArmorAll to make them look new again.
    Trust me, a closer look at the Raptor and KTM will show that each have been used as intended and they have the scares to proove it. If you clean the dirt and muck out of the scares, you don't notice them
  1. For Sale - Parts & Tools | FREE: Pitbull triple tree front stand (old style) and hitch carrier
    By xxaarraa in forum For Sale
    Last Post: 03-21-18, 04:56 AM
  2. Where does CT stand on signal lights for older bikes?
    By George in forum General Bike Related
    Last Post: 07-01-15, 03:42 PM
  3. Cruiser style Bikes, whats good??
    By hondarider102 in forum General Bike Related
    Last Post: 08-30-14, 03:46 PM
  4. Rear Stand FS:Swing arm Style
    By Pigman in forum For Sale
    Last Post: 04-19-10, 02:36 PM
  5. Replies: 13
    Last Post: 09-03-09, 12:32 PM
