Will do. I think 6 Fingers is still riding at least once a weekend. Clough is the go-to for the summer, he's been riding a lot of Bear Brook this winter. I guess the snow riding is better there. Last I knew he still had studs on the bike, which in light of this most recent dumping will be a good idea.
Not sure if you saw my thread in the maintenance area, but it looks like my KX is going to be out of comission for a bit. Simple top end job turned into major top end job. I should be back in it by the time the weather gets good, but I think it's safe to say the next couple weekends are out.
Have you ridden Clough? Technical place. Fun, but technical. I definitely think it's more suited to a 250 than a 125. Personally I'm more of an open trails and pits and jumping type of guy, but I still enjoy Clough. I enjoy it more when riding it on 6's extra 250The fastest guys out there, by leaps and bounds, are the guys on woods bikes with soft suspension. My KX makes nothing until powerband, and the suspension is set up for pit riding. Less than ideal for a place like that, but whatever.
I have not ridden Bear Brook, but I hear it's pretty open, less techinical, a better chance to do some fast snow riding (assuming spikes/screws, which I don't have).
Either way I'll see you out there this spring/summer. We'll have to post up on here when we're planning a ride out there. A lot of them are somewhat last minute though.
I have a pair of 250's including a 01 cr250r and mostly ride at clough, you should be ok but the cr250r can be a handfull out there. Set the suspension very soft to start out and a flywheel weight will help. Good luck if you want any one to ride with out there let me know.
I would also suggest the flywheel weight on the trails. But I love the 2 strokes. !
I'll never change !
Just a reminder check the valves at 50 hours. If it ever gets had to start stop riding it STAT and have the valves checked. Chances are that the intakes have zero tolerance. OH ant BTW strting it is an art if it hasn't been jetted yet.
Turn on the gas, pull the choke, whack the throttle 4 times, kick let it fire and stall, repeat until she stays running.
Noice score!!!!
It's a two stroke, and by 50 you mean 15, according to Jim Pijeon.
That appears to be the bike of choice for Clough. 6 & I have been riding out there through the techincal sextions, choosing lines, slipping clutches, whatever, standing and using body english, etc. Those KTM guys just ride by, sitting down, like it's a smooth trail. Insane. If I didn't like pit riding and jumping so much I'd consider one.
I feel like I should add to this statement, having given it some thought. I think a 125 is harder to ride _well_ than a 250. They don't really make power unless you're in powerband, and you need to know how to ride it, work the clutch, etc. to keep it in powerband. A 250 allows you to ride through/over stuff without being in powerband. However, that's coming from the perspective of someone that has probably 5 years on dirt bikes under his belt.
A 250 can be hard in it's own respect. A 250 will make power when you hit the throttle. You don't need to slip the clutch, work at it or get it into powerband. Twist the throtle, it goes. It will lift the front on torque. I don't think my 125 even has any torqueSo, for a beginner, I can see a 250 biting you. Give it a little gas at the wrong moment and it's likely to do something you really don't want or expect. A 125, unless you were already way up in the revs by powerband or slipping the clutch, won't do much when you give it some gas. I can see a 250 getting away from you, picking up the front wheel, riding off the trail, etc. with an inexperienced rider on it. A flywheel weight will help a _lot_ with this stuff.
Anyway, still a cool bike, I think you'll have a lot of fun, and I look forward to riding with you. After thinking on it for a few I figured I should mention this stuff.
So, got the bike fired up last night... didn't take much even though it was only like 18 degrees out. I rode it for like 5 mins up and down my parents dirt road, was super sketchy since the back tire is smoked and everything was covered in snow...but I'm dying to get the new tire on and go for a real ride!
Where are you planning to ride without studs, spikes or ice screws?
