Results 1 to 17 of 17
rebuild time
    rebuild time
    long story short, i broke a ring in the 300. obviously it destroyed the piston and the cylinder. piston seems easy enough to find but apparently its a nikasil cylinder and no one makes a replacement cylinder. KTM does but its $700.
    LA Sleeves appears to make a replacement sleeve for it for short money but i am unsure of what it takes to replace it. i assume im going to have to get it to a machine shop for this right?
    also, their kit comes with a piston. should i get a different piston or just use the one they provide?
    Re: rebuild time
    Don't sleeve it, send it to Millenium, Kustom Kraft, etc and they can weld it up, bore it back to OEM and have it replated for far less than buying a replacement.
    Re: rebuild time
    sleeve cost is about $150. i have no idea what a shop would charge to swap it out.
    i hadnt considered repair. i didnt really know that was a thing.
    one of my concerns is i am clearly missing at least 1 piece of the broken ring. i dont know if it got spit out or if its in the bottom end somewhere
    rebuild time-thumbnail_fb_img_1470530550994-jpgrebuild time-thumbnail_fb_img_1470530634712-jpg
    Re: rebuild time
    It couldn't have gone far, pull the side covers and inspect the crank seals. If those are intact any left over ring has got to be either long gone or in the crank valley.
    On the repair option, many places do cylinder exchanges if you're looking for minimal down time FYI. That damage looks perfectly repairable, my WR started out with similar damage.
    Re: rebuild time
    i couldve done this all in the bike but i decided that since ive had it for 3 years and done nothing to it and know nothing about it, i would do some much needed maintenance. i knew the radiators had been abused but taking them off really showed that they need some help. much like my cylinder, finding them for this year is proving difficult. the rear axle came out hard. and dry. new rear wheel bearings and a rear tire atre in the works as well as new chain sliders and an chain and sprockets. might as well do the swingarm bushings/bearings too. as much as i would like to have he suspension done, im not sure i can swing that though.
    Re: rebuild time
    KTM 250 300 380 EXC MXC SX R L Alumalloy Radiator Fit 1998 2003,99 2000 2001 02 | eBay
    Chinese, might have to do a little grinding/etc to make them fit perfectly, but they are cheap and work. These are what I have on the motard currently. Alternatively, Mylers radiator repair might be able to restore yours for cheaper?
    Re: rebuild time
    Kurlon's got you covered. Millenium for cylinder repair. You do sleeve a modern 2 stroke cylinder to the best of my knowledge. That process was abandoned in the 80s I think.
    In the dirtbike world these days, there's a specialist that can recondition most any part that you destroy for less than buying new replacements.
    Re: rebuild time
    millennium wants $350+ and KK wants $450+...ugh. putting a liner in it is gonna cost me about the same. waiting to hear back from one other place but i was told to expect similar pricing. i thought 2 strokes were supposed to be cheap to fix.
    Re: rebuild time
    If you dropped a ring on a 4t you know it'd cost way more.
    Re: rebuild time
    For not much more you can have one of those shops punch your cylinder out to the 320cc range, port, tune the head to match, and supply a piston/rings/etc, and still be less than a new OEM cylinder.
    Re: rebuild time
    I was about to iterate the same, but figured Oxx just likes to whine, so I didn't bother....
    CCS/LRRS #83
    Re: rebuild time
    yes i know
    not helping
    oh hey GFY
    Re: rebuild time
    Maybe if you only use the bike for 2-3 months per year you can get a 75% rebate on the cost of the rebuild.
    Re: rebuild time
    Oh hey girl hey
    CCS/LRRS #83
    Re: rebuild time
    i see what you did there
    Re: rebuild time
    I don't.
    It's gotta be some silly Harley service thing though, right?
    Haverhill, MA
    Re: rebuild time
    I don't.
    highway robbery-- NHDMV
  1. Replies: 3
    Last Post: 03-19-15, 09:59 AM
  2. Long time listener, first time caller!
    By Josephd14 in forum Welcome and Intro
    Last Post: 04-19-14, 11:14 AM
  3. almost time for a top end rebuild
    By SilverDragon in forum Pit Area
    Last Post: 05-11-07, 08:41 PM
  4. Suspension Rebuild for dirt time!
    By TheIglu in forum Dirty Bastards
    Last Post: 05-10-07, 06:51 AM
