Results 1 to 10 of 10
Recomendations for Tires to Mount Ice Screws?
    Pepperell, MA
    Does it matter the firmness of a tire for use with Ice Screws?
    My Thoughts were to go with a Hard for two reasons.
    1. Strength of rubber is tougher and should hold a better grip with screw?
    2. I want an even amount of traction running in corners and on straights, so harder should hold the profile better!
    Correct me, or teach me!
    www.tailofthedragon.com
    Haverhill, MA
    Re: Recomendations for Tires to Mount Ice Screws?
    Ice tires | marcelfournier.ca
    Rumor has it that the exchange rate with Canadian funds is favorable at this time as well.
    If you don't want to buy them made then use the same tires they use.
    I love the motoZ tractionator rear on the ice.IMO you want deep lugs patterened like a sand tire in the hardest compound you can get. THen run them with like 20-30 psi. Less flex = more grip on the ice.
    Pepperell, MA
    Exchange rate is good! US dollar= 1.327 CA
    Not bad, but still a little more than I was planning on spending.
    What tires do they use?
    I'M going with your standard gold ice screws and a hard motocross, or mud tire. The last time I did this I was very impressed with the grip and as long as you stay away from pavement and solid dirt trails, they seems to last!
    Haverhill, MA
    motoZ tractionator
    Is that the tire that Fournier uses? I think it is but wasn't 100% sure.
    Pretty sure the motoZ is the latest go to tire for the ice. Used to be some sort of Kenda that everyone used then the motoZ showed up.
    Haverhill, MA
    Quote Originally Posted by Half Squid View Post
    Ice tires shouldn't touch anything but ice. Maybe hard pack snow if needed but if you want them to last buy, or make, the wraps and put the wraps on while still on the ice and only take them off on the ice. It's the sharp edges that make all the difference.
    I have no idea as I am still pretty anti marcel. Those tires chew the ice too fast, and don't require any real skill to ride as the have virtually unlimited traction.
    The fredette ama tires are normally built on the kendas, but for recreational riding, I had Fredette build me a tire on the tractionator. Still requires some actual skills to slide as you definitely can find the limit, but it works better as the ice gets chipped up as the knobs are longer and hold less screws. (more screws is good for clean ice, bad for snow)
    Haverhill, MA
    Yeah I'm not 100% anti marcel but as someone who has a normal canadian front and an AMA rear (when I do get out) the marcel's are not high on my list. Once the guys with them get out there they make so much snow that my tires don't have all that much grip anymore. Don't get me wrong sliding around on my tires is fun and like you said I likely learn more when sliding but it would be nice to be able to try to hang with the guys with the marcels for more than a corner or two.
    Member TripleTaco's Avatar
    Aug 2009
    Southern NH
    I built tires a coupe years back with a Kenda K335 Ice rear tire. You can get a crap load of screws in it. It was a while ago now, but I think I had like 1000 screws in the rear tire alone...
    Skip the Gold screws...Kold Kutters are where its at.
    '96 DR350SE
    '00 KTM 200exc
    '07 Speed Triple - sold
    '98 YZ125 - sold
    Pepperell, MA
    Tires and kold Cutter's being picked up tomorrow.
    Found a Duramax tire relatively inexpensive with a great dual sport tread that will hold a lot of screw's
    Thanks for the input guy's!
    Hope to have some fun soon on some ice! Haven't done this in year's!!
  1. Replies: 11
    Last Post: 12-05-14, 01:16 PM
  2. Mount tires in western Mass?
    By e5bowman in forum Bike Maintenance
    Last Post: 07-08-13, 11:35 AM
  3. MOUNT MY 2 TIRES AND NH INSPECTION
    By smkn-1 in forum Bike Maintenance
    Last Post: 06-14-10, 01:29 PM
  4. Mount 2 tires, rims off the bike....
    By Crash Dummy Denno in forum General Bike Related
    Last Post: 12-23-07, 06:56 PM
