Results 1 to 17 of 17
winter tear down under way
    The good. Valves checked and haven't budged since I put the new SS valves in this summer. The JB weld repair I made to the cam cap bridge has held up perfectly. Shock out and ready to go to Kates, forks off ready for fresh oil, new front sprocket on, old chain off, head bearings and linkages feel nice and smooth. Might not even open them this year.
    The bad. Rear wheel bearings I replaced just a few months ago are shot already... I guess re-using the seals was a bad idea. Also I installed them dry. Perhaps I should cover them in waterproof grease this time. Anyone know of a bearing supplier with good prices? I used a local bearing shop, but they weren't cheap...
    Re: winter tear down under way
    getting ready to kick off my tear downs as well. think the WR steering bearings may be shot now. felt little stiff when i put the bikes away. TC BB kit is in, WR kit gets here Friday
    on the bearings... did you check out All Balls? their kits come with bearings and seals for ~$25. mixed reviews on their products but i tried them for the TC steering anyway. so far so good although not the same as OEM.
    I 'checked' my wheel bearings by shaking the wheels. No slop I can feel? RUN'EM! The next bearing change will involve new hubs so... I'm hoping to get some life out of these while I can.
    This winter the WReck will get motor fluids, along with a new shift shaft, shifter and clutch springs. I may peek at the top end but I've barely run 3 tanks through it total. Grease will be tossed about with abandon, and the carb may have a date with an ultrasonic bath. If I can get my grubby mits on a PWK Quadvent Airstriker all bets on the bath are off.
    TC BB kit??? tell me more...
    I don't actually know who manufactured the wheels I'm using. The bearings are bigger that stock, so I didn't know what kit to get. Took them to a local bearing house for a match. If I remember, the part # was 3005, but my local parts guy couldn't tell me what kit would have the right bearings.
    Lifer union's Avatar
    Blackstone, MA
    believe it or not there utes a place in bellingham that just sells bearings. just need to take what you have to them and the will match it
    James
    Yeah, I can get the bearings, I wouldn't mind having the option to get an MC specific kit with the seals at a decent price though.
    ah, shit. didnt realize the wheels were aftermarket. no markings anywhere on the rim, huh?
    yeah, bumping both bikes this winter got 'em in the basement ready and waiting...
    the TC is getting a Fast By Ferracci 270 kit: cyl overbore + replate, hi-comp piston, rings, pin, clips and oversized headgasket
    the WR is getting a custom 165 kit: piston, ring, pin, clips, machined head for prefect squish + comp, port / polished exhaust port to match the pipe, knife edged lower transfers, machined PVs
    i got in on some sweet deals for both kits, saved about $500 total. neither kit will introduce any longevity issues and i keep all my stock parts as spares.
    Schwing! Are you doing all the installs? Cause I'd be down to help out.
    Careful with porting on the 165 jug. You don't want to gut the low/mid range.
    Having teh stock spares is a good place to be, but you won't want to go back!
    hehee, yeah, i'm psyched. gotta tinker with everything
    i'm doing the installs, yup, but all the bore/plate/port/polish/machining/etc was done by pros. i'd love to learn some of it, but that stuff is an art. last step for the WR will be to have RB do the TMXX carb mod i wanted last winter. he experimented on a few and now offers the work. divider, low speed mods and his air screw.
    sounds good on the help! i'll keep you posted once i schedule the timing. spring is gonna be fun.
    Sounds good
    Shock refreshed by Kates, forks refreshed, new chain block and slider, new sprockets, new wheel bearings where needed, new linkage bearings where needed, waterproof grease everywhere the sun don't shine. I'm just waiting for a couple wheel bearings and seals.
    I have to say that the Showa twin chamber forks they put on this thing are beautiful to look at, work on, and ride. Forks have been a pretty crude part up til the last 5 years or so. These things are like a swiss watch. I actually enjoy working on them.
    OK, Bike is up out of basement and ready to go! It's always hard to go start wearing the thing out all over again after all this work.
    live to ride seth399's Avatar
    Feb 2007
    CA
    my bike is down the bare frame at the moment. I just splurged and got crankcase splitter, crank bearing puller and a general bearing puller set. Now once they show up I can finally split the cases that are sitting on a stand and see what gears broke inside
    LRRS #399
    MX #505
    Haha, I was gonna suggest those tools. No more wrenching on a bowling ball.
    Quote Originally Posted by seth399 View Post
    That's ok Seth, I really don't care about that motor anyways, I'm just going to put my 265 in. Thanks for stripping it down for me though. Just let me know when to expect it to arrive via UPS and in how many boxes, thanks!
    hmm, too bad you couldn't stuff the 265 into that 125 frame Peter Kates had up for sale.
    It crossed my mind, but I don't have any fabrication tools/skills so for now I'll stick with my old chassis. It really isn't that bad now that the suspension is fresh and correctly sprung. Some day I'll score a YZ tank and seat to cut the size down a touch but for now it works well enough.
  1. Winter tear down COMPLETE!!!!!!
    By Ray-Ray in forum General Bike Related
    Last Post: 03-10-10, 09:24 PM
  2. Work in PROGRESS!! (Winter tear down)
    Last Post: 02-18-10, 08:03 PM
  3. ex500 tear down
    By daviid in forum Pit Area
    Last Post: 06-25-06, 12:10 PM
