Page 5 of 6 FirstFirst 123456 LastLast
Results 101 to 125 of 130
WR250 tuning
  1. #101
    Re: WR250 tuning
    geez dood...super shitty...can't grab a pair of used functional forks from fleabay?
    I sold some non-leaky forks, and they only went for $50 (and were a PITA to ship)
    my bike is also out of commission at the machine shop, and the mechanic there's father and dog both just died
    so it'll be Stimilon 2012 for us!
    Oh no, I'm not getting out of Stimilon 2011 that easy, I've already pre-reg'd.
    Plan A) Find a newer chassis/basket case and transfer my motor over
    Plan B) Drop a newer front end on off eBay
    Plan C) Fug it, drop the coin on a heli-coil kit
    Plan D) It's junk already, epoxy time
    Plan C isn't very likely given that I know of at least one front end available for comparable cost, minus brakes. The downside to B is I'll need to buy new springs for front and rear to keep the suspension somewhat balanced as my WR has WAY soft springs compared to the newer YZ stuff floating around.
    What is left to do on your motor?
    live to ride seth399's Avatar
    Feb 2007
    CA
    Re: WR250 tuning
    get the demons out!!
    LRRS #399
    MX #505
  3. #103
    Re: WR250 tuning
    ahhh, ok...you've clearly done all the research, sorry to re-post known information, hahaha
    I put in new bearings but the crank was binding...so I got it trued, and had out of control racing properly seat the bearings to make sure everything was seated and spinning straight. But while he was in there, he found that the hole for the shifter shaft was bent and now oval. He said it would leak forever if I ignored it, so he recommended that I got it re-rounded at a machine shop, we burn in a new seal, and be done with it. But while we were working on that, the same part of the old crankcase that shattered, had a HUGE crack in it on my "donor engine" (which is also a set of mismatched case halves). So the donor motor is getting welded and machined for reinforcement, then the tranny bearings go back in, and after that, I can finally get it back to install the crank/transmission, and put it back together.
    and if it runs, everything else is pretty much ready to go!
  4. #104
    Re: WR250 tuning
    WOW! This shit is EPIC!
    Re: WR250 tuning
    , but what comes after EPIC ¿!?
    Re: WR250 tuning
    Quixotic?
    Haverhill, MA
    Re: WR250 tuning
    Kurlon,
    What would you say if someone you knew happen to have access to a M16X1.5 Heli-coil kit?
    Joel
    Re: WR250 tuning
    Kurlon,
    Joel
    I would say I'm loading my bike on a trailer, and requesting knowledge of my new found best friend's drinking preferences.
    Re: WR250 tuning
    WR200 parts work on this bike?
    Re: WR250 tuning
    I can only find a parts fiche for the 92 WR200, very similar front end setup but enough differences that I wouldn't be able to directly swap fork lowers as a repair.
    No idea on steering stem compatibility, or wheel compatibility, or other potentially swappable bits.
    Re: WR250 tuning
    Helicoil kit purchased on eBay on Thursday, USPS shows it was delivered today.
    I was here when USPS went by, they didn't stop and visit or drop anything off. WTF? Maybe it was in a different truck? Ok, I need a 41/64ths drill bit and tap wrench anyways, I'll hit up the store and see if it's here when I get back.
    Wrench and a 5/8ths bit acquired. (I'll just drink a shit-ton of caffeine before drilling so my shakes will make up for the missing 64th.) No helicoil. Check paypal, I had it sent to work, d-oh!
    I'll be doing my repair Mon evening I guess. I also picked up some exhaust packing so that'll get tossed in tomorrow.
    Do replacement footpegs come with pins/etc, or do they reuse the OEM hardware?
    Re: WR250 tuning
    good work...looks like you will be ready for stimilon!
    not sure about the pegs though...
    Re: WR250 tuning
    Wonder what I can do with this? Hrmmm....
    Re: WR250 tuning
    don't screw it up!
    Re: WR250 tuning
    don't screw it up!
    Gee, thanks for the vote of confidence!
    I'm working with a machinist friend. He's the one that insisted I get the right size drill bit, is insisting on a cut off wheel for trimming the insert, etc. If I manage to screw this up it will be the result of something epic and video will be posted.
    Re: WR250 tuning
    Haha! It was a pun, and a little jab at myself for screwing up my valve adjustment a couple of weeks ago...
    Re: WR250 tuning
    Heli-coil installed, front wheel installed.
    Front caliper is dragging, WAY over due for a take apart cleaning... will do the same to the master while I'm in there.
    Re: WR250 tuning
    F YA MUTHAFUCKAAAAA!
    So just brakes and ur ready to go?
    Feb 2007
    CA
    Re: WR250 tuning
    your bike is more together than mine is still wtf
    LRRS #399
    MX #505
  20. #120
    Member Fast_Eddie's Avatar
    Jul 2005
    Framingham
    Re: WR250 tuning
    I found another sweet bike for you, now that your WR is done.
    http://nwct.craigslist.org/mcy/2348922739.html
    Feb 2007
    CA
    Re: WR250 tuning
    Quote Originally Posted by Fast_Eddie View Post
    that's cleary too well put together for Kurlon
    LRRS #399
    MX #505
  22. #122
    Re: WR250 tuning
    Tempting, I was thinking of trading for the 1990 YZ490 at Reynolds Motorsports instead though...
    Any suggestions no hand guards?
    Old and Slow Sheppo's Avatar
    Westford, Ma
    Re: WR250 tuning
    I had a YZ490.. what an animal. That's all I can say
    Posted by Jane in BoxChat
  24. #124
    Jul 2005
    Framingham
    Re: WR250 tuning
    I usually run the cheap Moose or MSR aluminum hand guards. I'll usually spend the extra $10 to get the version that clears my brake line.
    I like the brand that has a plastic roost protector on them, but I feel that for $80 the unit should include mounts, they don't. It's another $30 if you want to mount them. For $110 they can kiss my ...
    Re: WR250 tuning
    buy hand guards used!
    I bought mine for $30 from craigslist, and I got the metal guard, the plastic deflectors, and the mounts
  1. For Sale - Parts & Tools | Yamaha WR250 X/R wheels
    By Mr. Kurtz in forum For Sale
    Last Post: 08-20-14, 01:24 PM
  2. 2005 WR250
    By Svenny in forum For Sale
    Last Post: 07-13-12, 10:10 AM
  3. 92 WR250 Power Valve Woes
    By Kurlon in forum Dirty Bastards
    Last Post: 07-11-12, 12:57 PM
  4. 2003 Yamaha WR250 Thoughts?
    By rebelpacket in forum Dirty Bastards
    Last Post: 09-07-06, 03:22 PM
