Results 1 to 25 of 31
What are people using for pressure gauges?
    Braap Baggey22's Avatar
    Westford, VT
    For the past few years doing track days I've been using a stick style air pressure gauge at the track. Sometimes it's a PIA to use and I'm not 100% sure how accurate it is. I want to get a good quality one for track use, but I'm not sure what to buy.
    What gauges do you guys use? Where did you buy them (links would be great)?
    Thanks!
    Re: What are people using for pressure gauges?
    Motion Pro. Honestly anything reliable. And of course compare it to two others as soon as you get it
    Windham NH
    I bought the $20 Joe's racing gauge from Amazon with the swivel head. I liked it, until it fell from my seat and now it reads ~2.5 psi high. Not very durable.
    Lifer isaac_'s Avatar
    Jul 2014
    Central CT
    Digital motion pro. By far the best one I've tried.
    Worth the money, you think? They're not that cheap..!
    Basic 60psi AccuGage with a rubber bootie. No idea how accurate it is, but it's consistent which is all I care about.
    Haverhill, MA
    I've had really good luck with the Quick Car brand of pressure gauges. Reasonably durable and to my knowledge accurate.
    Products - Tire Gauges - Quickcar Racing Products
    The 0-60 gauges work well for RR and off road applications. If you were to purchase two the 0-40 or 0-20 would be better suited to the off road and the 0-60 or the 0-40 would be good for RR. Only issue being that you don't want to over pressure the gauge so you'd have to be careful after seating the beads to not accidentally over pressure the gauge. The smaller the range of the gauge supposedly the more accurate of a reading you will get.
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    Right. A man with 1 pressure gauge knows exactly how much air pressure is in his tires. A man with 2 pressure gauges (usually) has no idea .
    Find the pressure you like, and with a consistent gauge it doesn't matter what the actual number is, as long as it's always the same.
    Jul 2014
    Central CT
    I've gone through 3 or 4 liquid filled gauges. Including 1 longacre. The Longacre failed me in less than 2 race weekends. The others which are popular at the track and have worked well for MANY other people would not for the life of me work on my tires. I could never get a good seal around the stem valve. I'd always hear the air hissing out. I bought the digital motion pro and have been loving it. So far so good. Mind you I've only been using it for 2 track days and 1 race weekend but couldn't be more happy. Yes it was m'f'ing expensive.
    i use whatever Street & Comp sells...the liquid one
    Senior Member Viper897's Avatar
    Apr 2014
    Seacoast Maine
    As with anything, whats your budget.
    You can go mild and get something cheap from amazon.
    I started with a non branded one with the KTM logo on it.
    You can get wild, look up a company called Intercomp, and fork over some cash for a super wamadyne one.
    He sells the quickcar and he also sells an unbranded knock off. Both work. The knock off works just fine until you over-pressure it.
    what's the one with the blue rubber around the dial?
    Westford, VT
    I wonder if Street & Comp will be at the TTD on Memorial Day weekend.............
    Haverhill, MA
    The Quick Car gauges
    Lifer Stromper's Avatar
    Eastern Ct
    The calculus of hate
    Or the unbranded knockoffs.
    go faster cdovego's Avatar
    Weymouth
    Typically your tire guy (Michelin, Dunlop, Bridgestone, Pirelli) can verify the accuracy of your gauge when you're at the track.
    Central Mass Powersports #123
    Lifer JettaJayGLS's Avatar
    Tahoe City
    This.
    Quote Originally Posted by Baggey22 View Post
    only one way to find out:
    Toll Free: 800 326-5487
    Local/Wireless: 518 279-4598
    Yup... I've had my Liquid filled 0-60psi Quickcar gauge since 2010. 56-061-Gauge
    Reason I got the 0-60 is because I THINK I read somewhere that your intended pressure setting should be around the 50% range of the gauge, kinda like torque wrenches... I may be wrong, though.
    one thing i'll note, since a few of us all have the same one. you'll want to bleed the pressure before using. there's a rubber cap on the top, under the blue rubber. wedge your fingernail in there and look at the needle. it will move as hair temp & humidity changes. as long as the needle stays within that tolerance section, you're good. but make sure you're bleeding it.
    note: for the liquid model only
    I crack the rubber cap open a couple of times a day as air pressure/temp/humidity conditions change.
    Lifer OneCheekRider's Avatar
    Aug 2012
    LA
    been using the Quickcar one for as long as I can remember. I had a problem with the hose, emailed them, and they sent me a new hose no questions asked.
    Lifer Tekime's Avatar
    Mar 2016
    Falmouth, ME
    Awesome, I was going to post this exact question today. Got a bunch of stick gauges and don't trust them.
    What about air release? Anyone think there's enough air loss during checks to consider?
    It will move as hair temp & humidity changes.
    Does short hair vs long hair have any effect? And if you're bald should you still be concerned?
  1. New/ aftermarket gauges for race SV650
    By maxim_X in forum Bike Maintenance
    Last Post: 05-11-15, 05:38 PM
  2. Replies: 2
    Last Post: 09-10-12, 03:00 AM
  3. Rear axle gauges
    By The Snowman in forum Bike Maintenance
    Last Post: 06-04-10, 11:04 AM
  4. Aftermarket temp gauges?
    Last Post: 03-30-10, 07:41 AM
