Results 1 to 17 of 17
Fork travel
    Feb 2008
    Rhody
    Fork travel
    So I had another amazing day at Tony's Razee day, was feeling very comfortable and really really enjoyed myself. What I did notice was that I was only using a little more than half of my available fork travel, but as I said, I felt super comfortable all day long. So, I figure my options are...
    1. Don't mess with anything because the bike felt great.
    2. Adjust the suspension so I get more travel.
    3. Brake harder.
    Thoughts?
    Hyper
    Branford CT
    Re: Fork travel
    Matt, first off, it was great to meet you the other day. If you feel comfortable on what you are riding, than why change it. If you do make changes, make sure to record what you do and what you started at.
    #277
    Fork travel
    Agree on the second part, not the first. Get a notebook and tabulate all of your changes. Make sure you include tire pressures and general weather conditions. Don't be scared to twist the clickers, just need to know where you're going and where you've been.
    Windham NH
    Re: Fork travel
    1. Set your sag appropriately or as close as you can get it to a good number. You can Google how to do this, or any of the suspension shops can help. If you can't get both your static sag (rider on bike) and free sag (weight of bike alone) into appropriate ranges by adjusting preload alone, then you may need to consider different springs. Again, google this and it will make more sense. You are basically just setting your starting point at rest in the range of suspension travel (how much travel you have available to absorb bumps vs extend into dips).
    2. Brake harder regardless!
    Re: Fork travel
    Something tells me if you ask our resident Suspension Guru, Peter Kates the conversation would go something like:
    - What's this for, Pete?
    *points to zip tie 1/2 way down/up fork leg
    - That's there to say "Brake harder, you pussy!"
    Ask me how I know
    Feb 2008
    Rhody
    Re: Fork travel
    I intentionally didn't post this on his subcategory, hoping this thread goes unseen too...
    But really, braking is still my weakest skill and probably if done properly would work those forks as they should be.
    And about setting the sag, I've done some research on settings other Hyper owners have been happy with and they're all over the map. This, combined with the very long travel of the Hyper's forks (165mm), makes finding a sweet spot trial and error I guess? A lot of recommendations put the static sag at ~45mm, I've got it set at 35 right now.
    I downloaded and printed a bunch of suspension setting templates for recording current setting/changes/etc. Next track day (next year ) I'll do some tweaking I guess.
    Mike, great to meet and hang out with you too, such an awesome part of track days that your paddock mate becomes your new buddy.
    Hyper
    Re: Fork travel
    On long travel forks, I don't think you are looking to use it all. Measure how much travel you did use. 120mm seems to ring a bell as what most roadracing bikes use. You don't need to use it all. (that's what SHE said)!
    Re: Fork travel
    Someone's lying in this story...
    Re: Fork travel
    For trackdays, I would say don't worry about braking harder.
    We have enough throttle jockeys as it is.
    If I'm not trying to outbrake someone, then I probably brake at 75% on most laps (at the end of the straight). I see lots of riders that go for max acceleration and max braking, only to blow turn 1 in a variety of ways.
    I'm not going for a specific lap time, so I'd rather try to nail turn 1 as smoothly and quickly as possible... and that is easier when not max braking.
    Anywho... I encourage everyone to get their suspension set for their weight fairly early. It's OK to learn how to ride around some suspension issues, but it's also nice to have one less thing to worry about.
    Tony
    Trackdays in CT, NY, and NH
    www.TonysTrackDays.com
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    Re: Fork travel
    Buy and read Sportbike Suspension Tuning by Andrew Trevitt. Then if the day comes you want GMD to do something you can actually convey to him what you are trying to accomplish. Andrew will give you a methodical approach and he explains things in very simple even I can understand terms.....Doing your suspension tuning here is doing it by committee.
    Re: Fork travel
    I think it needs moar cowbell
    Lifer union's Avatar
    Blackstone, MA
    Re: Fork travel
    I use about 2/3 on my supermoto where on the R6 I would use 9/10ths
    James
    Feb 2008
    Rhody
    Re: Fork travel
    Thanks for all the insight guys, very helpful. At this point I think I'm going to leave the suspension alone, for many of the reasons stated on this thread, and also I was thinking that increasing the travel would also increase the front end dive which was something that was really bothering me on the street until I until I adjusted the forks as they're currently set up.
    Hyper
    Junior Member Schramm's Avatar
    Oct 2014
    Hartford, CT
    Re: Fork travel
    Ask me how I know
    Ha, Pete sounds like a cool dude. I'll have to meet him this weekend. I had the opposite at our last round, I was complaining to my tire vendor about front end push. Then he looked at the zip-tie jammed into my axle carrier. My bad :S
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    Re: Fork travel
    Sorry to wast your evening new guy.
    http://www.nestreetriders.com/forum/...0-pk-isms.html
    Oct 2014
    Hartford, CT
    Re: Fork travel
    OH man....
    Blackstone, MA
    Re: Fork travel
    Quote Originally Posted by Schramm View Post
    OH man....
    It's all in fun. Too bad you missed the real fun years
    James
  1. Replies: 7
    Last Post: 07-08-11, 11:07 AM
  2. Changing a fork seal/fork oil??
    Last Post: 08-11-10, 07:58 AM
  3. VIR Travel arangments
    By OreoGaborio in forum General Track Day Talk
    Last Post: 01-04-05, 01:30 PM
  4. Travel advisory!
    By Jank in forum General Bike Related
    Last Post: 08-08-03, 09:27 PM
