Results 1 to 25 of 37
New to Pirelli
    Posting Freak
    Jan 2003
    New to Pirelli
    Hi all,
    Switching to Pirelli Dragon SuperCorsa Pro SC2 from Michelin street tires. I'll be using tire warmers. (175deg)
    Ducati 999R
    Loudon.
    What HOT tire pressures should I start with?
    TIA
    'Lidz
    Meriden, Ct
    Re: New to Pirelli
    I'm sure one of the Boston Moto staffers will chime in with suggestions...
    Denno? Degsy? Scotty?
    Re: New to Pirelli
    32 psi front, 28 psi rear. These are HOT pressures taken RIGHT OFF the track!!!! Off the warmers you can try 32 front and 26-27 rear.
    CCS/LRRS #83
    Foxboro, MA
    Re: New to Pirelli
    off the warmer i'd try 31 in the front to get you close to the 32 hot
    Denno - CCS|LRRS EX#49
    2006 Yamaha R6
    LRRS Rookie of the Year 2008
    Meriden, Ct
    Re: New to Pirelli
    Told ya'...
    Re: New to Pirelli
    Really, expecting the tire to be warmer from the track than off the warmers? Interesting.
    Meriden, Ct
    Re: New to Pirelli
    That surprises you?
    Oct 2004
    Southeastern Taxachusetts
    Re: New to Pirelli
    That surprises you?
    Wanna know what surprises me?
    MSF RiderCoach
    MSF Dirt Bike School Coach
    she rides like the wind
    & smells good too.
    Re: New to Pirelli
    That surprises you?
    Actually, yes, it does. I would have figured the warmers would get the tire to just over the operating temp of a HAMMERED tire, and most of us running them wouldn't be able to push them hard enough to exceed those temps, without screwing up the pressures, etc.
    Learn something new every day.
    Foxboro, MA
    Re: New to Pirelli
    Boston Moto takes good care of their riders. You'll see once you buy that tard and get some pirellis for it.
    Take a look to see the line of riders coming directly off the track after practice one & two and rolling right to the BoMo trailer to get their pressures set by us. Consistently we see tire pressures that have bumped up 2-3 psi too high in the rear and 1-2psi in the front. (Sometimes worse!)
    Why?
    There are so many variables when you take the warmers off your tires, drop the bike off the stand and take the track. (Is it 60 degrees out? ok Is it cloudy? Is it sunny? Did it rain overnight? - The list goes on and on... Its never a simple equation...) All these variables effect how much gain you get when you bring the tires up to operating temp. It is almost impossible to set your pressure off the warmer let alone setting your pressure cold and get it right consistently!
    Your Hot off the track temperature is all that matters and eliminates all these variables. Take it off the track and it will get you as close as possible to the optimal pressures. If you can eliminate tire pressure as an on track variable, you can focus on everything else.
    2006 Yamaha R6
    Lifer Pittenger5's Avatar
    Austin
    Re: New to Pirelli
    Quote Originally Posted by Crash Dummy Denno View Post
    (Sometimes worse!)
    I was 6 pounds over in the rear, and the front felt funny.
    505
    Zip Tie Alley #505
    Old and Slow Sheppo's Avatar
    Westford, Ma
    Re: New to Pirelli
    OK pressures, I understand wanting to be at the optimum temp for traction, performance etc. Do you guys also note starting pressure? Wont a starting pressure compared to ending pressure tell you if you are working one end harder than the other, sliding a tire, spinning the back? A raise in pressure is a direct link to temp. Another question to you temp the tires when you come in?
    Posted by Jane in BoxChat
    Re: New to Pirelli
    Yes, we encourage all our riders to note their pressures off the warmers as well, and then off the track. This will help them get a feel for their "Gain" the amount of pressure increase you get once you're on track and pushing the tires. On some bikes and for some riders (also depending on weather) you will actually LOSE up to a pound in the front. The rear almost always sees a gain. But again, you have to note this every day at different times of the day, as it's never the same due to weather, ambient temp, track temp, how much mojo you have that day, etc.
    CCS/LRRS #83
    Austin
    Re: New to Pirelli
    (OT) You guys placed a tire order for next race weekend yet?
    Zip Tie Alley #505
    Re: New to Pirelli
    Yep, order went out Monday.
    CCS/LRRS #83
    Westford, Ma
    Re: New to Pirelli
    exactly it's an every race, every practice routine.
    Re: New to Pirelli
    Yep, and if you keep a log, you'll know on mild days you typically see ~2 psi gain, on hot days you get a ~3 psi gain, etc... and you'll be able to dial it in.
    CCS/LRRS #83
    Re: New to Pirelli
    You guys don't want to know how I get my pressures dialed...
    Lifer brewmaster's Avatar
    Apr 2004
    Portsmouth, NH
    Re: New to Pirelli
    OK what about CIII's for track days. What pressures do you recommend for them?
    M900ie
    SS750
    69 gas gusslin' Chevy
    LRRS EX #418
    Foxboro, MA
    Re: New to Pirelli
    Quote Originally Posted by brewmaster View Post
    34f/36r
    2006 Yamaha R6
    Apr 2004
    Portsmouth, NH
    Re: New to Pirelli
    Thanks Denno. That is what I ran for the Fishtail days in the rain, just double checking. Just a side note, the CIII's are not confidence inspiring in the rain. Great in the dry though!
    M900ie
    SS750
    LRRS EX #418
    Posting Freak
    Jan 2003
    Re: New to Pirelli
    OK, thanks BoMo guys for the useful info.
    I'll try- Off Warmers- F-31, R-27
    Off Track- F-32, R-28
    AND, I do check tire TEMP, also (directly off track, in pit lane...I have a Pit Tootsie with a infra-red gun), but with the Michelins I never knew what to do with the info!!
    Any help here? Temps R,Center, Left??
    TIA.
    'Lidz
    Jan 2007
    Rochester MA
    Re: New to Pirelli
    Ahhhhhh.....I knew you'd switch to Pirellis someday Steve!
    Posting Freak
    Jan 2003
    Re: New to Pirelli
    Yeah, done with going on my Ass!!!
    Whatta ya got planned for trackdays???
    Jan 2007
    Rochester MA
    Re: New to Pirelli
    Not much Steve, just racing right now. Maybe we can all do one or two at the end of the year?? Would be fun to get out there with you guys.
  1. For Sale - Parts & Tools | Pirelli MT 21 and Dunlop 606
    By whynot in forum For Sale
    Last Post: 10-13-20, 09:12 AM
  2. For Sale - Parts & Tools | Pirelli 180/60 V2 SC1 $100
    By MFChop in forum For Sale
    Last Post: 06-15-15, 10:13 AM
  3. pirelli 180/55 120/70
    By 03Worc9R in forum For Sale
    Last Post: 06-03-11, 03:21 PM
  4. Pirelli compatable???
    Last Post: 01-14-10, 07:27 PM
  5. Pirelli !60 Take off
    By BLACK SQUIRREL in forum Pit Area
    Last Post: 07-06-07, 01:22 PM
