Page 2 of 2 FirstFirst 12
Results 26 to 32 of 32
Is it safe to run directional tires backward
    Re: Is it safe to run directional tires backward
    I bet if the tire was mounted backwards, it would cool down instead of heat up.
    Yeah, but would the plane take off from the conveyor?
    NOPE. UNPOSSIBLE.
    Now, to simulate what's actually going on, take that rubber band and stretch it around a plastic bottle. Now take that bottle and roll it around on the band. Note the lack of heat.
    More to the point, increasing the size of the contact patch does not increase the friction. The friction coefficient doesn't change based on the size of the patch. Unless the tire is sliding, there is no friction induced heat. You're back to just the heat of material deformation in which case a larger patch deforms the rubber less as the work area is larger. Upping the pressure so your patch is smaller will increase the point loading and make for a hotter localized zone which can be seen as tearing when you go too far.
    Queso I read this, then did some more reading so I could get myself a bit smatah. Although I was incorrect with my initial assessment, I did say "friction," which is the source of all heat generated in a tire.
    I'll go back to my corner now.
    I've run tires backwards on the track w/ no problems. I was told the siping (grooves) are there for water dissipation. The sipes don't work well if running the tire backwards, but if you're in the dry then no biggie.
    Shot is shot though. If 1 side is truly totally worn out, I'd get a new tire.
    You can also run brake pads backwards if the material is worn down to the backing plate. Ive done thing this in a pinch
    Quote Originally Posted by Lxpony View Post
    I tried that but I couldn't figure out how to reinstall my brake rotors inside out.
    Meriden, Ct
    Pro tip: replace your brake pads when half the material is remaining. They've already fallen off at that point and aren't stopping nearly as well as they used to.
    Plus, you won't have to admit that you don't so simple safety maintenance on a public forum.
    Hiram, ME
    Pro tip: learn to understand sarcasm.
  1. For Sale - Other | Free vintage truck tires - 7.00x15 - Decent yard tires (not roadworthy, IMO)
    Last Post: 06-03-14, 11:29 AM
  2. SAFE
    By zxme in forum Wanted
    Last Post: 08-18-11, 03:36 PM
  3. Replies: 3
    Last Post: 03-25-08, 07:20 AM
  4. Plugging MC tires Safe ?
    Last Post: 07-21-04, 04:59 PM
  5. tires tires tires free tires
    Last Post: 12-16-03, 10:10 PM
