Page 2 of 2 FirstFirst 12
Results 26 to 39 of 39
Safety Wire Thread…
    Re: Safety Wire Thread…
    And bleeder bolts?
    Quote Originally Posted by DBKromz View Post
    And brake reservior caps
    No and no.
    "...any plugs or caps from which oil, water, or gas
    could drain...
    DOT3 and DOT4 brake fluid in particular are not oil-based.
    You said... oil based...
    CCS/LRRS #83
    Wirelessly posted (BlackBerry Giggity: BlackBerry8330/4.5.0.186 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/104)
    Mine has a safety secondary latch, AND a diaper.
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    Quote Originally Posted by Expat View Post
    Well, I have tried it and to be honest, if it cannot rotate more than 1/2 turn, it cannot come off. (unless the wire snaps) Point taken about shear, especially on calipers.
    I am a mechanical engineer and deal with critical materials in hazardous enviroments, not trying to be an ass, just looking at it logically from an engineering standpoint
    can't be that critical!
    When I was in aerospace I was working in Mechanical engine systems... all of our fuel controls got aluminum hardware, with 12 holes (2 on each side of each point of the hex head). There were specs on tension, and shape of the S (spec was the wire had to be mounted so that it covered 90-180 degrees of each bolt it secured). We also spec'd for the wire to be twisted in opposite directions after each bolt.
    however, for racing, I agree... if the thing can't rotate a 1/2 turn or more, you're good.
    Lifer obsolete's Avatar
    Norf Sho
    I had to count twists per inch, length of pigtail, ensure no maring (couldn't use pliers) and ensure no gap what so ever when I worked in on and around nukes in the AF.
    -Alex
    Lifer Expat's Avatar
    Mar 2007
    Now nukes I can understand! None of us want something to fall off one of those!!
    Norf Sho
    Actually if something fell off it won't go boom. lol
    -Alex
    #331 CBR929RE's Avatar
    Bridgewater, MA
    the piece that fell off won't go boom or the whole thing won't go boom?
    and after it all goes boom no one gets to see your nifty safety wiring anymore.
    KB KB's Avatar
    Manchester NH
    Unless you have a twist off gas tank good luck getting that safety wire to reach your gas cap that you have wired to the key.
    Other than that the wire needs to be pulling the bolt tight.
    However all that I saw will get you through tech no problem at NHMS.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Norf Sho
    The whole thing. Safety wire on weapons is there to ensure proper connections so it works. It's usually on connectors.
    -Alex
    Yea, THANKS ALL for the Help.....passed tech no problems at all
    Wirelessly posted (Instinct: Mozilla/4.1 (U; BREW 3.1.5; en-US; Teleca/Q05A/INT))
    Ive never seen them check header bolts.
    my axle pinch bolts and caliper are drilled so the holes are both inside (facing each other), and run the wire tight in between.
    Also, be wary of who you have in tech. This year I have personally been told 4" numbers wouldn't pass (it's in the rulebook), and "Clips" in lieu of wire won't pass for pinch bolts, which is ridiculous. It always comes down to who you have and whether or not they want to find something to fault...
    CCS/LRRS #83
    does the rule book say that 4" numbers will or will not be allowed?
    whats the rulebook say about clips?
  1. Safety Wire...
    By Sheppo in forum Bike Maintenance
    Last Post: 06-11-11, 08:05 AM
  2. Safety Wire Your Safety Wire
    By Jim in forum Bike Maintenance
    Last Post: 12-02-09, 03:21 PM
  3. Safety wire ??
    By Half Squid in forum Pit Area
    Last Post: 04-05-07, 11:50 PM
  4. safety wire
    By barfpuke in forum General Track Day Talk
    Last Post: 03-20-06, 03:14 PM
  5. safety wire?
    By Awesome in forum Pit Area
    Last Post: 03-23-05, 05:04 PM
