Results 1 to 19 of 19
SV fork springs to try out
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    I'm looking to try out a set of 1.05 fork springs for a SV 650. Before I go and buy a set I thought I would check to see if someone had a set that I could try at a TTD event.
    I know there are a lot of SV track day riders and thought it would be worth asking.
    thrilled brady's Avatar
    Nov 2007
    Raymond, NH
    Re: SV fork springs to try out
    wow, those are stiff for an SV!
    Jan 2010
    Farmington, CT
    Quote Originally Posted by brady View Post
    I was thinking the same thing... I weigh around 190lbs and like the 0.90kg/mm fork springs on my SV650. Do you know for sure that you really need fork springs that stiff for your SV650?
    What are you running now?
    Sep 2010
    Granville, NY
    I'm bottoming out with 1.0s right now.
    Cough Cough 240# bare naked cough.
    Working on the weight but in the mean time......
    Lemme know if you sell the 1.0's I keep bottoming out on my .95's even with stiff valving (cartridge conversion)
    Sep 2010
    Granville, NY
    10-4
    Sep 2010
    Granville, NY
    Hmmm. I'm note finding 1.05s available from Racetech.
    Where else to look?
    Feb 2007
    What about sonic springs?
    Sep 2010
    Granville, NY
    Good call on Sonic.
    They have 1.10s and pretty cheap I might add.
    If nobody comes up with a set to try in the next week or so I will just buck up and buy a set.
    Jan 2010
    Farmington, CT
    Hmmm. I'm not finding 1.05s available from Racetech.
    Where else to look?
    Pick up a set of 1.10 springs and just try using a 1.1 spring in one fork and keep the 1.0 in the other. Then you will have the equivalent of a set of 1.05 springs installed. If that works, then sell your extra 1.0 to Pete & he can try the 0.95 & 1.0 spring to get 0.975 equivalents = win-win!
    KB KB's Avatar
    Manchester NH
    I am 265 with gear on right now and I am running the 1.0s and I don't bottom anywhere. Perhaps you need to work on getting more weight on the pegs instead of the seat.
    Also what are you running for a rear spring? If you have the stock rear spring and 1.0 fronts then the front is working to compensate for the weaker rear spring. Also what exaclty do you mean by bottoming and what turns? If your bottoming in 10 especially get out of the seat!!!
    Good luck.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Sep 2010
    Granville, NY
    I'm running a 550 on the rear.
    Most of my bottoming comes on the brakes through the bumps into T3.
    Braking a little later and smoother helped keep the metal to metal clank from happening but I still was pretty deep in the travel. Things also got better once I moved my line a little more to the left.
    Over all the front feels pretty OK but the hard bottoming was alarming. It was not every lap but enough to make me think that I need to try something different.
    Another thought is to adjust the emulators a little. Any thoughts on that?
    Maybe I just need to work on my technique some more into T3.
    Actually I was having my best day through T10. On the gas and on the pegs. Pretty smooth actually. Usually I have trouble here but the shock seems to have helped quite a bit.
    Thanks for the feed back.
    Jan 2010
    Farmington, CT
    So, I'm guessing you are riding a Gen2 SV650 (03 or newer model) with the 550 lb rear spring. On the Gen1 SV650, the 650 lb rear spring works good for 190 lb rider. They changed the shock linkage for Gen2, so it now uses a softer spring to get the same effect. When I bought my TZ250 and rode at Loudon for the 1st time, I was bottoming the soft forks really bad in Turn 6. Ended up changing from stock (0.72 kg/mm) fork springs to a set of 0.85 springs, which worked really well with a 240 lb race bike + 190 lb rider.
    You might want to raise up the fork oil level a bit (add more fork oil) to make a more progressive set of front forks, if you aren't bottoming in Turn 6.
    On my '99 Gen1 SV650, it helped a bunch to raise up the back shock to about 13-7/8" eye-to-eye length, over the stock shock length. Sorry, I don't have any good numbers for Gen2 SV650.
    Sep 2010
    Granville, NY
    Yes, you guessed it. Gen 2. I should have mentioned that.
    Thanks for the tips.
    Sep 2007
    Hinsdale, nh
    I was running 1.0 springs re-valved with #30 oil and a 700 spring on the rear [elka] out back and I didn't bottom any where on the track 280lbs with gear here gen 1 sv
    many a biker have been ruined by a wife and a full time job
    KB KB's Avatar
    Manchester NH
    Bottoming is also an idication of incorrect oil heigth and you probably need a heavier weight oil.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Just Registered Doc's Avatar
    Jericho, VT
    Or try gripping the tank with your legs so there is less weight on the bars.
    Try heavier oil. I think stock it comes with like 5 or 10. Put 20 in it. Also look into Intimators. They are drop in valving.
    I think I have 1.0's but don't remember. I'll ask GMD.
    I weigh 260-270 in riding gear right now. Have a Penske in back. Whatever it is seems right on. Plan to be there 5/23-24.
  1. How do I select the correct fork springs??
    By jwm2k3 in forum Pit Area
    Last Post: 05-23-15, 06:19 AM
  2. Replies: 15
    Last Post: 09-17-14, 09:43 AM
  3. WTB: EX500 shock and fork springs.
    By Expat in forum Wanted
    Last Post: 07-08-11, 06:04 PM
  4. Diverse fork springs
    By Fast_Eddie in forum Dirty Bastards
    Last Post: 04-18-11, 03:22 PM
  5. K6 GSXR fork springs?
    By Qfactor in forum General Bike Related
    Last Post: 01-18-07, 03:14 PM
