Results 1 to 25 of 25
01 gsxr 600 fouling plugs???
    professional lurker burtonboarder23's Avatar
    Nashua, NH
    having an issue with the track bike i picked up last year, Went to pull the plugs to check for issues and they are not the standard ngk plugs. They are currently ngk r0045j-10. My question is, why the different plugs. Trying to figure out if there could be an issue if i go to throw in the plugs that are recommended for the 01 gsxr 600.
    any thoughts?
    "Could you elaborate on that a bit? Just telling me not to run a specific tire, and giving me no true logical explanation is like telling me I'm going to get my dick sucked tonight, and not by whom."
    Re: 01 gsxr 600 fouling plugs???
    Probably the wrong heat range which would foul the plug.get the righy one.then see how she runs.
    New air filter too wont hurts
    We're the ones you took out cheap or pricey?
    Non OEM either means it has a high compression motor, they're a cheap basted, or don't know what they're doing and put any plug in there.
    About $17 each so, somewhat spendy.
    The plug in question is specified by NGK to be a race plug.
    Senior Member WinVT's Avatar
    Winooski VT
    Do you know the history of the bike in terms of engine mods?
    Nashua, NH
    its got all the yosh internals as far as engine components. The plugs that were in it are the model listed above and brand new air filter(stock) besides the internals its got a full yosh exhaust. From what i gathered the bike had sat for a season or so, thinking maybe gummed up injectors?
    Take the injectors off and get them cleaned and balanced. I actually had this done last week.
    Who did this for you? . How many miles were on them?
    Nashua, NH
    is there anywhere NE local that does this? I know of a few places online that do it.
    i used Fuel Injector Man in Florida. My stuff came back within a few days.
    01 gsxr 600 fouling plugs???-img_1419-jpg
    Nice Jimbob.............
    Nashua, NH
    just the fact that the company is called Fuel Injector Man makes me want to use them
    I believe is name is Dale. he's real old school. reminds me of TLRman with his carb work
    Nashua, NH
    Im going to pull them out on friday since i have the day off and see how gunked up the screens are... crossing my fingers that this is whats causing the issue and not something else
    Even though it's not highly likely considering it's FI we're talking about, I'm curious how a potential fuel blockage results in fouled plugs.
    As far as injector cleaning, I've gone with Pro Flow Technologies and had good results. Turnaround at the time was a week.
    Wirelessly posted
    Quote Originally Posted by butcher bergs
    I suppose it COULD lead to an unburied fuel issue due to lack of atomization, but I'm with bergs on this. Fouling plugs could be bad or maladjusted valves, blocked air filter or incorrect plugs or bad FI map. Was a power commander removed?
    We could dyno it at adrenaline and check the a/f ratio and remap the PC.
    Would be nice to have a pic of these plugs.
    My thoughts on this are that the plugs have completed their service life and what we are diagnosing is nothing more than a set of spark plugs that no longer burn fuel efficiently which results is carbon buildup and/ or fouled plugs.
    Nashua, NH
    ill get some snapshots one night this week when i have some time to tear into the bike again
    Nashua, NH
    Didnt get a chance to take a photo but the plugs were wet and blackish, everything wiped off fine, caused by to much fuel?
    I have a PC3 that i just got for the bike. Might try throwing the stock air filter/full yosh exhaust map on it and see if it yields
    better results.
    Any other ideas?
    I think you're on the right track.
    Based on what, Jim? "wet and blackish" could be oil for all we know.
    Gotta see these plugs. They tell the entire story.
    if the new plugs turn right away, then he'll know it's not a plug or tuning issue.
    you're right that the color makes a difference, but swapping the plugs and a fresh PC3 tune is probably the first thing to start with.
    Nashua, NH
    Once I get back from getting all my stuff finally switched to nh I'll try firing it up, hoping for the best.
    Sent from my ADR6400L using Tapatalk
    Nashua, NH
    Put the yosh exhaust with stock air filter map on the pc3 and adjusted the idle to suzuki's recommended idle and the bike is as happy as can be, let it warm up and took it for a quick ride around the neighborhood, going to run some sea foam through it once im at the track in may to clean all the good stuff out and with any luck have no issues with it.
    instead of sea foam, i would take the inejctos out and send them for a cleaning & spray pattern balance.
  1. Tire plugs
    By SRTie4k in forum General Bike Related
    Last Post: 07-27-12, 09:13 AM
  2. Spark Plugs
    By akira700 in forum Bike Maintenance
    Last Post: 10-10-08, 08:18 AM
  3. NGK plugs
    By ri-gixxer in forum Bike Maintenance
    Last Post: 04-09-07, 08:08 PM
  4. Fouling plugs... 96 EX500...
    By VinceF2 in forum Bike Maintenance
    Last Post: 05-30-03, 01:44 PM
  5. ear plugs
    Last Post: 03-01-03, 11:40 PM
