Results 1 to 13 of 13
06 GSXR 600 Help
    Lifer DaSarge's Avatar
    Oct 2002
    Cape Cod
    06 GSXR 600 Help
    Hey guys,
    I need a measurement done. I need the length and width of the top yoke from the steering stem bolt to the fork. Thanks guys if you can provide me with this info.
    Spence
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    Re: 06 GSXR 600 Help
    hmmm... what's this for?
    I can measure it later. how accurate do you need the measurement?
    Sarge, you may try and Pm Peter K. he prob knows it off the top of his head.....you can do that when you are a GURU........
    Oct 2002
    Cape Cod
    Eh as close as you can without it being a pain
    Im planin a lil somethin
    Lake Champlain, VT
    I have calipers... first read through I was picturing a diff. dimension.
    Are you just needing the dimensions of the top triple clamp? I have a spare... fly a chopper over to springfield and it's yours... otherwise I will measure tonight.
    Oct 2002
    Cape Cod
    Yeah kitt just the length from the steering stem bolt (on the right side) to the fork and the width. In inches will be fine..I just need a general idea at what I am working with.
    No airborne ops goin to MA until June 16th when I step foot on US soil again
    Lake Champlain, VT
    Quote Originally Posted by DaSarge View Post
    ok... disance between the right side of the stearing stem, to the left side of the right fork tube... right? (I would have given you center to center dimensions if you hadn't said so).
    Oct 2002
    Cape Cod
    lol yeah thats what I need man, thanks a lot!
    Oct 2002
    Cape Cod
    bump, bueller
    Lake Champlain, VT
    When I see ya, I'll drop and give ya 20... (I was super tied up at work today and left the memory card at home).
    Lake Champlain, VT
    That's in INCH.
    a few things to remember:
    There is an aluminum nut that goes ontop of the triple clamp - leave 0.25" around each side of the stem (at least 0.5" to make room for a box-end wrench if you cannot install & remove whatever you're installing with the nut in place).
    The perimeter of the triple clamp, as well as the perimeter of the stem and fork circles are 3/4" thick, these wall thicknesses are 0.25" or so... the rest is only about 0.25" tall.
    These are cast, and do better with fewer holes drilled in them.
    Lake Champlain, VT
    this is probably better than my worded description above...
    [IMG][/IMG]
    Oct 2002
    Cape Cod
    Thanks a lot Kitt...No, no drilling involved. Thanks for your help!
  1. 2007 suzuki gsxr 1000 gsxr stator system
    By frenchy21 in forum Wanted
    Last Post: 07-19-12, 01:51 PM
  2. Replies: 5
    Last Post: 03-22-12, 09:42 AM
  3. Replies: 29
    Last Post: 11-21-11, 06:00 PM
  4. Replies: 6
    Last Post: 06-02-11, 09:14 AM
  5. Part outs RF, Gsxr 750, Gsxr 1100 Watercooled
    By Madmike in forum For Sale
    Last Post: 01-04-11, 02:02 PM
