Results 1 to 14 of 14
07 cbr 1000rr??
    07 1000RR h22jeffrey's Avatar
    Aug 2009
    methuen
    07 cbr 1000rr??
    Hello fellas not sure if this is the right place for this but hey...lol
    ok im having an issue with my left turn signal when ever i hit the switch for the left blinker it tries to turn on for a half of second and then it blows my fuse...can anyone relate any info on what i should checkk..
    Thanks
    who knows
    Re: 07 cbr 1000rr??
    Are the blinkers aftermarket and if so who put them in? Could be an exposed wire issue...
    Aug 2009
    methuen
    Re: 07 cbr 1000rr??
    yeah they are aftermarket they worked fine all last season till i took it to honda to replace my fairing after that it was no good...
    who knows
    Re: 07 cbr 1000rr??
    I'd have to say that is your issue. Which faring did they replace? and do you know how to take it off to fix your issue?
    I be the guy who installed the blinkers just did a twist and tape job.
    who knows
    Re: 07 cbr 1000rr??
    Over the winter I took all the wiring off my blinkers, tail light and plate light and re-wired them all with a sodering iron and shrink wrap because they were twist and tape jobs. I hate when people do shit work!
    Aug 2009
    methuen
    Re: 07 cbr 1000rr??
    yeah they replaced the one that holds the blinker..im going to disconnect it and see if it stops blowing the fuse...if they are wired backwards would that cause it?
    Re: 07 cbr 1000rr??
    Quote Originally Posted by h22jeffrey View Post
    Are they LED? If they are LED wiring them backwards would matter. If they are bulb type, the direction does not matter.
    Lifer DuncanMoto's Avatar
    Wirelessly posted (BlackBerry9000/4.6.0.297 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/102 UP.Link/6.3.1.20.06.3.1.20.0)
    LED bulbs are pole specific.
    LRRS CCS AM#636 blacklightning's Avatar
    Goffstown, NH
    Re: 07 cbr 1000rr??
    LED's are pole specific, they are diodes, but that wouldn't blow the fuse. They just wouldn't work. A short to ground would blow the fuse. +1 faulty wiring.
    LRRS/CCS AM 636
    Just Registered drop's Avatar
    Bradford, MA
    Re: 07 cbr 1000rr??
    Quote Originally Posted by blacklightning View Post
    what he said.
    - Jamie
    2009 K 1300 S
    Re: 07 cbr 1000rr??
    did you check the blinker fluid?
    Posting Freak yesterdayze's Avatar
    Milton Vermont
    Re: 07 cbr 1000rr??
    Also, unclip where the pigtail plugs in, put an ohmeter across the NON bulb side with the blinker OFF. Don't turn it on with the meter in Ohms mode unless you want to buy a new meter. If the reading is zero or close to zero, you have a short going forward. Try the same thing (like the guys said) from the positive side (usually this is the switched side though some have positive always on and switch ground - if that is the case you can ignore this whole part) of the wire (orange, red etc. typically - one of them bright colors lol Not black) to the frame. Once again zero or close may indicate a short. Just don't turn the blinker on while you are doing all that.
    LED's CAN short (breakdown voltage) and begin to conduct - without lighting - in reverse, but usually they just blow open not closed like blacklightning said.
    Aug 2009
    methuen
    Re: 07 cbr 1000rr??
    Quote Originally Posted by DBKromz View Post
    fixed thanks to this guy^^ haha..
    thanks for all the help guys just took it apart and the rear one worked fine so i took off all the tape from the dealer lol and re-crimped it and im good to go now... sticker time is around the corner .,...
    Re: 07 cbr 1000rr??
    someone had to say it
  1. 07 CBR 1000rr parts
    By Dip Dungles in forum For Sale
    Last Post: 09-12-11, 11:29 AM
  2. 08 CBR 1000rr $7999++
    By j4eric in forum General Bike Related
    Last Post: 10-17-09, 02:41 PM
  3. keep the 600 or go to a 1000rr
    By momo in forum General Bike Related
    Last Post: 07-07-08, 07:49 AM
  4. New 1000RR is up
    Last Post: 10-03-07, 06:15 AM
  5. 06' 1000RR for 3k??????
    Last Post: 04-30-07, 12:55 PM
