Results 1 to 20 of 20
need to get this fixed!
    Just Registered Omahastylin16's Avatar
    Apr 2008
    Scituate, MA
    hey guys, the shifter on my bike is fucked up and from the advice ive gotten so far i have a feeling that this is gonna be a problem thats a little over my head. general consensus is that its a broken spring inside the case.
    so im wondering if any of you know of a trustworthy mechanic that wont overcharge you, or if any of you more accomplished and experienced bike guys would mind lending some knowledge and garage space. normally im not afraid to tackle repairs myself but ive had a few people tell me that this may involve taking out the whole motor. soooo.....HELP!
    "Chatbox...It's like Vegas, for your fingers."
    Originally Posted by CBR_Knight
    in my own thread, let me post this:
    first of all, nothing about sex or play with a female seems interesting or arousing to me....
    "BALLS" is coming home late after a night out with the guys smelling of perfume and beer, lipstick on your collar, slapping your wife on the ass and having the balls to say "you're next!"
    Re: need to get this fixed!
    Detent spring?
    What are the symptoms? You got a service manual?
    Apr 2008
    Scituate, MA
    hey pete, i dont have a service manual but whats going on is ill tap the shifter down into first gear and the shift lever will stay all the down so you need the reach your toe pretty far down to get under it to go into second gear. when you try to shift into third it feels like the lever wont go up far enough to shift. the lever itself feels very sloppy and has a lot of play in it
    Just Registered wookie's Avatar
    Sep 2006
    San Antonio, TX
    Crashed recently? Sometimes a bent rearset will prevent the shifter from returning to neutral when it is tweaked.
    2003 R6 - Track
    2000 SV650 - Street/Track
    Apr 2008
    Scituate, MA
    nope no crashes, but youre right i remember that happening to my friends f4i. this was more of an out of the blue thing. took her out of the garage for a ride in late october and as soon as i couldnt get into 3rd i knew something was seriously messed up
    Wanker 2v2Ducati's Avatar
    Medford, MA
    my 900SS was having a similar issue so i pulled the left side case cover off to check out the springs and they looked fine, ended up some road grime (it was gooyey nasty im not sure what it was) got into my shifter linkage/rear set from the back and was gumming up the pivot point real bad. Cleaned it, took lever off and cleaned it all out and greased it, problem solved. I dunno what kinda bike you have but on my 900 the worst part of accessing the springs was that to change them you needed to remove the flywheel to access the lower one, but besides that didn't look like a tough job.
    Like I said they say, nothing stops a party barge.
    97' Ducati 900SS - Sometimes runs
    Apr 2008
    Scituate, MA
    oh im sorry i forgot to mention, the bike is an 01 kawi zx9r. im not sure what is the best way to access the shift star and springs
    Apr 2006
    Beverly, MA
    TLRMan is your man.
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    I was in til you said kawi... good luck with it!
    Tucson, AZ
    It should be noted that said shifter issue caused Mike to miss a Newbury pose. Please give this the attention that a situation as serious as this deserves.
    I kid, I kid. This is for the 98/99 but I'm about 96% sure it will work. If not, let me know and I can look harder.
    Original
    Feb 2004
    Bellingham, MA
    Quote Originally Posted by Omahastylin16 View Post
    Call me tomorrow. Sounds like a simple fix, well simple for me.......
    Raymond NH
    My 01 9R did the same thing. It was just road grime and grease gumming up the shifter pivot point. Take it off, clean it up and put it back together with new grease. 5 minute job you can do with the OEM toolkit under the passenger seat.
    Apr 2008
    Scituate, MA
    Quote Originally Posted by schleppy View Post
    TLRMan is your man.
    I assumed marc was the man, but i havent seen him on here much lately
    kitt, ill be the guy putting nails in your tire warmers this summer
    Quote Originally Posted by jnm988 View Post
    yup, cold night, apparently i missed some kind of tshirt?
    pete i'll try to get in touch with you soon
    i need more specific instructions
    Raymond NH
    Just in case I was not clear, the shifter pivot point that gums up is on the foot peg post. The peg assembly needs to come off the frame to get to the peg bolt on the back side of the peg assembly.
    how about this as i can tell you are afraid of tools and your bike. go to a car wash and power wash the peg and it should clean it out then lube it up.
    All strippers SHOULD have fake tits!
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Place to start
    at least pull that sprocket cover etc
    and check for BS
    Though I would also make sure not sticky clutch before any real dissassembly
    Now don't you feel good
    Bent shifting forks or galled drum follower
    Glen Beck is John the Baptist
    Apr 2008
    Scituate, MA
    im def not afraid of the tools or the bike, im gonna try cleaning up the shifter pivot point tomorrow and get the sprocket cover off and clean that up as well. i just get overwhelmed when i hear "oh man, your gonna have to pull the motor"
    hey donkey balls, want to enlighten us on what the problem was? i know you got it fixed, and you're out riding your colored ninja
    Apr 2008
    Scituate, MA
    fucked up shift fork, ended up getting a brand new tranny and motor out of the warranty company
    Ense petit placidam sandman's Avatar
    sema
    01 zx9
    i think i still have a factory service manual for one of those in addition to some parts still laying around.
    i'm not far from you if you want to borrow or buy the manual.
    jim
    "Molon labe"
  1. Can this tank be fixed? If so how
    By Roland in forum General Bike Related
    Last Post: 07-16-14, 11:06 PM
  2. Fixed My Brakes
    By Jim in forum Pit Area
    Last Post: 08-21-10, 11:52 AM
  3. Replies: 27
    Last Post: 03-15-09, 03:01 PM
