Results 1 to 11 of 11
Shortening a chain
    Lifer Suf Daddy's Avatar
    Nov 2003
    Boston, Lincoln, other locations
    Shortening a chain
    How do I shorten a 110 link chain down to 106?
    Besides take out four links, is there a special tool to cut the chain and put back that "master link?"
    -Suf Daddy
    Suf Daddy.
    Walpole
    Shortening a chain
    Unless you use the typcal master link with the little spring clip you will need a chain tool to re rivit the chain back together after you have shortened the chain. The chain can be cut with a grinder or the same chain tool can be used to break the rivit and shortn the chain.
    2018 Harley Road Glide
    2000 Ducati 900ss
    2003 Harley Softail Deuce
    Shortening a chain
    What he said...
    Freestyle Street Rider Brian_C6's Avatar
    Jul 2003
    Windham, NH
    Shortening a chain
    yeah, get a wizzer wheel or table grinder. Grind down the chain (flat plate part of the link) and pull it off. Buy a dirtbike style master link with the C clip. Make sure you put the clip on correctly. The open end should face the rear of the bike... or opposite the chain drive direction.
    Lata,
    bri
    PS. I've had the dirtbike style (C clip) master links for years and never had a problem.
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    yeah i lost a c clip on the way home from nh
    chain held im 1 luckyfucker
    no c clips ever again less i have 2
    lost um on dirt 2 chain no hold long push home
    www.bostonmoto.com
    Forum Rules
    Angry Man Racing Collision pro's Avatar
    Jan 2003
    NC
    Shortening a chain
    http://www.streetandcomp.com/ They sell the tool and you will have it the next day. Ask for Dan Ex202. Use the pressed link as the clip ones fall off.
    Collision Pros Racing
    Nov 2003
    Top Notch everyone!
    As always.
    Thanks -Suf Daddy
    Suf Daddy.
    Winchester, MA
    Shortening a chain
    Ooohh, sprocket closeouts...
    Lifer Rye's Avatar
    Nov 2002
    Behind Enemy Lines
    Shortening a chain
    Be sure you're adjusters can accomodate taking that many links out. You're decreasing wheelbase and may be pulling that wheel forward too far. Also, I have lost clips from clip style chains.....get a rivet for piece of mind.
    '95 ZX7/9
    '02 XR650R
    '78 KZ1000
    Nov 2003
    Shortening a chain
    My axel couldn't be farther back.
    The adjuster sticker said replace chain two marks ago.
    I figure it'll pan out, not sure about the number of links I have to loose because its the first time I've done it on this bike.
    SOunds like rivets the way to go. Its an 1100xx so i figure loosing the "C" clip would probably F me big time.
    Thanks for the advice
    -Suf Daddy
    Suf Daddy.
    Shortening a chain
    You can only cut the chain in sets of 2 links so keep that in mind when cutting.
    If you use the clip type, be sure to put the clip on the rite way and you'll be ok, i've never lost a properly installed clip yet in the 15 years i been off road riding.
  1. Chain
    Last Post: 06-01-15, 02:34 PM
  2. NEED SOME HELP?? 15t front sprocket and shortening the chain?
    By scubasteveRR in forum Bike Maintenance
    Last Post: 05-22-09, 05:45 PM
  3. Replies: 0
    Last Post: 05-03-07, 12:51 PM
    Last Post: 06-29-04, 12:23 AM
    Last Post: 05-28-03, 09:17 PM
