2
Recently I had wanted to retrofit my GPS to fit onto my bike. However, I did not want it hanging in the air, or hanging from the windscreen, or being an eye sore in general.This left out most of the RAM mount options that people love.
I decided to make my own custom mount using the hole in the steering stem.
I used one:
small 1 inch piece of fuel line
1.5 inch screw
Various nuts and washers
I took the stock GPS mounting clip and drilled a small hole in the middle of it so that the screw fit through it. I then super-glued (epoxy tomorrow) the nut and a washer to the end of the fuel line. You slide the piece of fuel line into the steering stem and as you tighten the screw it expands the rubbers into the sidewalls of the stem and really anchors it down.
Seems solid- although I will probably use some secondary security method to make sure it doesnt fall out of the clip.
Should work for any bikes that have a hole in the steering stem! Mine is a 2000 ZX9
Hmmm looks familiar. You might find a rubber stopper or well nut might fit the underside of that clip better. There is a DIY I did for this a couple years ago around here somewhere.
Well done. I like it.
