Results 1 to 18 of 18
Swingarm Bobbins?
    Swingarm Bobbins?
    What type would you use with a PitBull Bobbin stand, the big plastic ones or the little aluminum ones?
    Swingarm Bobbins?
    Mark, you can use either. I have one bike with each of those and the pitbull works the same for both. Or is this a poll on opinions as to which people think are better?
    degs
    Swingarm Bobbins?
    degs
    I wanted to see what people think is more better. I've always used the little aluminum type and they kinda look like crap after a while..plus they didn't offer much protection in the one little get-off I had.
    Swingarm Bobbins?
    I have run both. No difference in terms of performance really. The small aluminum ones may be a little easier to get onto since you can see more of them but it's almost not even worth mentioning.
    I run plastic ones now for the added protection. They have taken a few hits and work wonderfully still.
    Posting Freak Puppet's Avatar
    Oct 2004
    Seattle Area
    Swingarm Bobbins?
    I've always switched to the bigger ones and they've worked well as sliders during a few moments of "miscalculation", both in the driveway (kickstand not all the way down) and moving.
    As far as getting it up onto the stand. Never had a problem with either
    Brian
    LRRS/CCS EX #881
    WMRRA EX #281
    Lifer smf's Avatar
    Nov 2006
    Swingarm Bobbins?
    I like the big plastic ones, seems like if you slide they'll do a better job of protecting stuff (and i don't really like the look of the little aluminum ones). as mentioned stands work on either.
    just my $0.02.
    Scott
    Lifer Currently's Avatar
    Ooltewah, TN
    Swingarm Bobbins?
    I use the combo ones ... little aluminum ones with big plastic sliders on top.
    Did a wonderful job on my little getoff this spring. Plastic ground off protecting the bike and swingarm.
    The SV crowd uses these ... Motosliders
    They have an almost legendary rep due to lots of crashes and their ability to absorb the forces and sacrificially grind away taking the abuse instead of the radiator and plastics which are way more expensive. I am on my second set.
    Stay away from the OEM ones ... they are brittle and break off.
    Seen lots of pictures with them broken off not protecting the radiator.
    Swingarm Bobbins?
    Quote Originally Posted by Currently View Post
    It's a good thing my radiator is near my swingarm
    Thanks for the link on those
    Foxboro, MA
    Swingarm Bobbins?
    quit putting it on the stand and ride the thing!!!
    Denno - CCS|LRRS EX#49
    2006 Yamaha R6
    LRRS Rookie of the Year 2008
    Swingarm Bobbins?
    Mark, the Woodcraft deals in "standard" color (Ti) work well with the 50th.
    Woodcraft-CFM :: Spools > 6mm
    They're larger than most metal spools, and they're not as obtrusive as the polymer type. And they don't scratch much.
    Using swingarm spools to prevent damage is a waste, IMO. They don't save shit unless you're riding (crashing) some pansyass supermoto.
    Andover
    Swingarm Bobbins?
    I switched to the bigger plastic ones because I figured if I ever went down and the bike ran over my leg or something they would feel a lot better then the sharper edged metal ones. The plastic ones do not fit as nicely in the stand so they make it a little harder to line up the stand and lift the bike.
    Lifer LuvDog's Avatar
    Ashland, MA
    Swingarm Bobbins?
    I've got the big delrin ones too... no problems whatsoever putting the bike in the stand.
    2003 ZX7R
    1995 916
    Andover
    Swingarm Bobbins?
    Now that solves all my problems, thanks just ordered a pair.
    Foxboro, MA
    Swingarm Bobbins?
    Quote Originally Posted by ChR1s View Post
    wrong - lowsided with just the little metal ones and it took the brunt of everything - the plastics worked even better when my friend lowsided as well
    2006 Yamaha R6
    Lifer nefarious's Avatar
    Jul 2004
    Portland Maine
    Swingarm Bobbins?
    Gilles chain adjuster, with lift attachment
    Adobe Certified Expert, Photoshop CS4
    Adobe Certified Professional, Flash CS4
    Swingarm Bobbins?
    Quote Originally Posted by Smooth R6 View Post
    Lowsided where? Ride faster and try that again.
    Foxboro, MA
    Swingarm Bobbins?
    haha
    whatever you say!
    2006 Yamaha R6
    Ooltewah, TN
    Swingarm Bobbins?
    I got the complete set.
    Was just trying to keep on topic about spools.
    The front ones are hollow Delrin with the internal bolt core being metal.
    This allows the entire thing to flex and grind away on a low side protecting the radiator.
    The rear ones will fit just about any bike with spools.
    He only has front ones for suzukis and some hondas.
  1. WTB 01/02 swingarm and brakes
    By 388 in forum Wanted
    Last Post: 12-03-12, 08:54 AM
  2. WTB swingarm stand
    By dodge1478 in forum Wanted
    Last Post: 06-07-10, 04:36 PM
  3. 02/03 Kawi 9R Swingarm
    By MotoFreak in forum General Bike Related
    Last Post: 03-15-08, 08:55 AM
  4. Mladen's swingarm?
    Last Post: 11-28-06, 08:51 PM
  5. 954 swingarm on the 929
    By Awesome in forum General Bike Related
    Last Post: 11-23-04, 02:51 PM
