Results 1 to 8 of 8
High temp coating?
    Dr Q : Last resort Medic Qfactor's Avatar
    Homeless, MA
    High temp coating?
    Any recommendation for black jet hot coating for exhaust in the Boston / Northshore area?
    Any specific coating I should be specifying for longevity / avoid fading?
    thanks
    Q
    Lifer jwm2k3's Avatar
    Mar 2004
    Lynn, MA
    Re: High temp coating?
    I had a MV Agusta F4 midpipe coated black. I actually just went to www.jethot.com and shipped it out to them and had it back super fast.
    Dec 2005
    Near The Dragon
    from what i've read, the pipes should be coated inside and out for longevity, otherwise the pipe gets extremely hot inside and deteriorates from the inside out.
    again, this is from what i've read..
    Get out while you can
    Find your own path
    Mar 2004
    Lynn, MA
    Quote Originally Posted by Cerberus View Post
    What you say makes sense....the pipes I sent out did have coating both inside and out....
    Harlingen, Texas
    What if the pipes are stainless steel, such as the ones on my Sprint?
    Dec 2005
    Near The Dragon
    Quote Originally Posted by caddydaddy View Post
    honestly, you'll have to do the research, but if the outside is ceramic coated and the inside is not, the coating holds all the heat in, and the metal gets much much hotter than it normally would because it can't radiate any of that heat away.
    how your particular grade of stainless would react to this, i simply don't know.
    i'm not a metallurgist.
    I don't even play one on tv
    Find your own path
    Derry NH
    Ceramic coating stainless is fine. I had the headers on my car coated, but my supplier had it done for me so I don't know who he used.
    Jan 2010
    cny
    i had my SS exhaust coated twice by the same people come to find out they never blasted the exterior and the coating never stuck properly. would flake after a couple months.
    i had my headers/Y's blasted and then used the eastwood product with 10x better results.
    i think SS can be ceramic coated just needs to be blasted first.
  1. For Sale - Parts & Tools | KBS Gas Tank Coating Kit $20
    By ThunderCycle in forum For Sale
    Last Post: 07-27-15, 12:48 PM
  2. High Temp Exhaust System Sealant
    By The Snowman in forum Bike Maintenance
    Last Post: 09-14-07, 08:26 PM
  3. 04/15/03 High Temp of 82... How far?
    By suppoz in forum Rides & Events
    Last Post: 04-22-03, 07:40 PM
