Results 1 to 25 of 27
Who had installation skillz?
    Looking to get a set of Woodcraft frame sliders for the 1000, but not wanting to do this installation myself. It's not like the 900 where the entire hole is on one piece of the fairing.
    It's more like a notch in the upper and a hole saw would most likely catch the edge and rip the fairing up.
    Here's the installation spot on an 07:
    Anyone? Mondo mentioned CEO. Chris, you up for this?
    Nat Pixon! noxin's Avatar
    Apr 2008
    Boston, MA
    Re: Who had installation skillz?
    If you reverse the hole saw and press down, it'll make a groove for you to start without ripping it to shit.
    Once it establishes the hole, put it in forward and finish it.
    I'd consider some masking tape over the area to be removed. Heard it makes things easier in general. Less risk of chipping the paint and hacking the surrounding areas.
    Painted up all the plastics for my race bike and forgot about the frame sliders. Learned about the masking tape in the process.
    Posting Freak
    Oct 2009
    Southern RI
    why not use no-cut frame sliders.
    KAWASAKI RULES WOOOOO!
    Quote Originally Posted by Stegosaurous View Post
    because he'd like them to actually work if he ever needed them to
    Old and Slow Sheppo's Avatar
    Westford, Ma
    on the hole saw and masking tape
    Posted by Jane in BoxChat
    chuck, have you seen threads about the laser trick?
    with the bolt on stands and no bodywork, put a laser pointer on jack stands and aim it on your engine bolts. then put the bodywork back on, and the laser will still be pointing at exactly where you need to cut
    Lifer union's Avatar
    Blackstone, MA
    Why not ask Denno? He is an expert at installing frame sliders. Ive seen his work first hand just ask Terry
    James
    Uxbridge, MA
    I did them on mine, used a couple self leveling lasers, a milk crate, and some books to get them to the proper height. bike was on stands and locked in place. Measured twice, cut once. They came out PERFECT! Tight Fit & Look Factory.
    Used tape where I was cutting the hole. Used a new hole saw. started in reverse, finish in foreward.
    I had to think how to tackle it as they cover that whole are on the 09's. Yours looks MUCH easier.
    note to self: make sure you tell him you bought NO-CUT sliders before he cuts your bodywork (twice)
    Attachment 17820
    Lifer slammp's Avatar
    Jul 2008
    Massachusetts
    THAT is a really good idea that I had never thought of. Installing those things is always a tremendous PITA.
    Quote Originally Posted by slammp View Post
    but still mask off the area with painter's tape to avoid cracking your bodywork.
    BTW, thanks for cutting my name out of the quote, you scumbag
    Cut from the outside in.
    Feb 2004
    Bellingham, MA
    Raises hand.......
    who knows
    Quote Originally Posted by DBKromz View Post
    Did this method with my 04RR and it worked perfect. my new bike already had them installed and needless to say he didn't use this method because the holes suck and are ovals.
    it's not that hard, just make sure you put the laser pointer far enough away so you don't hit it while putting the fairing back on.
    PK gets the answer right. None of you read the initial posting did you?
    I DON'T WANT TO DO THIS MYSELF.
    • I used masking tape on the 900RR
    • I drilled from the outside in on the 900RR
    • I don't have a laser level and really don't have any other use for one, so why spend extra $$$
    • I'd probably kick something in the process of getting the fairings back on to spot the laser mark on it anyway, since I'm a clumsy oaf.
    I simply don't like the idea of cutting the edge of the fairing. Too many things can go wrong. And I'm being lazy.
    I read your post. I just didn't offer help.
    EDIT: Oh and, nothing goes wrong if you properly mark your drill spot with the fairing mounted then take the fairing off and put a piece of wood behind it and start hacking away.
    Posting Freak
    Oct 2009
    Southern RI
    Not trying to challenge you, i just dont get it? What's the deal with nocut??
    In the case of the 06-07 CBR1000RR, there are reports of breaking the water neck and damaging engine casings in a slide.
    Nov 2007
    Sure, 10 minute job
    Zip-Tie Alley Racing
    LRRS/CCS #103
    Westford, Ma
    typically they don't work as well in a crash. They bend or brake.
    Nov 2007
    yeah, I hear they will brake off and sometimes damage your rear break
    LRRS/CCS #103
    Feb 2004
    Bellingham, MA
    I just finished removing the engine to fix an engine spacer that was smashed by a cheap set of sliders. 3 hours labor and 1 hour machining time. Yeah, please buy the cheap off set sliders, my kid likes to eat......
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    After you finish putting in a hole with jagged edges you can cover up the butcher work by using a automobile door edge molding. Use a heat gun to get it in there for a nice finish. Your friends will ask you to do theirs. And you can charge them too.
    Westford, Ma
    Quote Originally Posted by ceo and a bunch of numbers View Post
  1. Skillz, i has none.. .
    Last Post: 06-28-15, 03:10 PM
  2. Cager Gots Skillz
    By typeone in forum General Bike Related
    Last Post: 10-22-10, 01:18 PM
  3. Who haz filling up skillz?
    By Jim in forum General Bike Related
    Last Post: 11-06-09, 09:08 PM
  4. Talkin Mad Skillz here
    By CitizenFrye in forum General Bike Related
    Last Post: 07-30-08, 03:06 PM
