Results 1 to 7 of 7
Ignition advancer
    Member iwannaride's Avatar
    Feb 2005
    Methuen, Ma
    Ignition advancer
    I have a 2002 ZX-9 and i am looking for some information on an ignition advancer. I am trying to get an idea exactly what it can and will do good or bad and where can i get one.
    thanks. I have added a Yosh skip-on K & N and i am going to have it jetted and dynoed.
    thanks
    Winchester, MA
    Ignition advancer
    If you jet the bike rich you can advance the timing safely a few degrees and get a bit more snappiness in the throttle, whether it will show up as horespower on a dyno or not is a matter of debate, suffice it to say that you will not recognize huge gains with the advancer.
    But the bike is jetted lean from the factory and you've leaned it out even more with a less restrictive slipon, I wouldn't advise an advancer until you've brought the mixture onto the rich side across the rev range.
    I love my jetted carbs, I run them in a zx6r and it has VASTLY improved the feel of the midrange, no more power dips and sucking wind at rollon from 7k on the highway. I think I may need to bump the mixture back a bit on the midrange as I shimmed the needles one clip lower than recommended by factory and installed larger mains by 2.5, the bike pops and sputters a bit now on decel but it's smooth as butter on the throttle
    Feb 2005
    Methuen, Ma
    advancer
    Thanks for the advice. I am looking into getting a jet kit and i am trying to get some prices on having it jetted. I have got one price of $320.00 for the kit and jetting it. I am not sure if that is good or not. i am capable of jetting it myself but i want it close to perfect as i can. As it stands now i feel a little more mid range but i am lagging off the gun. i think it from the K&N. If i roll on it in first gear around 5-6000 rpm it lifts right up. but if i snap the throttle at 5-7000 rpm it barely comes up due to a lag or flat spot. I don't really wheelie but i am trying to get better throttle response. I took out the clear air system and the popping in the exhaust has stopped. so next is the throttle response.
    thanks for all the input.
    anthony
    Member gsxrjack's Avatar
    Apr 2005
    Peabody, Ma.
    Re: advancer
    anthony
    I live right in peabody and will help you jet it for nothing, just let me know...i have a nice straight to check it out after we do any adjustments also
    Jack
    Feb 2005
    Methuen, Ma
    Ignition advancer
    Thanks, which jet kit do you recommend. i have heard good about the dynojet.
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Ignition advancer
    I have used 2 ignition advancers.
    On my 84 fj1100 it made a huge difference
    2nd time like it didn't happen
    Along with the jetting hack away at the air box inlets. Make it look like a squirrel habitat
    Glen Beck is John the Baptist
    Apr 2005
    Peabody, Ma.
    Re: Re: advancer
    Jack
    ive had the best luck with factory jet kits, much better than dynojet imo[
  1. Wanted - Parts & Tools | 2008 Kawasaki ZZR600 +4 Ignition Advancer
    By Navjag in forum Wanted
    Last Post: 03-31-14, 08:19 PM
  2. For Sale - Parts & Tools | Factory Pro +4 Ignition Advancer for Kawasaki ZX600 85-02
    By Navjag in forum For Sale
    Last Post: 03-27-14, 12:54 PM
  3. any one have a ignition box
    By lrrs428 in forum General Bike Related
    Last Post: 06-10-09, 04:28 PM
  4. Factory Pro Ignition Advancer
    By contrldsub in forum Business & Product Reviews
    Last Post: 09-29-08, 02:44 PM
  5. Ignition?
    By Murphy_101 in forum General Bike Related
    Last Post: 05-22-07, 07:18 PM
