Results 1 to 25 of 27
Broken down in Medford. Help!
    Jan 2010
    Watertown, MA
    So, on the side of the road. Bike sounds like it may be flooded. Was riding fine, engine started bogging down, stalled out. Was turning over with choke but stalling when I put it back down. Now won't start.
    Have to go to work in 2 hours. Thoughts?
    A
    Posting Freak 6 Fingered Man's Avatar
    Feb 2009
    Exeter NH
    Re: Broken down in Medford. Help!
    Stupid question... Is the gas on?
    LRRS #951
    My girlfriend wants to be like me when she grows up.
    Sometimes violence IS the answer. The answer every other time is busa.
    Uxbridge, MA
    You do have gas right?
    Vapor lock?
    clogged fuel filter maybe?
    May just be flooded,,,,
    Jan 2010
    Watertown, MA
    I know you had to ask it Yes, gas was on
    Jan 2010
    Watertown, MA
    If flooded, how long should I give it? Glad it's a nice day!
    Feb 2009
    Exeter NH
    If it where flooded the choke being on would not have it fire up as that just adds more fuel. What kind of bike is it?
    LRRS #951
    Just Registered Doc's Avatar
    Jericho, VT
    Sounds like you are out of gas or lost a battery connection.
    Jan 2010
    Watertown, MA
    Hyosung gv250. Not out of gas, not battery. The bike still cranks, just won't turn over.
    Feb 2009
    Exeter NH
    I would look at the fuel pump if it has one, make sure it is pumping gas. Then check for a clogged fuel filter. The symptoms you are describing are almost definitely a lack of fuel to the carb/s.
    LRRS #951
    open gas cap might be vapor lock
    Oct 2009
    Does your bike have a reserve fuel switch? Look around the bottom edge of the tank. Tank can sound like there is gas in it, but you can't access it until you flip the switch.
    Lifer catamount's Avatar
    Sep 2006
    Colchester, VT
    Quote Originally Posted by Aimy77 View Post
    Maybe your mixture was bunk and now your plugs are fouled (using choke on an engine that is already warmed up).
    Walked to the closest auto parts store and grab a couple of plugs. Use your toolkit to replace them.
    Jan 2010
    Watertown, MA
    Tried gas cap. Inspected fuel lines, pump, etc. nothing. Also, stupid biker passed me on the side of the road, bike in pieces. Nice.
    Feb 2009
    Exeter NH
    Quote Originally Posted by catamount View Post
    The bike would not run before he used the choke, and that would not cause the bike to fire while choked then die. That is most definitely a lack of fuel.
    LRRS #951
    Feb 2009
    Exeter NH
    If you pull the fuel line off after the pump and crank the bike does gas come out of the line?
    LRRS #951
    Uxbridge, MA
    No spark to the plugs....... Fouled plugs?
    Sep 2006
    Colchester, VT
    Quote Originally Posted by 6 Fingered Man View Post
    Well, if the plugs were on the way out and THEN he choked a hot bike then they are certainly drenched now, fuel shortage or not.
    In my experience, I've found that a fresh set of plugs has solved many potential "fuel" issues and certainly worth the $5 investment.
    Sep 2006
    Colchester, VT
    Quote Originally Posted by FireboltEric_MA View Post
    6 Fingered Man has already assured us that this is not the problem!
    Uxbridge, MA
    dirt in the carb/ needles? I'm just guessing as I am not even there.
    Dr Q : Last resort Medic Qfactor's Avatar
    Homeless, MA
    I'm heading in the city heading down 93S in a few minutes.
    Call 617 304 2157 if you are still having problems, I can stop.
    Q
    Jan 2010
    Watertown, MA
    Got it working. Will post how when I get home
    glad i could help
    Jan 2010
    Watertown, MA
    Talking Re: Broken down in Medford. Help!
    QFactor, thanks a bunch for the offer. You rock, and my mom will be in your top 8 any time
    So, I managed to hail a biker. After about 5 minutes of asking me some of the same questions I got here, he got it started. He turned the fuel valve over to the reserve tank and it started right up. Because the fuel filter isn't clogged and there is plenty of gas in the tank, he thought maybe something was blocking the petcock at the actual valve. He turned the thing all the way around and back to reserve, ran fine. Turned it back to the regular tank, ran fine... Totally odd. Thank you all for all of the help and offers, I really appreciate it! Gives me warm fuzzies to know that I can get help should I need it!
    Now, off to job #2.....
    Feb 2009
    Exeter NH
    Glad those new plugs did the trick and it wasn't a fuel issue...
    LRRS #951
    NorthShore
    I was gonna offer ya ride to work too..
  1. Hi for Medford
    By scaf in forum Welcome and Intro
    Last Post: 07-16-16, 10:22 AM
  2. Hello From Medford
    By Ralpheal316 in forum Welcome and Intro
    Last Post: 05-23-14, 12:36 PM
  3. Fabrication in/around Medford
    By Variablevalve in forum General Bike Related
    Last Post: 07-26-11, 02:38 PM
  4. New From Medford
    By CrazyItalian in forum Welcome and Intro
    Last Post: 04-20-10, 05:11 PM
  5. new guy in medford
    By 2v2Ducati in forum Welcome and Intro
    Last Post: 08-25-08, 12:37 PM
