Results 1 to 17 of 17
Proper fuel pressure?
    Feb 2012
    So I have an 80s 125cc carb'ed Honda motor and I need to rig up a fuel pump for it. The vehicle it came out of use was gravity fed.
    Would something like this be too much?
    Specified at 2-3.5PSI.
    I was also thinking of picking up an old motorcycle fuel pump but I have no idea what pressure those run.
    Something like this
    Comments and suggestions appreciated!
    Thanks
    Too many bikes to list
    Mosdt likely drunkd
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    Re: Proper fuel pressure?
    I don't know anything about the Mr. Gasket pump.
    I do know that a lot of carbureted CBR's convert from a pump similar to the 2nd image to a gravity feed as a mechanism to check the pump.
    I have no actual info on them but anecdotal evidence indicates something like 2PSI for the CBR pumps.
    I guess it depends... At what distance was the previous gravity feed? How much is the elevation of the fuel source changing? Fortunately fuel is less dense than water and carbs are pretty forgiving to pressure variations.
    Feb 2012
    This is what the motor came out of:
    85/86 TRX125
    Mosdt likely drunkd
    Mar 2012
    Chichester, NH
    OK. So "almost 0" gravity head before. Also "almost 0" friction losses.
    What's the new configuration?
    Feb 2012
    Tank is mounted next to the motor on a flat surface.
    Mosdt likely drunkd
    Mar 2012
    Chichester, NH
    You're probably fine with the Mr. Gasket thingy.
    My only concern here would be applying too much fuel pressure to the carbs, causing you to get too much fuel. At the pressure we're talking about I really think I'm being overly cautious.
    Side note : I've also never worked on 4 Wheeler carbs, so they could contain some magic that I'm not familiar with.
    Feb 2012
    Nope, no magic on this one. Rocks a standard Keihin round slide carburetor.
    Mosdt likely drunkd
    Apr 2011
    NH
    I would think that will work, a car carb runs 6-8 psi.
    Tim
    LRRS #44
    Superbike Services 44
    Why not use a Snowmobile style vacuum pump? No electrical required, will not overwhelm your carb's float.
    Feb 2012
    I don't have anywhere to grab vacuum from.
    Mosdt likely drunkd
    Sure you do, drill the intake and thread in a brass nipple. You can also get foam filters with vacuum nipples on them.
    Feb 2012
    A friend is giving me one of these for free. I may just use it. 3.5PSI
    Mosdt likely drunkd
    You can pick up a fuel pressure gauge pretty cheap if you want to test things - like $10 or so. I think I have a spare if you want to borrow it...
    Feb 2012
    So I got it running, it has no air filter. But it seems like that pump is just too much for it. It floods out unless you hold it wide open
    Mosdt likely drunkd
    Lifer Stromper's Avatar
    Eastern Ct
    You need a fuel pressure regulator to knock it down to 3 to 5 psi
    The carb will not be able to accurately regulate higher pressures
    The calculus of hate
    Feb 2012
    The pump I used only pushes 3.5PSI.
    Mosdt likely drunkd
    Senior Member mell0's Avatar
    Manayunk, PA
    This might be overly complicated, but could you T off the fuel line and route an additional line to turn it into a return style system? That might help with the excess pressure.
    -Andy
    2013 Triumph Bonneville
  1. Metric high pressure fuel hose and clamp
    By xxaarraa in forum Bike Maintenance
    Last Post: 07-23-15, 06:46 AM
  2. Replies: 2
    Last Post: 09-10-12, 03:00 AM
  3. proper battery charging
    By breakdirt916 in forum Bike Maintenance
    Last Post: 07-17-12, 12:06 PM
  4. Proper Foot Protection
    By Billy in forum General Bike Related
    Last Post: 07-27-06, 07:29 AM
  5. Proper dismounts Video
    Last Post: 12-04-04, 10:41 PM
