Results 1 to 7 of 7
2019 Husqvarna FE350 gasket leaks
    I bought a 2019 husq FE350 new , only have 800
    Miles and noticed Top head gasket leak .
    Took back to dealer , luckily had an extended warranty and they are going to replace gasket .
    But this bike has never seen dirt only ridden 1 hr a week around the neighbor hood . Unbelievable I’m so upset is this normal ?
    Re: 2019 Husqvarna FE350 gasket leaks
    You mean the rubber gasket for the valve cover? Yes, these are prone to weep. Mine started a while back. I'll replace it eventually. Not a problem.
    Nov 2009
    Bristol County
    Was it where the black cover meets the silver, with two half circles? I wouldn't call it normal, but not unheard of either. Certainly no big deal for the shop to fix.
    nedirtriders.com
    Feb 2011
    Somerville MA
    My 701 also weeps a bit from the valve cover gasket. I had a "is it serious" conversation with a tech about it. He suggested I clean the area to get a sense of the weep rate, but was otherwise unconcerned. Very different motor design philosophy vs. the CRF250L, I guess. ¯\_(ツ)_/¯
    -Jared
    Central MA
    At 8 years old, my '12 350 EXC-f is just now starting to show dampness under those 2 half circles. It is still nowhere near what I would consider as "requiring attention" though.
    just buy a 2020
    My experience, anything European with a motor, I buy knowing it’s going to be quirky in a few ways. They are not gas and go weekend after weekend, year after year like the Japanese brands.
    That being said, my last KTM 4-stroke used the weep a little oil around the valve covers and I simply tightened the valve cover bolts about 1/8th turn each and the leak stopped.
  1. 2019 Husqvarna FE350
    Last Post: 11-15-20, 02:07 PM
  2. Fork seal leaks and seized bottom links ?
    By danny86 in forum Dirty Bastards
    Last Post: 05-07-11, 02:54 PM
  3. valve cover gasket
    By Truth in forum Bike Maintenance
    Last Post: 11-26-07, 03:51 PM
  4. Finding coolant leaks?
    By Awesome in forum Bike Maintenance
    Last Post: 06-10-06, 11:15 AM
  5. Gasket help
    Last Post: 04-01-06, 04:18 PM
