Results 1 to 25 of 36
2nd Gen SV650 Subframes
    Feb 2016
    Somerville, MA
    Hoping someone can help me out. Did some digging about a sub frame for a second gen sv, and it looks the last time this was discussed was in 2008. In a post a long time ago someone mentioned Chris at Endurance Engineering. Do you know if he still manufactures sub frames? If not does anyone have any recommendations? I want something that will fit a gsxr 600 race tail fairing.
    I really like the sub frame from JHS, but its is a fortune.
    SV650 2003-2010 - JHS RACING STORE
    AMS makes a light weight carbon fiber tail also expensive
    AMS Motorsport Race Fairings
    Really looking for something like in the attached image, which may very well be custom.
    2nd Gen SV650 Subframes-capture-jpg
    Any info or personal product reviews would be great.
    Thanks.
    Lifer isaac_'s Avatar
    Jul 2014
    Central CT
    Re: 2nd Gen SV650 Subframes
    FWIW I fit a 2003-2004 gsxr Superbike tail on my stock subframe. No hacking required. YMMV. So the question is what year tail are you trying to fit? What are you looking to spend? Custom Subframes are expensive.
    Branford CT
    Check out R&R racing.
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    Looks like I should start selling these things.
    As my man said. They aren't cheap. $300ish.
    I have a few interested already. Maybe it's time to build some weld jigs and make some subs.
    5 Not allowed! Not allowed!
    Jul 2014
    Central CT
    Reminds me. I want to talk to you about design. Got some cool ideas looking at another bike.
    Feb 2016
    Somerville, MA
    I have looked at RR Racing and the lines just seem to mimic the stock sub frame, if i'm spending the money i want it to be both light weight and aesthetically pleasing, (these things bother me). That being said i am looking to fit it to a 08 sv and it seems like I'm going to spend somewhere between 250 and 300. But maybe i just fit the 05 gsxr bodywork over the stock sub frame and save myself some money.
    Senior Member WinVT's Avatar
    Winooski VT
    I'm currently in the process of fitting 04/05 gsxr race bodywork to my 2nd gen SV. First of all, it sucks. Nothing fits right. In hindsight, I would have just gone with SV bodywork again. My plan is to spend a couple more hours on it and then I may just cut my losses and start over.
    Anyway, I haven't spent much time on the tail section yet, but I think it will actually be the easiest piece to fit. I think everything on the subframe needs to be cleaned up a little bit and the plastic might have to be trimmed a little for clearance but that should be it. The guide I looked at it recommends making a couple custom brackets for support. I'm hoping to get back to it either this weekend or next and i'll check back in with an update. If I can't get the tail to fit at all, I may go the path of a custom subframe.....or sv bodywork.
    LRRS #313
    Jul 2014
    Central CT
    Quote Originally Posted by WinVT View Post
    My race bodywork (same gen GSXR as yours) never fit properly either. Then I went with Daytona 675r (06-08) and it fit like a glove. Minor fabrication for two side brackets, minimal cutting for the exhaust. What did require effort (Rada can attest to) is the subframe. I'm sure I could have hacked up my stock subframe and made it fit but we don't roll like that.
    Winooski VT
    I've heard that about the daytona bodywork. I may go that route if I can't get the gsxr stuff to fit right and then maybe just stick with an SV tail if modding the subframe is going to be a pain in the ass.
    LRRS #313
    Feb 2016
    Somerville, MA
    Maybe a dumb question, but when you do the mods with Daytona bodywork do you keep the stock seat? If i go this route and spend all the time and money I'm really looking to have a true race tail and seat and ditch the stock seat. It seems like unless i want to spend the money for JHS parts it is a custom job?
    Jul 2014
    Central CT
    Quote Originally Posted by Mikesalt13 View Post
    I don't have a stock seat. I went with a 09-12 Daytona 675r SuperBike tail (so it only has the foam).
    You're correct, unless you go JHS, it's a custom job. I don't know if you race, but if you're at the classic in June (which you should definitely go to nonetheless), swing by garage Center 1 and check mine out. The guy that made my subframe will conveniently be next door.
    You will also need an upper stay. This is what i used. Fairing Bracket - Suzuki SV650. 99-02 & 03-08. possible fit 09-12
    '06 SV650 Track Conversion - Page 8 - Band Of Riders
    This was lou's build using Chris's Endurance Engineering subframe and an 06 r6 SB AB tail.
    Jul 2014
    Central CT
    Quote Originally Posted by Sidavong View Post
    That's tits right there.
    Feb 2016
    Somerville, MA
    Yes I will be there on Thursday with Penguin, and will come back for the weekend. I will definitely stop by and take a look.
    Feb 2016
    Somerville, MA
    So I'm under the assumption Chris does not make these anymore? Simple and nice, exactly what i am looking for.
    I'm considering a GSXR tail, myself.
    Also leaning towards this option... I'm not just fond of the idea of ponying up for a custom subframe.
    Hm. I wonder how the daytona bodywork would look with a gsxr tail....
    Meh, I don't think I'd like it.
    Jul 2014
    Central CT
    Steal Bills tail and mount it on my subframe.
    Lifer NPDCPA's Avatar
    Mar 2011
    I have 06/07 GSXR 600 bodywork on my 2007. Install was very easy with expected trimming here and there and an aftermarket front subframe but was unable to get a GSXR tail over the OEM rear subframe so I stuck with the 2nd gen SV that I bought from Armorbodies. I do have a GSXR sbk tail and draft panel that I tried but can't get to work. If you are looking for a cheap option to try let me know.
    Jul 2014
    Central CT
    Quote Originally Posted by NPDCPA View Post
    Draft panel?
    Mar 2011
    Draft panel is the finishing piece that closes the tail off under the subframe instead of leaving it open to the elements, tire sling, etc.
    Permanent N00b -Dutch-'s Avatar
    Feb 2014
    Pawtucket, RI
    Straight up ignorance here... What's the point of the custom tails over the stock setup? Aerodynamics? Weight savings? Sexehness?
    Jul 2014
    Central CT
    I just call this the undertail
    Quote Originally Posted by -Dutch- View Post
    What's custom is the subframe... which we need to fit other bike's tail. Strickly sexehness. That and the SV race bike tail is UGLY.
    Feb 2014
    Pawtucket, RI
    So, other than looks, there's no point to changing the tail on an SV race bike?
    Jul 2014
    Central CT
    Correct.
    Feb 2014
    Pawtucket, RI
    Cool beans. I no longer feel sorry for anyone complaining about how hard it was to swap out.
  1. Aluminum subframes
    By bdawkins20 in forum Pit Area
    Last Post: 11-05-09, 01:46 PM
  2. 06 SV650 for 2K??
    By Ericthejet in forum General Bike Related
    Last Post: 04-13-09, 12:34 PM
  3. 03+ SV650 Front Brake Calipers on 00 SV650
    By bergj1986 in forum Bike Maintenance
    Last Post: 06-13-08, 02:14 PM
  4. f3+f4i subframes
    Last Post: 12-10-07, 02:09 PM
  5. f3 and f4i subframes
    By catch2otwo in forum Bike Maintenance
    Last Post: 12-10-07, 07:37 AM
