View Poll Results: Canyon Dancer in a truck bed
Voters
29. You may not vote on this poll
  • Yay
    16 55.17%
  • Nay
    7 24.14%
  • Bemused
    6 20.69%
Results 1 to 17 of 17
Canyon Dancer
    Nov 2004
    Boston, MA
    Canyon Dancer
    In a truck bed, Yay or Nay
    EVERYTHING is a repost
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
    Worcester, MA
    Canyon Dancer
    I have one but the issue I run into is the straps coming off the canyon dancer are too long. When I hook a tie down to the canyon dancer, then go to hook the other end to my truck, I have to shorten the tie down all the way up and I still end up with slack. No way to tighten it. FYI I had this problem in an 02 S10 as well as my current Silverado 1500. The bike is an SV. If you want to buy the canyon dancer, I'll sell it. Never used, just a little dusty.
    LRRS EX #165 (formerly)
    Lifer LuvDog's Avatar
    Ashland, MA
    Canyon Dancer
    Quote Originally Posted by BMFR6 View Post
    Do what I do... run the tie down hook all the way through the loop on the canyon dancer and back down to your tie down point in the truck.
    So basically... both hooks from the tie down are on your tie down point in the truck.
    2003 ZX7R
    1995 916
    Littering and........
    Jul 2004
    Vermont
    Canyon Dancer
    Works well on a sportbike, not necessary with your motard.
    P.S. - I dont know what happened to that thread about the motard not fitting in a shiort bed truck with the tailgate closed, but ask everyone who was at VIR how well it works.
    Canyon Dancer
    nay with the motard
    just use ratcheting tie downs (the ones especially designed for motorcycle use) and they'll have a nylon loop you can hook one end of the tie down into
    Canyon Dancer
    I like my bikes like I like my wimen, nekid, they don't need a canyon g string thingie to dance in the back of a pickup
    but there's no reason for a bike to be in the back of a pickup unless it's broken
    Canyon Dancer
    i use them in the bus.
    Canyon Dancer
    I vote for homemade jobbies.
    Plastic coated cable with extra flexible pvc tubing over it. Loops at the ends by swaging ferrules.
    Mad max
    How much to make me 2 sets about 15 inches long?
    You could turn this into a business idea
    Lifer akira700's Avatar
    Apr 2005
    in the city
    Canyon Dancer
    Regarding the home made ones...
    Have you tested them at high levels of stress?
    Well guess you have if you have used them !
    They make ones made from nylon webbing that have
    pound ratings. Ancra makes these soft hook strap extensions
    that are rated at 1200 lbs breaking load and 400 lbs working load.
    Looking at that swagged joint makes me nervous.
    KB KB's Avatar
    Manchester NH
    Canyon Dancer
    I say no way on those canyon dancer things. They always fuck my grips up.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Pepperell, MA
    Canyon Dancer
    If you use the Caynon dancers correctly they shouldn't screw up your grips. Mine get screwed up on the RC all the time because I have to loop the eyelit of the caynon back around the bar end and grip which does in fact cause damage. I have tried Luvdogs method but I worried about the straps wearing down faster from friction between the two straps pulling against each other.
    The new bike is great! I used four soft ties and was able to grab four points from the frame and not cause any damage to anything!!!
    www.tailofthedragon.com
    Canyon Dancer
    Quote Originally Posted by Half Squid View Post
    haha, it seems like everything about that bike is perfect
    Canyon Dancer
    I have not done any type of empirical testing on them. They have worked perfectly in operation but that doesn't mean diddly in terms of how close they have come to breaking.
    Degsy, while I think it's a viable option to sell them I am weary of doing so with out any knowledge of what the yield and ultimate strength is. I will look into seeing what my school has for testing equipment.
    Canyon Dancer
    Quote Originally Posted by Mad Max View Post
    Cool! I'm waitin'!!
    Member bobr's Avatar
    Jan 2007
    Manchester NH
    Canyon Dancer
    All I've ever used is 1 set of tie-downs with built in soft hooks. I've never dropped a bike. It always cracks me up when someone brings a bike in with 5 tie downs and 20 feet of rope holding the bike in the back of a pickup. My second favorite is when the bike's tied with the kickstand down.
    can't we all just get along? the snake. ssssss!
    Canyon Dancer
    Two straps may hold a bike just fine when under normal conditions but what happens when someone cuts you off and you have to do evasive maneuvers putting all the cargo under much higher lateral acceleration.?
    Jamie (saxman) and Neal (silver dragon) had both of their bikes fall out of single trailer in a very similar situation. Jamie's bike was totalled, Neal's wasn't too far off.
    Thankfully no one was hurt, but learn from their lesson. Two straps for a motorcycle isn't safe. It takes only one strap to fail for it fall over or out. You have no redundancy with only two.
  1. For Sale - Gear | Canyon Dancer Bar-Harness
    By gcgiroux in forum For Sale
    Last Post: 03-20-16, 07:15 PM
  2. Canyon Dancer Alternative?
    By kumpy in forum General Bike Related
    Last Post: 10-21-12, 10:05 PM
  3. Canyon Dancer
    Last Post: 01-21-10, 09:35 AM
  4. FS: Canyon Dancer straps
    By akira700 in forum For Sale
    Last Post: 08-19-08, 10:38 AM
