Results 1 to 8 of 8
aluminum or stainless
    Durham
    So after digging around for a better way to get my new exhaust put together I've come to the current conclusion that the best way to get it done is to but a pile of pre-bent sections and just build the damn thing piece by piece. But of course nothing in my life is easy so now I have a new dilemma, do I use stainless steel or aluminum sections? I've got a basic outline of the pros and cons of each below. Thoughts?
    stainless pros:
    matches the parts of the exhaust that will not be replaced
    durable
    easily welded (so I can probably tack it myself)
    readily available
    cons:
    heavy
    more expensive (from what I've seen so far)
    aluminum pros:
    light weight
    less expensive (from what I've seen)
    cons:
    does not match remaining parts so they will probably be replaced as well (potentially eliminating any cost benefit)
    less durable
    difficult to weld (would have to find a way to keep it all together until its welded)
    not as readily available
    Old and Slow Sheppo's Avatar
    Westford, Ma
    Re: aluminum or stainless
    I've never seen an aluminum exhaust system. Would it hold up? can YOU tig weld? I say stainless. It's aint too heavy not like you're talking a car system. get some nice thin wall Stainless.
    Posted by Jane in BoxChat
    Durham
    Nope, I definitely can NOT TIG weld. I have no intentions of trying to weld the whole system myself but since there is going to be some trial and error to get everything to fit I figure a couple quick tack welds shouldn't be that difficult to hold things in place while I bring it to someone who can weld it properly. I suppose another option would be to use rubber couplings to hold things together but that only works for straight sections, if I have hold a bend in place that might become a problem.
    Lifer Evil_Weasel's Avatar
    Over the Highside
    the obviose answer is titanium.
    As usual, your post displays a complete lacking in any fucking idea what you're talking about.
    Hey, at least you're consistent.
    san fran
    id do stainless. Al is kinda soft. not sure how your exhaust is laid out but it wouldn't take much to put a knick in it if it were aluminum. a little rock kicked up or from your boot. stainless is much more durable.
    Tuono
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    I don't think you can have aluminum before the can lest it be a
    shiny grey puddle on the ground melt 1100 degrees
    Glen Beck is John the Baptist
    Dec 2005
    Near The Dragon
    definite no to aluminum.
    no one makes aluminum exhaust systems (that i know of) and there's a reason for that.
    i'm not an engineer but there's no good reason to using Al that out weight the lack of strength, and excessive conduction of heat, not to mention a fairly high coefficient of thermal expansion..
    Get out while you can
    Find your own path
    Durham
    cool, stainless it is.
  1. For Sale - Other | Sig P232 Stainless
    By TheIglu in forum For Sale
    Last Post: 03-16-16, 12:16 PM
  2. Wanted - Other | Ruger 10/22 Stainless
    By NPDCPA in forum Wanted
    Last Post: 12-05-14, 09:36 AM
  3. Stainless steel should not pit, right?
    By AimlessMoto in forum General Bike Related
    Last Post: 05-11-11, 02:11 PM
  4. Stainless fridge
    Last Post: 09-21-10, 05:16 AM
