Results 1 to 7 of 7
Aluminum vs Steel
    Aluminum vs Steel
    Are aluminum bars any more bend resistant that standard steel bars? I'm about to swap in a 3rd set of bars for a friend and would really like something that's a touch more resilient before practicing in a parking lot to solve their low speed issues...
    Lifer Expat's Avatar
    Mar 2007
    Re: Aluminum vs Steel
    If the thickness is the same, then steel will be more bend resistant.
    Steel will almost certainly be cheaper plus, if the bend is not too bad you should be able to pull it back with a long tube.
    I've never been comfy straightening street bike bars, especially on someone else's bike.
    Savannah, GA
    make the bars out of a stronger material.. something else might bend. The bars bending is like a crumple zone i guess you can say.. i'd rather the bar bend than something else more critical, like the clip-on.
    The best advice I’ve ever been given is to not forget where you came from.
    Waterbury, VT
    Unless you put a kink in the tube you should be OK straightening a steel bar a few times. It's better to put a bar on it and use steady pressure over beating it back into place with a hammer. Aluminum is a tough call because it tends to work harden a lot more than steel.
    It may look a little odd - but have you thought about mounting some off-road bark busters to add some strength to the bars?
    SSearchVT
    Mar 2007
    I agree but for low speed parking lot stuff, you should be OK, check the area where the bend was for flaking of chrome or cracking of paint to be sure they are OK.
    Central MA
    Yes! By far! A good set of Renthals will out last a set of mild steel bars 10 to 1.
    I have used the cheaper Rocky Moutain aluminum bars (Tusk brand?), and although they are not quite a tough as Renthals, they are still way more bend resistant than mild steel bars.
  1. Wanted - Parts & Tools | Steel Sprockets
    By csmutty in forum Wanted
    Last Post: 10-29-17, 09:03 PM
  2. steel pieces
    By theothersean in forum Wanted
    Last Post: 01-21-13, 07:33 PM
  3. Stainless steel should not pit, right?
    By AimlessMoto in forum General Bike Related
    Last Post: 05-11-11, 02:11 PM
  4. AL or Steel clutch kit?
    By PinHead in forum Bike Maintenance
    Last Post: 08-10-03, 03:19 PM
