Results 1 to 3 of 3
Aluminum welding, fuel tank fabrication.
    Do anyone know or have a local contact that can weld aluminum, or also has fabrication skills to build me a 2 gallon fuel tank for a project?
    The simple, I need a 7” wide x 7” deep x 11” long aluminum fuel tank with a vented flush fuel fill, and a top mounted internal fuel pump. I could make those simple sizes work if I had to, however I could gain fuel capacity by following the shape of the space I have available.
    I’m not on an unlimited R7 style budget here, but I’m know it’s a costly item, so if you know anyone that may be interested, please let me know.
    Re: Aluminum welding, fuel tank fabrication.
    probably can find someone closer too you, this is who I have used for that type of project, I've had good results making a cardboard mock up and replicated with aluminum plate
    https://www.bbautorv.com/
    Feb 2012
    Can they weld titanium ? Have a Yoshi Ti header from a bike that was running pig rich and blew holes where it goes into the head on every cylinder iirc, haven't looked at it in a while
    Too many bikes to list
    Mosdt likely drunkd
