Results 26 to 50 of 58
American Big V-Twin Lube Thread
    I93/495
    Re: American Big V-Twin Lube Thread
    75w-90 gear oil all around. Bigger numbers mean its better oil.
    https://www.walmart.com/c/kp/75w-90-oil
    Not even close to accurate.....
    2012 Tiger 800 XC
    75w90 gear oil and 20w50 motor oil is pretty similar in viscosity.
    That said, the different chemical properties in some gear oils may not be compatible with components in your transmission. I'd research it way more before making a change like that.
    This is why I'm curious as to what the Purple One is running that in. I'm sticking to basically what's specified/recommended.
    I use Amsoil 20W-50 Synthetic V-Twin Motorcycle Oil for everything. In my 2000 Road King..
    Yup. Pretty much same here. Although this go 'round I'm going with Klotz Transmission/Primary lube.
    And...just got notified the fluids & filter have been delivered. Tires should be here in about a week...
    Oct 2020
    Chelmsford, MA
    stuff you read on the internet is always accurate
    Oct 2020
    Chelmsford, MA
    For those of us who are wise, we keep to what the engineer said: "anything JASO MA2 certified"
    So I used Mobil 1 for 15 years. Recently made a switch to Motul (green) stuff. Seems to work just as good, but haven't really had more than 1 oil change with it!
    Only owned one briefly but used Castrol Power 1 V-Twin 4T 20W-50. It is pretty widely available.
    https://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/674DB92D31BE7CE0802583050045159E/$File/BPXE-A3QE84.pdf
    Suspect Rotella T6 meets the same specs.
    https://shell-livedocs.com/data/publ...85fe7599bd.pdf
    Moot point until my next engine oil change. My oil & lubes are in, so I'm good for now. May try Rotella next time, who knows?
    Has the right approvals, but not available in 20W-50. Only 5W-40, which IMO is far too thin for an air cooled motor like this.
    I would (and do) run a dino 20W-50 before a synthetic 5W-40.
    I noticed that too...
    I93/495
    Thinner oils run cooler. Highly speculative, but it's possible a stout synthetic 40 wt runs cooler and still offer better protection then a dino 50 wt. It would be more viscosity stable at higher temps as well. Better NOACK numbers, probably better HT/HS numbers as well. Impossible to prove without "data" but cars speccing 5W or 10W-30 for years suddenly saying a 20wt is okay are good examples. Everyone thought Ford trucks would blow up running 5W-20 but they still went the distance on them.
    There is way more to oil then viscosity and thicker is not always better.
    There very well might be oil analysis results showing stout 40 wts are perfectly safe in these motors, but I haven't looked for them.
    2012 Tiger 800 XC
    But any thinner and the oil would all be on the ground... Had to be said.
    Lancaster, CA
    Bubs, I read zero replies in this thread. For the many years I owned my Buell XB9S (Sportster motor), I ran Rotella whatever-correct-viscosity, changed it every ~3K miles, and had no troubles. I owned that Buell ~ 3 years offhand, with nary an issue.
    Bill Cool --- CRA EX 47, CVMA EX 478 --- 2025 CVMA F40UL Champion, 2023 NEMRR GTO Champion, 2020-21 LRRS LWSS Champion --- RSP Racing / TTD / MTAG-Pirelli / Woodcraft / Sportbike Track Gear / Seacoast Sport Cycle / Bison
    Well that was different. Engine, transmission & primary all done with shiny new Klotz. Still wrapping my head around having to do THREE different points for lubrication though. Odd, but whatever...
    Supposedly, when I bought it from the dealership at 5000 miles they did a full servicing with would have included those that I had just done. I'm beginning to REALLY doubt it. Very low engine & trans oil. And whichever monkey put the oil filter on and replaced the screws on the clutch (derby) cover was a fuckin' idiot. I don't know how they didn't snap the derby cover screws. I had to turn one into a flat head screw to get it out (originally Torx). I'll be ordering new ones by week's end. I'm guessing they used foot lbs instead of INCH pounds when tightening.
    My buddy fab'd a tool for getting stubborn oil filters off. Thank goodness! Again, whoever installed that is a fuckin' moron. I got the K&N replacement with the 17MM nut on the end for easy removal. I didn't really have a problem with getting oil everywhere. I just made a chute from a cardboard box & placed it under the filter as I removed it. Barely a drop. I made a similar chute for filling the primary.
    I like that everything other than the primary was measured on it's side stand and everything was drained on it's side stand. By the way - do 'they' really call them jiffy stands? WTF is up with that?
    All in all, it only took a couple hours. Would have been less if I didn't fuck around so much. Each time I pulled a drain plug, I'd grab a beer and take a couple puffs to make sure everything was drained thoroughly. I've never had a bike where I had to change more than one lube areas. Well, except the Raptor I guess. But that's just two drain points for the same oil. Still very odd to me, but it is what it is.
    I'll probably poke around on Amazon for one of those primary fillers and a form-a-funnel that can be used under the oil filter. The cardboard worked fine, but I'd rather just grab these next time and go at it.
    We'll see how the bike & I like the Klotz. I only managed a 5 mile ride home from my buddy's when all was said & done. At the very least, it smells really good!
    Yes on all counts.
    Honestly the worst part about the Harley in my mind is the use of SAE fastners. This is the 21st century for crikes sakes! And then the front end is mostly metric anyway. Dumb.
    The multiple oil fills is the runner up. It is vaguely dirt-bike like, although as you point out it is different fluids in different components. And honestly it isn't that big of a deal.
    Every time I check the oil I am reminded at how nice, chunky and overbuilt the oil cap and dip stick are. Would I rather a japanese style sight glass instead? Maybe. Does the dip stick with reading instructions STAMPED ON IT work for me? Yep.
    The "jiffy" thing is weird. I will never say that word outloud in reference to a side or kick-stand.
    Go ride the piss out of it!
    Yes on all counts.
    Yeah, I meant to mention that too. The fancy, over engineered dip sticks were well marked & all. But man, a site window would be SO much better.
    And no. I'll never refer to the side stand as "the jiffy stand".
    My drain plugs were all metric, BTW. The derby cover was Torx.
    I've only managed a few hundred miles since, but everything seems ducky. I haven't really noticed a difference other than the transmission definitely feels & sounds smoother. And every now & then when I get a whiff of the Klotz and all is well.
    New tires came in, so that's next!
    I will mention if your Harley is anything like my road king! Do the rear brake pads while you have the rear wheel off... Cause well you'll see !
    I93/495
    Does that still apply if one actually uses the front brake to stop
    2012 Tiger 800 XC
  21. #46
    Actually the rear brake on a 800lb motorcycle is quite effective in whoain the beast to a stop!
    I93/495
    I imagine it wears much faster if that's the only brake people use......
    2012 Tiger 800 XC
  23. #48
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    I'll just point out that there will be some people at the track this weekend who will change tires rather inexpensivly.
    Of course they will have to be off the bike and you'll need to pay the entry fee.
    I just sold my "spare" set of wheels for the old bike. Buying a new spare set for the new one.
    Right now a complete front is looking like about a Grand. Ouch.
    I just bought a new rear wheel with a 50% tire for about the cost of a new rear tire.
    Yeah. But you are a wheel addict!
    I just bought a new rear for the RK. I swear tire prices are up 25-30% over a year ago.
    Mar 2012
    Chichester, NH
    That's not incorrect.
  1. Best chain lube?
    By Tekime in forum Bike Maintenance
    Last Post: 09-05-18, 09:23 AM
  2. V-Twin run official ride thread
    By jbmass in forum Rides & Events
    Last Post: 08-31-12, 08:07 PM
  3. lube me up
    By getaddicted in forum General Bike Related
    Last Post: 06-21-08, 12:12 PM
  4. Chain lube?
    By zxme in forum Bike Maintenance
    Last Post: 05-08-07, 10:10 PM
  5. Chain lube
    By NHBusa in forum General Bike Related
    Last Post: 05-19-04, 10:16 AM
