Results 1 to 25 of 26
Whats different in these two pictures...
    TWINS! xrocket21's Avatar
    Central Maine
    I didnt notice till recently. I bought the bike used.
    Lifer Pittenger5's Avatar
    Austin
    Theres a dog in one. That was easy
    Either that or the blinkers dont match
    Zip Tie Alley #505
    Central Maine
    Haha, thats arrow!
    And yes, just noticed the blinkers!!!!!
    good eye
    May 2007
    Southern NH
    ...its so you can tell port from starboard on that boat.....
    Muhammad Ali.
    Central Maine
    if any of you can help remedy this issue...
    http://www.nestreetriders.com/classi...php?product=88
    Now that I know its off its bugging the shit outta me...
    So, is there something else that's different?
    .... duey's Avatar
    Wilmington MA
    those look to be LP flushmounts that you can get from pretty much any dealer or online for about 15-25bux. May be a bit harder to find instock locally since those flushmounts are a bit older, but i'll check around my job and see if i find anything lying around for you.
    2021 Ducati Panigale V2
    2020 Honda Grom
    Central Maine
    No, sorry, I was referring to the blinkers. By just noticed, I mean I bought it and drove it 800 miles before I finally noticed they werent the same!
    Central Maine
    Thumbs up Whats different in these two pictures...
    Quote Originally Posted by duey View Post
    Id appreciate it! I was hoping someone may have a spare just lying around!
    Lifer JohnnyV's Avatar
    Westborough, MA
    No bar-end weights... Vibrate much?
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    Sigs. Dont match I would sell the fucking thing its wrecked, like how could you 800 miles your so lucky you could have been killed.
    www.bostonmoto.com
    Forum Rules
    Quote Originally Posted by beet View Post
    If it were a TL, it would've fallen apart when you tried to drive it away from the guy you bought it from.
    Central Maine
    Quote Originally Posted by 02Telefonica View Post
    It was in a bit rough shape when I got it. Those pics are from the day I got it.
    I have added stock bar weights, the center cap on the tree was missing, I changed the rear blinkers from blue to amber, replaced the exhaust donut gasket, and I am working on fixing the red LED brakelight that was out. All the bulbs I get dont fit though, So I will have to MAKE some fit. I changed the oil and cleaned it up too.
    Its an 03 and I bought it with 15.5k miles for $5,500 with new tires, undertail, m4 pipes, and Power FC3, so even though it was rough, its reflected in what I paid. Next step is to replace the chain/sprockets (debating 520/530) and front pads, and flush the radiator, and It will be in pretty good shape.
    Its deffinitely been down on both sides though, plastic is a bit rough here and there, and foot brake lever is a bit bent.
    May 2002
    Meriden CT
    If it were a AcuraTL, it would've fallen apart when you tried to drive it away from the guy you bought it from.
    All Hondas junk your right I agree with ya
    www.bostonmoto.com
    Forum Rules
    Nice try with the quote.
    Go with the 520 conversion if you like having tons of extra horsepower!! (nearly a 1/4hp!!!!)
    And way more replacement chain and sprockets.
    Central Maine
    I cant find a straight answer on the 520/530
    Some say it wont wear any faster, some say it will.
    Concesus I have found is that its not worth it if you have a new chain, but if your chain is old anyway, why not go 520. But I still havent decided. Havent decided on gearing either. Someone on here is gonna let me borrow a chain tool though, so thats good!
    My chain worries me, its in pretty bad shape. Actually, i have a pic.
    edit: Pic is from a thread I started to figure out wtf was leaking in the exhaust, turns out it was just rammed on the flange before and there never was a gasket.
    Actually, it's more a matter of chain strength vs the amount of torque a bike puts out.
    I know that most bikes probably won't snap a 520 chain, but they're rated for a reason. I wouldn't put less than a 525 on a 750+cc sportbike.
    Why take a chance? You could lose a foot or an engine case if your chain snaps under load.
    Central Maine
    Im worried more about my current shitty chain letting go and locking my my rear tire. I DID read somewhere that a 520 is rated to 750cc. I dont race or anything so I may stick with a 530. Who knows. I just dont know what to get and there too many opinions out there to get a straight answer. i dont know if I want steel or aluminum. I just want a standard setup, I dont race or ride that hard, but I am big at 6'5" 240.
    I ride a 900cc bike and went with a 525 (D.I.D. ERV525 Gold) chain and stock gearing with both steel sprockets. Steel is stronger and since you're riding street, you don't have to worry about the weight savings.
    Central Maine
    Sounds lik Ill probably do 530 chain with two steel sprockets then...
    And 15/42 sprockets (or 15/41) I DO commute 70 miles a day on it...
    DID chain, theres two models , dont know which one, and I dont know who to go to for steel sprockets.
    edit:
    D.I.D. 530VM X'ring Chain & Steel Sprocket Kit - Honda RC-51 00-06 - Sprocket Center
    Lifer union's Avatar
    Blackstone, MA
    edit:
    !/2 of the stuff in this thread is true and the other 1/2 is from some guy on the internet.
    I run and have been running a 520 chain and sprockets on my RC with no problems. Im using a DID erv2 chain. I dont think its made anymore so my next chain will be the erv3. Will it last as long as a 530 of course not but if you take care of it will last a long time.
    For sprockets. Steel is the toughest and its what Im running right now. I have AFAM sprockets and when they are cleaned up they look close to new. An aluminum hard anodized is also a good chose but it wont last as long as the steel. I know people that have gotten thousands of miles out of them.
    If you want to go 520 you should be fine as long as you buy good stuff.
    James
    I still Vote Dog
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    Quote Originally Posted by Mongoose441 View Post
    I still Vote Dog
    Central Maine
    I still Vote Dog
  1. Whats up?
    By slapshotman7 in forum Welcome and Intro
    Last Post: 01-24-08, 01:51 PM
  2. Hey whats up????
    By NEWTREADS in forum Welcome and Intro
    Last Post: 06-30-07, 06:29 AM
  3. whats up
    By Biker in forum Welcome and Intro
    Last Post: 07-27-06, 05:34 PM
  4. Whats up
    By bankrobber in forum Welcome and Intro
    Last Post: 05-29-06, 09:41 PM
