This is going to compete in moto-gp this year. great sound from an inline 4...Interested to see how it does.http://hellforleathermagazine.com/20...-hit-the-dyno/
awesome
LRRS Am #331
Sounds and looks so cool...
A good visual on how the rear suspension reacts when power is applied, even if it is three times my applied power! Nice job if you can get it!
That thing sounds beastly.![]()
Shannon
Seeing as it's not vibrating itself to pieces, and the engine don't show any signs of being modded to accept a counterbalancer, plus the comment that it works like a tripple... am I right in thinking he twingled either the inner or outer pair of cylinders and left the firing order of the others alone? So the crank itself is the same, it's a custom cam and redone injector timing to make the magic happen?
I would think they would have needed to make another crank unless 2 of the cylinders happened to be at or very close to TDC at the same time. and of course new cams and timing everything else to match.
LRRS Am #331
LRRS Am #331
The odd-fire engine has a 90 degree crank, so it would not fire at even intervals, just like the R1.
