Results 1 to 19 of 19
Why so bendy?
    Sep 2007
    Middlebury VT
    Question Why so bendy?
    I'm seeing this bendy section a bit more often on some of the newer bikes.
    In an effort to stimulate debate on the subject would it be safe to say it's for ease of oil filter removal?
    http://www.motorobert.cz/Nove_motocy...nt1130_red.jpg
    Banned Euro trash-hole BCT748's Avatar
    Apr 2008
    Salem NH
    Re: Why so bendy?
    It's also, maybe even more so, to keep oil heat down. A lot of heat radiates from the pipes and into that very thin metal oil filter.
    Unofficial self proclaimed official NESR plumber.
    "Ah shit son, datz be a Ducati!"-Random kid in Methuen.
    Sep 2007
    Middlebury VT
    Re: Why so bendy?
    Sounds good to me.
    What about the length of the pipe?
    The pipes on my Ninja seem so simple in design compared to the Benelli.
    Apr 2008
    Salem NH
    Re: Why so bendy?
    There is a lot of science in designing and exhaust. Sometimes the shortest distance isn't the best for the power curve.
    Sep 2007
    Middlebury VT
    Re: Why so bendy?
    So the shape may be just so to maybe slow the flow of exhaust as it travels outward from the engine? Would the insides of the pipe be treated with anything special or is it a moot issue due to pumping forces from the engine?
    Re: Why so bendy?
    A lot of the pipe shape on that bike is for looks as much as anything.
    Apr 2006
    Beverly, MA
    Re: Why so bendy?
    I heart the TnT.
    I would venture a guess (as others have) that it's to keep heat off the block/filter, and to ease filter changing.
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Re: Why so bendy?
    Maybe need length or bullsh*t catalytic converters
    Glen Beck is John the Baptist
    Dec 2005
    Near The Dragon
    Re: Why so bendy?
    Quote Originally Posted by Ericthejet View Post
    the length of the pipe and speed of flow are not related, except when heat loss changes the density of the exhaust..
    "slowing the flow" is never a goal of the exhaust designers.
    well.. actually, at lower rpms and part throttle applications, some resistance to flow helps fatten the torque curve in that area, but that works against high rpm HP which is why many sportbikes are incorporating a flow control valve downstream in the exhaust system.
    ideally, the inside of the entire system would be treated /ceramic coated to hold the heat in and improve flow
    Get out while you can
    Find your own path
    Southern, NH
    Re: Why so bendy?
    Quote Originally Posted by schleppy View Post
    I heart the TnT.
    One of my favorites
    Apr 2008
    Salem NH
    Re: Why so bendy?
    Quote Originally Posted by Cerberus View Post
    Length and shape are two different things. Bends (the shape) are restrictive.
    Dec 2005
    Near The Dragon
    Re: Why so bendy?
    Quote Originally Posted by BCT748 View Post
    REALLY?!
    first of all, my reference to length wasn't meant to make you self conscious
    second of all, someone else referenced length of pipe and implied that the extra forward travel of the pipe could have been for extra length, which would improve low end torque, but cost in high end HP usually..
    ..because the length can be restrictive too, due to harmonic reversions etc
    Find your own path
    Apr 2008
    Salem NH
    Re: Why so bendy?
    REALLY?!
    OK so you just need to learn how to quote the right thing
    You should have quoted this one instead:
    Sounds good to me.
    Dec 2005
    Near The Dragon
    Re: Why so bendy?
    i quoted who i meant to in referencing the intent to slow flow through the exahsut system..
    and I couldn't be bothered with precise ninja quotes.
    are we good?
    Find your own path
    Wirelessly posted (BlackBerry9530/4.7.0.75 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/105)
    It may be for exhaust sound too. I know some companies put big bucks into making sure they have that special note. Otherwise IDK
    Re: Why so bendy?
    does it have anything to do with what will make the company more money?
    Apr 2008
    Salem NH
    Re: Why so bendy?
    are we good?
    NEVER!!!!!!!!!!
    Quote Originally Posted by jcbell1007 View Post
    I thought the only company that gave that much of a shit about how it sounds was HD
    Re: Why so bendy?
    Might be
    I always wondered, just never asked the question
    Expatriated to Seoul spicy's Avatar
    Reading-> 서올특별시 강남구
    Re: Why so bendy?
    buenchy chicks ar efucking aweosnegmm
    hurray, strikethrough!
