Results 1 to 21 of 21
Bike engine temperature...
    mhm... *GhostRide37's Avatar
    Randolph MA
    Question Bike engine temperature...
    for those who have an engine temperature indicator, im curious what a typical temperature reading for you is (street riding, not track). im sure it varies from bike to bike, but what range is normal for YOUR bike
    1995 Yamaha FZR600- my learner, sold
    2001 Yamaha YZF-R1- stolen
    2005 Suzuki GSX-R 750- cutoff by an illegal U-turner and totaled
    2007 Yamaha YZF-R1- stolen... R1s are a hot commodity, huh? any anti-theft system suggestions?
    Current: 2009 Yamaha YZF-R1
    BenSmith
    Senior Member MattyC's Avatar
    Apr 2008
    South Shore, MA
    Re: Bike engine temperature...
    Highway with air flow during 70-80F ambient temp, approx 170-190F. Sitting in traffic with no airflow through radiator or constant stop and start traffic lights; between 220-240F.
    anywhere around 75-120*C or 170-248*F
    Low end of the spectrum when it's a nice day & i'm not in traffic... top end when it's hot & i'm STUCK in traffic. Pretty rare that it gets above 95*C (bout 200.)
    Lifer burnham's Avatar
    Apr 2006
    massachusetts
    180-205F this time of year
    06 R1, seems to always be in the 170-175 range no matter what the outside temp is as long as I am moving. If I get stuck in traffic, the fan cycles on at 218, and it cools to 208 before shutting off. I've never seen a temp above 218 on my bike.
    The 98 R1 I had used to always run at 164 if I was moving and that one the fan cycled from 224 down to 214
    Lifer catamount's Avatar
    Sep 2006
    Colchester, VT
    Moving in sub 80 degree weather: 175 steady
    Stopped: Quickly moves up to 219 and the fans come on
    Apr 2006
    Beverly, MA
    Quote Originally Posted by catamount View Post
    My SV is pretty much identical to this.
    Posting Freak
    Wilmington, MA
    180's-220's depending on weather/movement
    I Dance With Will
    Oct 2002
    unknown
    yea man same as mine when new and have seen 220 at most. but now it doesn't go down when fan kicked in and i have seen 240 unless i start moving quick. i had water in there at some point when i notice. now has that expensive antifreeze and seems worse. im taking thermostat out next.
    "fuckit!"
    live to ride seth399's Avatar
    Feb 2007
    CA
    Isn't that coolant temp? either way mine was around 205 today (pretty hot) and sitting in traffic it gets up to 220-225 F
    Just Registered drop's Avatar
    Bradford, MA
    (2006 ZZR600)
    exactly 153 all day on the highway when it's under 80 degrees out, otherwise it floats in the low 160s.
    in traffic it'll hover around 185-195, and occasionally will hit 200-210 when it's really hot. in heavy traffic fan will kick at 215 till it drops to 205...this goes on till i can stay above 15mph or so again.
    Expatriated to Seoul spicy's Avatar
    Reading-> 서올특별시 강남구
    07 SV650S
    168-174 if i'm moving and/or it's cooler than 75*
    180-220 if it's warm and i'm not going too fast/or it's hot and i'm stationary
    hurray, strikethrough!
    Sep 2006
    Around the corner
    04 cbr 1k
    174 when moving and 233 when sitting at a light. After 14000 miles or so I discovered that if you hold the throttle just ever so slightly off idle the fan so graciously kicks on and she'd hover around 217-219 till I started to move again, in cooler weather it would come down to 209 - 211.
    Not sure if other mfg's have the same function feature but it's worth the testing to keep your eng slightly below grenade temps
    The rule is:
    CBR 929 W/ antifreeze
    80deg
    Highway = 178-182
    Traffic = 214-225
    I may be switching to water my next oil change for the hotter temps within the next couple of months. Who else is running straight water with an additive? Does it help with the recovery temp?
    170 on the highway, and 200 when we were riding in the city 2 nights ago, and when i was out riding last night
    Leo loridin64's Avatar
    Outside Lowell
    RC51 - cold days (35-55) runs 150-165 around town. Summer, the fans will turn on at ~220 and take it down to around 207 in traffic or not. Frame gets so damn hot its unbelievable. Easily the hottest bike ive ever ridden
    2002 RC51
    USMC - Semper Fi
    POW/MIA - Not Forgotten
    Oct 2001
    Bedford, MA
    Mine is steady at around 175F when moving, that's when the thermostat opens/closes.
    Fan comes on at 220 in traffic, which happens pretty easily.
    We are all at the mercy of the manufacturers here.. bikes will probably only get hotter. Current bikes run hotter then the old ones cause the EFI allows them to run leaner mixtures.. better fuel economy & emissions as emissions tend to drop as exhaust gas temperture goes up. All the extra horsepower isn't helping either.
    I swear mine runs a little cooler with the map richened a little.. but I can't prove it scientifically or anything.
    something witty here tsanterre's Avatar
    Milton, VT
    '07 CBR 1000rr
    Steady riding - 189
    Hot in traffic - quickly to 210
    Fan comes on - 220
    ~that which doth not kill me can only make me stronger~
    LRRS / CCS - #103
    Nik viva_brasil's Avatar
    Dedham
    05 R6,
    fan on at 210
    sitting in traffic i've seen it get to 220s
    on the highway on a hot day it's steady between 160-170.
    Current:
    00 Aprilia RSV-R
    Past:
    06 R6
    05 R6
    97 Honda F3
    Oct 2005
    Wrentham MA
    80deg
    Highway = 178-182
    Traffic = 214-225
    My Duc 851 would get as high as 240 in traffic... I switched to engine ice - it still go as hot be recoverd to normal temp quicker - the motor was pretty heavily breathed on:-). It also ran cooler in normal operation180 vs 210.
    added race fuel...brought the temp down further... (slower burning)
    Graham
    Graham
    in traffic wicked Hot
    on the highway still wicked Hot
    parked in the sun Hot
    parked in the shade warm.
  1. For Sale - Parts & Tools | FS: Woodcraft Dual Temperature Tire Warmers
    By Gecko in forum For Sale
    Last Post: 07-18-14, 12:28 PM
  2. The formula for acceleration times/temperature
    By KingCast 650R in forum General Bike Related
    Last Post: 09-01-10, 03:22 PM
  3. R6 Operating Temperature
    By jmer24 in forum Bike Maintenance
    Last Post: 07-13-10, 11:46 PM
  4. Ducati Temperature Question
    By S4R_GRL in forum Bike Maintenance
    Last Post: 06-30-08, 03:33 PM
  5. running temperature
    Last Post: 05-05-06, 09:38 AM
