Results 1 to 22 of 22
De-sleeve an Sv???
    Meriden, Ct
    De-sleeve an Sv???
    Can someone explain why you would want to de-sleeve an Sv650 race motor down to a 599cc?
    I saw a built motor for sale and it has been sleeved down to a 599cc. This baffles me. Unless you need to do it to make it fit into some specific class... Otherwise I don't see the benefit of smaller displacement.
    Nov 2007
    Re: De-sleeve an Sv???
    Someone correct me if I'm wrong on and of this.
    First of all, you've mixed up your terminology a few times.
    De-sleeving would be removing the sleeves from a sleeved motor, thus increasing it's displacement. Sleeving a motor decreases it's displacement.
    Sleeving a motor often involves inserting a tougher metal sleeve into a lighter metal motor. With the stronger sleeves your displacement is decreased, but it allows you to run higher compression (for N/A) or higher boost (F/I)
    It is often used in turbo applications (1999-2004 audi S4 is an example IIRC)
    maybe i am confusing this with something else though
    Zip-Tie Alley Racing
    LRRS/CCS #103
    They use the motors to run smaller and sportsman classes In wera and maybe other race organizations
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    Lifer daviid's Avatar
    Oct 2004
    Plantsville, CT
    Quote Originally Posted by BLACK SQUIRREL 441 View Post
    ding ding
    -Benjamin Franklin
    Lifer McBiggity's Avatar
    May 2003
    Charlton, MA
    Alot of western coast guys run SV's detuned to meet regulations. Noel, just run your SV and learn. You'll be amazed about the difference between trackdays and racing
    Lifer obsolete's Avatar
    Norf Sho
    Quote Originally Posted by ceo012384 View Post
    Desleeving would only refer to the removal of an old sleeve regardless of displacement. If you desleeve a motor it must be subsequently resleeved. The new sleeve could be of greater or lesser bore size.
    Most new motors are made of aluminum which cannot take the stress. Therefore a steel sleeve is inserted into the block as the bore. This is also used on iron blocks in the case of massive bore damage. Sleeving has no effect on bore size unless you want to change it.
    -Alex
    Posting Freak
    New Hampshire
    There was a good article in Roadracing world a while back about Twinworks using parts from Japan spec SV 400 motors to make smaller displacements.
    The one in particular they looked at was raced at willow. Some 500cc class I think
    Central VT
    I'd say that Pete wins!
    Jake
    2006 ZX-10R
    1999 Kawasaki ZRX1100
    Meriden, Ct
    Quote Originally Posted by McBiggity View Post
    Oh trust me. I wasn't considering buying it. My SV is just fine the way it is.
    Nov 2007
    Gotcha. Thanks for the info.... didn't realize most newer motors were already sleeved.
    LRRS/CCS #103
    Norf Sho
    Yea, anything with an aluminum block will be sleeved.
    Here's a cool article about an iron block being sleeved after the cylinder was ventilated. http://www.popularhotrodding.com/eng...ing/index.html
    -Alex
    Lifer eboos's Avatar
    Quote Originally Posted by Ryno View Post
    I have that issue around somewhere, but the long and the short if it was they used the SV400 crank which was a shorter stroke and had custom rods made.
    You should be warned, CCS and LRRS do not allow decreasing displacement to fit in lighterweight classes.
    Dude, the issue was actually siting right here on my desk. Stand by for update. It was the March 2007 issue.
    Update: the rod length went up to 5.029" from the stock 4.744". They used stock cylinders, pistons, heads and everything.
    no, a lot of surface treated aluminum, for instance once difference between the SV650 and V-strom 650, the SV is sleeved, the Strom isn't, it's got a electrochemical coating some secret suzuki recipe called SECM, similar to nikisil I guess
    lotta dirtbikes use it
    Norf Sho
    Really? I didn't think it would take it. Learn new stuff everyday.
    -Alex
    Meriden, Ct
    Psssttt... It's nikisil...
    Posting Freak
    New Hampshire
    Yeah most modern sport bikes are not sleeved. I know early on Nikisil was the main one, but I think there plenty out there now
    Chevy made a bad attempt at treated aluminum blocks in the early 70's with the chevy vega
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    I liked the vagas
    www.bostonmoto.com
    Forum Rules
    Yeah, but the term "de-sleeving" refers to reducing the ccs. That is all.
    thrilled brady's Avatar
    Nov 2007
    Raymond, NH
    Quote Originally Posted by beet View Post
    I liked the vagas
    My Vega ran just great with 2 different heat ranges of plugs and 1.5 quarts of oil for every tank of gas. You had to keep the windows rolled up at stop lights so it wouldn't fill up with blue smoke (some still came in through the floorboards). I still wonder sometimes how it got by with a two speed automatic transmission.
    My Dad made me sell it after he drove it for the first time, said it was a "deathtrap". My next car was a Chevette . Put an amazing stereo in it that made me forget I was driving another crapwagon for four years. Best car I ever drove in the snow, though, tracked like a sled with skinny runners, and no power to break it loose even though it was rwd.
    The 5.0 Mustang (4.9 really, but no one will ever admit it) that I got next tapped into a whole new part of my brain, a good thing it came a while later.
    Some one said "Vega" (OK, vaga), not my fault...what was this thread about?
    Quote Originally Posted by brady View Post
    My Vega
    well, mine actually wasn't bad engine wise. but I swapped the tiny radiator for one out of a Nova, put over 100k on mine when the rear suspension began disintigrating, took engine out and used it to replace the one in my sister's Vega that had characteristics of yours
    My dad's company decided to economise and replaced his Impala company car with a Chevette diesel, auto trans & air conditioning , I think it could do the quarter mile in 45-50 seconds
  1. TLRman, lookey what Suzi has up their sleeve
    By SEVENSGT in forum General Bike Related
    Last Post: 09-18-03, 06:22 PM
