Results 1 to 22 of 22
possibly just gixxer related.
    Jan 2009
    Waltham
    I've taken my 750 k8 out a few times in 09 and it seems like if its been more then a week of me not riding it the rear goes flat. I have done a thorough inspection of the back tire (visual inspection/ slight over inflate and soapy water trick) and have come up with nothing. the bike isn't on stands and is moved at least once a week. also the tires are the origonals with less then 1200 on them. Is this normal? any ideas?
    Re: possibly just gixxer related.
    Have you tried the soapy water at the bead of the tire where it meets the rim? Maybe it is not seated properly.
    Meriden, Ct
    How is a leaky Bridgestone "gixxer related"?
    Two demerits!
    If the tire is not compromised, and the bead (where the tire meets the rim) is not leaking, then the valve stem is leaking. The valve core inside the stem is either faulty, or loose.
    Jan 2009
    Waltham
    damn, demerits already...
    put that there mainl to see if any other riders with similar bikes had similar problems, well if the valve stem is leaking ill see if I can take it to where I got it and have it fixed. would this be covered in the year warenty?
    Just Registered Doc's Avatar
    Jericho, VT
    It had better be covered.
    You could just try and tighten the valve stem yourself.
    Burnouts will break the bead on a tire, so will wheelies. STOP trying to do them.
    Lifer Pittenger5's Avatar
    Austin
    You aint my momma!
    Zip Tie Alley #505
    Jan 2009
    Waltham
    haha doc, no burnouts and no wheelies, scouts honor. the bike has seen one lowside at about 5mph at the end of the season due to probaly the first patch of ice in newengland. hopefully the dealer doesn't decide to blame the tire problem on that. Considering the barend and mirror were the only things scuffed. The human body is an excellent frame slider...
    Jericho, VT
    You aint my momma!
    Nope, but who's your daddy?
    Meriden, Ct
    Quote Originally Posted by WordTooYoMamma View Post
    No, Suzuki will not pay for your leaking valve stem. Nor will any other manufacturer. Tire pressure and maintainence is your responsibility.
    If you have a good relationship with the dealer, they may do it and not charge you. Bring them just the wheel, so they don't have to mess with the bike. If it takes them more than 5 minutes, expect a bill.
    Meriden, Ct
    Really? Please enlighten us on how a maintainence related issue, on a wear item, "had better be covered" by a manufacturer?
    i've never had a tire loose air on ANY of my bikes... EVER.... including bicycles... even cars.... every tire i've ever owned has held pressure forever.
    It's definitely gixxer related.
    I haven't ridden my K6 YZF R1K yet in K9 but I just kicked the tire and it's still got air in it. Gotta be a gixxah thing
    On a more serious note, if you have a good relationship with your dealer, they will take care of a minor issue like a valve stem
    Jan 2009
    Waltham
    thanks for the advice, gonna recheck the tires with the soapy water, and as soon as the 15inchs of snow is gone up to manchester I go.
    Senior Member TimmyB's Avatar
    Southern AZ
    Russel Crowe wouldn't have to pay.
    Feb 2008
    Las Vegas
    Quote Originally Posted by TimmyB View Post
    Fuckin A
    Carpe Diem
    '10 Yamaha R6-Race-
    Go to a bicycle shop Get a shrader (sp) valve and remover looks like a valve stem cover with two teeth on the top (less then 2 bucks) stick in the valve and turn it like a screw it will screw out and the air will escape screw the new one in.
    I will bill you
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    Dude, if you're considering going all the way to Manch for this, hit me up before you go.
    I can save you all sorts of time as I have a Schrader tool and am in Hudson.
    Make check payable to "Zip-Tie Alley Inc, C/O Black Squirrell".
    Just write any number in the box and we'll fill in the appropriate amount of zeros.
    But seriously, don't go all the way to Manch for this....unless you really feel the need to.
    did you put winter air in or summer air?
    Meriden, Ct
    Weak...
    and...
    Late.
    Jan 2009
    Waltham
    Weak...
    and...
    Late.
    Agreed, and i get summer air smuggled in from Mexico, along with some other stuff...
    Infected Slyder's Avatar
    Concord, NH
    So in the end it's not a gixxer thing, not the tire, rim, bead or the stem...it's you and this stuff smuggled in from messico
    no one else said winter air so GFY
  1. Possibly FS: Modded TTR 125 L
    By Kitt in forum For Sale
    Last Post: 07-23-09, 08:42 AM
