Results 1 to 10 of 10
bike wont turn over
    Junior Member drszsoldier's Avatar
    Apr 2011
    bike wont turn over
    A friend of mines has a Gsxr 600 2007
    The bike tipped over on him on the other day and cracked the generator cover slightly on the bottom of it and started leaking oil
    The bike turned on normally even before we changed the cover
    We replaced it with a new one and, and then added oil since everything dripped out
    When he puts the switch key on the on mode all the lights turn then when he goes to start it the engine doesn't turn over as if the whole system shuts down when he tries to start it
    Is there any wires connected to the generator cover that we should be concerned about?
    We made sure the kill switch wasn't on and it still won't turn over and the battery snt the problem because we tried another one
    Any suggestions?
    Stator wires come from there. If they are unplugged you will get no turning over.
    Addict jbmass's Avatar
    Nov 2010
    Warwick, RI
    Re: bike wont turn over
    TIP OVER SWITCH, check to make sure it isn't closed
    Apr 2011
    Quote Originally Posted by jbmass View Post
    Where is that located?
    Nov 2010
    Warwick, RI
    Below the seat, directly behind the gas tank. I has two wires leading out of it, should read between 0.7 to 7 ohms, definetely not closed. It's just a small box, inside is a metal semi- bent horizontal rod with a washer riding it. If the washer makes it to either side of the box it grounds out, it's a interlock to protect the bike & rider incase of a tip-over.
    Bike have a few interlocks, some more than others ie: kick-stand, neutral safety, clutch lever, tip-over etc.
    Apr 2011
    Are they plugged into something under the generator cover or is it under the plastics?
    Apr 2011
    There were no 2 wiresz
    Lifer Punjistick's Avatar
    Norwell, MA
    I believe the tip-over sensor is at the very end of the sub-frame on the '07s. Here's 2 pics out of the manual.
    yes, they are.
    Feb 2004
    Bellingham, MA
    turn the key from off to on 3-4 times. It resets the tip sensor.
  1. Bike wont continue to run HELP please
    By Bkilm in forum Bike Maintenance
    Last Post: 08-23-11, 07:33 AM
  2. BIKE WONT START
    By dj 96yzf750 in forum Bike Maintenance
    Last Post: 07-23-09, 05:49 PM
  3. bike wont start :(
    By daviid in forum Bike Maintenance
    Last Post: 05-17-09, 11:29 PM
  4. Bike wont start?
    By Rclassic03 in forum Bike Maintenance
    Last Post: 08-21-08, 06:10 PM
