2003 RC51
1997 ATK 605 project, 95 % done
1994 Yamaha Serow DONE
cant get the brakes to bleed on the atkl ,despite the vac bleedert from duncan moto
and needs a brake lever, brake switch, and clutch cable....
my new girlfriend:
That ATK is gonna be fun!
(Im partial to the 51)
The bleeder screw is clogged. Take it out and clean it.
2018 Harley Road Glide
2000 Ducati 900ss
2003 Harley Softail Deuce
interesting theory.....
I took it for its first ride tonight
No clutch, no front brake, no rear brake
Come to find out, a 605 thumper is really fast....
feel no pressure when pumping the brake
put a vacuum bleeder on, and cant pull the fluid through either.
I dont think the bleeder is clogged, the rubber cap was still on it, and the bleeder is very clean, but Ill check for clogs
I think I need to bench bleed the front and rear MC's
How long did the bike sit before you got your hands on it?
I had an old suzuki GS550 that had sat for a while and the brake fluid turned into a sort jelly. Maybe you have some of that type of thing going on somewhere in your lines. Once we flused the jelly like substance out of that GS everything worked correctly.
Joel
It had sat a couple years, but the front brake line is brand new
Yeah the goo on the GS was in the master and the caliper as well. We had to pull it all apart and clean it out then it was fine.
Good luck getting it fixed regardless, motards are a blast on the street because even if you are riding them hard you likely wont be breaking 60 mph and having a blast doing it. Unlike a liter bike where you hit it in first and you are breaking every speed limit there is around here.
Joel
