Results 1 to 10 of 10
Bleeding Tiller, Calling All Tiller Owners
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    yep i was liking dem new sukis
    now you and dat dar stoner sayin day say not soa good ????
    www.bostonmoto.com
    Forum Rules
    Lifer oreo_n2's Avatar
    Mar 2002
    Amherst, NH
    i'll give ya $10 for the tiller.
    Brent LRRS #772
    2006 KTM 560 SMR
    May 2002
    Meriden CT
    ok i'll give ya a grand
    nesrebay
    www.bostonmoto.com
    Forum Rules
    Mar 2002
    Amherst, NH
    man, even detuned and pissen jizz, my tl would eat your falco for a snack before breakfast, then ill take your $10 and slap you in the ass and send you on your way
    Blow Me!
    i wasn't posing a competition!
    Focker!
    Brent LRRS #772
    2006 KTM 560 SMR
    Northshore/Beverly, MA
    You have too much oil in it...and if the seal around the clutch pushrod isn't replaced, you'll piss it there too.
    Too much oil in crankcase, and wheelies = leak out those seals...
    Make sure they are brandy new, and everything is clean.
    Check to see if it's coming from the airbox, you may have a pinched breather line too! or one that fell off....
    Next question is did you buy the bike new, and how did you break it in?
    The cylinder lining isn't a steel sleeve, and if you romped on it too early, you may have glazed or damaged the cylinder, and is now generating too much blow-by into the crankcase, pressurizing the case above normal.
    Lots of reasons....
    Just clean it up really good, ride it, and look for traces...Gravity will always be working against you. where you think the leak is, may be above it.
    The fix for the wheelie oil leak is to fill crankcase with oil, until it reaches the center of the sight glass.
    Like Josh said, counter shaft seal, or could be the clutch push rod seal too...It gets a lot of crap built up there from the chain lube and crap in general.
    As for mine, ABSOLUTELY NO PROBLEMS..... After I did all the preventative fixes for it.
    BTW, I sucked up the forks into the triple clamps about 13mm total, and that F__king thing sets into the corners like it's on RAILS!
    Re: Bleeding Tiller, Calling All Tiller Owners
    Originally posted by tiller
    i am honestly thinking of selling it and purchasing an rc51 for next spring, anyone any thoughts, degsy what are your thoughts on the rc51 any problems that would deter me from purchasing one?
    You mean other than the leaking gas tanks? Nope, haven't heard of anything other than that. But the passenger seat is about the size of a panty liner, so two-up probably wouldn't be good...
    I've ridden an RC51, and I can't say it had anything over the Tiller. I'm definitely happy I went with it, and would do it again if given the opportunity...
    Walpole
    How about not doing any wheelies when you take it out for a test drive. Instead of a 4 mile ride make it a 2 mile ride. If oil is leaking out take all the plastic you can off the bike and take it for a naked ride and you might see what you couldn't before, like TLRman said "Gravity is working against you". If you are getting that much oil out of your bike from a 4 mile ride then you should be able to make it weep oil out froma stand still. Just keep trying different things untill you find the damn thing, one test will be sure to find what the other did not.
    Ed
    5) it is hard to trace a leak when you have an area that starts just above the stator cover and goes all the way back to the rear left of the swing arm
    If it starts just above the cover then it either has to be comming from the cover or above it I would say.
    My 2 cents
    2018 Harley Road Glide
    2000 Ducati 900ss
    2003 Harley Softail Deuce
    Mar 2002
    Amherst, NH
    hey tiller, the falco is a competitor to those other twins too, realistically. and it snot as expensive as the mille. the New 2002 falco R's are 93% of a mille at 10,900. just a little more than a NEW TLR.
    i am sure you could get a good deal on a used one.
    but this is not very productive help or the info you are looking for, keep looking for htat leakage source dude.
    Brent LRRS #772
    2006 KTM 560 SMR
  1. Wanted - Other | Roto tiller
    By bbhzx10 in forum Wanted
    Last Post: 06-08-15, 09:29 AM
  2. tiller
    By ri-gixxer in forum Wanted
    Last Post: 02-23-11, 08:29 AM
  3. help with my tiller...
    By KillahTillah in forum General Bike Related
    Last Post: 02-24-09, 05:46 AM
  4. hey tiller.....
    By oreo_n2 in forum General Bike Related
    Last Post: 07-31-02, 05:32 AM
