Results 1 to 4 of 4
Blowing fuses on my 02 F4I
    Member MrBreese's Avatar
    Northfield NH
    It's the 10 A fuse for my instrument display. Blew once couple weeks ago in VT. Now again on short ride Saturday. This is third season on the bike. Had aftermarket front directionals when I got it.
    I'm guessing it's a bad connection or chaffed wire but before I start my goose chase I figured may as well see if any ones dealt w/it b4.
    Thxs for any help!!!
    Murphy says you'll catch up to Granma just before the Twisty sign.
    Re: Blowing fuses on my 02 F4I
    Is the fan fuse the same as the dash fuse?
    I ask only because if they are related then there's prolly a pebble keeping the fan from turning and subsequently blowing the fuse.
    A bad connection isn't likely the culprit but a chafed wire hitting a ground is.
    Good luck.
    +1 probably an open wire hitting a ground
    <---- R.I.P. Hauptman's Avatar
    Pepperell, MA
    yep...shorting the system somewhere...chaffed wire is my bet
  1. XR's Only is blowing out some KTM parts along with others
    By gt_pedaler in forum Dirty Bastards
    Last Post: 10-21-13, 08:00 PM
  2. Cooling fan blowing fuses
    By The Snowman in forum Bike Maintenance
    Last Post: 01-17-10, 10:38 AM
  3. Fuel pump relay blowing
    By Nate Dawg in forum General Bike Related
    Last Post: 10-19-08, 09:40 PM
  4. Blowing white smoke
    By ahtune69 in forum Bike Maintenance
    Last Post: 04-27-07, 08:07 PM
  5. Fuses
    By Collision pro in forum General Bike Related
    Last Post: 03-13-04, 01:29 AM
