I picked a little compressor up for $15 on Saturday and realize it could probably fit in some of the bike trunks out there... Any of you overachievers installed one of these yet??![]()
A. ...But I can go to jail for that!!
Q. For what? Being f*ckin' awesome?!
RandyO has a lil' compressor that he keeps in his saddle bags....Its Not "hard wired" but he does have a ""quick connect"
Honda (RC26) VFR700
"hey Randy, do a wheelie!!"
Mr. R7 had one mounted in an R1 for an air shifter. Don't think it'd fit in the trunk of his '04 R1 though.
That must be nice, especially on long trips.
I learned the value of a compressor and tire plug kit after getting stranded with a flat on Saturday. It's got me thinking about being more prepared, while I walked home cursing my tire and dead cell phone.
I had a hunch someone on here had already rigged something up!
Yep, i had it in a 98 R1, then reused it again in a 99R1. I think the brand i had was MRE and it fit in the trunk of my R1 perfectly. I had always thought about adding an extra fitting so i could add air to the tires but i never got around to it. It had no troubles pumping the small air tank i had on the bike up to 130psi.
It'll fit in the new R1's trunk as long as you don't mind removing that little X bracket![]()
I can't find the link, but basically the guy bought a $15 Campbell Hausfeld mini air compressor from Wal mart and cracked open the case.
By the time he was down to the pump gauge and cord, it was so small he could mount it inside his frame rails under the seat and jump to the battery to pump up a flat.
Kinda cool.
A DIY for $20 cheap.
-Suf Daddy HTH
Suf Daddy.
When you buy your tire plug kit, get the BMW kit that they make for their bikes... Best damn tire plug kit out there, you'll see why when you take a look at one.Originally posted by RedRider
Cheers,
Chris
I was pretty impressed w/ stoinky's Stop 'n' Go kit last year, better than my Progressive kit by far. now that they make an even smaller version, I've got one always in my tank bag...![]()
jeff f
'97 RF900R
Since I ride more than one bike, my cheapo compressor stays in my tank bag. I have it rigged to plug into my electric jacket outlets. Only used it once on one of my bikes but have fixed quite a few flats for other folks.
Does it look like this?Originally posted by Suf Daddy
Kinda cool.
-Suf Daddy HTH
http://www.harborfreight.com/cpi/cta...temnumber=4077
or
http://www.harborfreight.com/cpi/cta...emnumber=43520
It could be the 4077 one without the plastic around it.
When I find the link I'll send it. Its the compressor guts only.
Looks like a torch for cookin' the rock on your spoon.
-Suf Daddy
Suf Daddy.
I just picked up a 12V cordless comp at Ocean State Job Lot for 25.00. Just charge it up and throw it in the tankbag and you got air on tap. One charge should fill up about 3 bike tires after you plug the hole of course.
Chris, thanks for the tip! That question was also lingering in my mind. My current plug should hold well enough to get me to a tire change, but it still has a slow leak.When you buy your tire plug kit, get the BMW kit that they make for their bikes... Best damn tire plug kit out there, you'll see why when you take a look at one.
But I'll add the BMW plug to my road repair kit... Leave it to those crafty Germans!!
