Page 3 of 3 FirstFirst 123
Results 51 to 61 of 61
need a bolt extracted
  1. #51
    Re: need a bolt extracted
    could a steel thread insert get cut to be shorter with a dremel, or am i thinking crazy?
  2. #52
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    The insert needs to be 1.5x the bolt diameter to provide adequate holding strength. That's why they are 33 mm (22x1.5=33).
    the frame only has 15mm of threads. so the bolt wont do its job properly if it's too long
  4. #54
    Powercoil. Measure your threads and job thrice to make sure you order the right one.
    https://smile.amazon.com/dp/B008V13QHO
    i just ordered this. sucks that it's in the UK and international shipping will take 4-6 weeks.
    i just called a shop that sells these kits and they wanted 3x the price that this one was on amazon. they did tell me that people do and can cut the thread inserts shorter to fit. so i'll just have to cut mine, put a good amount of red loctite in there, and hope it holds. luckly, the bolt that uses these threads only gets like 10 ft/lbs of torque, so it should be ok. this bolt only centers/pinches the motor to the frame. the hole in the middle is for the actual motor mount that gets 58 ft/lbs
  5. #55
    Haverhill, MA
    Wouldn't suggest installing a thread repair coil with any Loctite.
    The fact that it is a coil will make it so that the threads should not move once inserted properly. The coil will actually be slightly larger diameter then the threads that you will cut with the provided tap. The spring tension in the coil will secure the threads into the tapped hole.
    Also, unless you plan to never have to remove or adjust the hardware that uses these threads do not use any Loctite on the hardware threading into the coil.
    Cutting the coil to length should be done prior to inserting the coil and it would be good to cut it slightly shorter then needed, half a coil or so, so that it does not protrude out of the threaded hole on either end once inserted. Make sure when you cut the coil that the end that was cut does not have any burrs and will sit correctly into the threads or you could have issues threading in the hardware that goes into the hole.
  6. #56
    Oct 2020
    Chelmsford, MA
    snapped bolt and stud extraction is a special kind of nightmare repair. you either end in complete success or complete failure. you're well on your way to one of those outcomes
    TWINS! xrocket21's Avatar
    Central Maine
    16 studs in the Vortec 8.1L headers... Had to extract 13... Took an entire week.
    the bolt itself will have never seize.
    i was just concerned that i'll have to cut the thread insert in half, as i only have 15mm of thread in the frame,. the insert is 33mm
  9. #59
    Haverhill, MA
    Yes you will want to cut the coil so that it is roughly 14mm tall so that it does not stick out either side of the threaded hole you are installing it in. As mentioned though make sure where you cut the coil does not have any burrs on it or that could cause you issues with threading in the hardware you plan to never seize.
    Ashford, CT
    Does the bolt utilize all those good threads that are still left or does it it only engage those messed up threads? If it engages those good threads I'd just chase those bad threads and run it. All it does is center the engine, where do you think it's going?
    Jeff
  11. #61
    Quote Originally Posted by GearHd6 View Post
    cant chase threads that are gone. i'd rather not install a new frame knowing it will have thread problems. that thruster will be a pain everytime i do motor swaps, which is every 1-2 years.
  1. Dropped bolt
    By 02redhawk in forum Bike Maintenance
    Last Post: 07-31-18, 12:56 PM
  2. Which bolt is it ?
    By danny86 in forum General Bike Related
    Last Post: 09-02-12, 07:10 PM
  3. WTB: Banjo Bolt
    By jcbell1007 in forum Wanted
    Last Post: 04-12-11, 12:21 AM
  4. How do you get out a snapped bolt ?
    By danny86 in forum Bike Maintenance
    Last Post: 06-05-10, 10:40 PM
  5. New Bolt On for Jim
    By csmutty in forum General Bike Related
    Last Post: 01-08-10, 06:39 PM
