Results 1 to 25 of 29
need to borrow head socket
    I Dance With Will
    Oct 2002
    unknown
    for this... size 46
    "fuckit!"
    Northshore/Beverly, MA
    for this... size 46
    You need a spanner wrench...not a socket....Have another beer!
    Don't forget to take the circlip off 1st...
    I Dance With Will
    Oct 2002
    unknown
    manual shows special socket so you torque it down. that's the "adjusting nuts". i'll go look for spanner.
    spacer was off.
    "fuckit!"
    spacer was off.
    Yeah....they are idiots....makes you go out and buy their "special" tool....
    hammer and a screwdriver..... right mark?
    Lifer s a x m a n's Avatar
    Mar 2003
    Lee, MA
    i have one ... don't know the size ... it's for my RR
    It never got fast enough rebelpacket's Avatar
    Jul 2003
    Bozeman, MT
    You can make one of those tools. Get a socket thats the same size, and either mill, or grind flanges down. I made a tool like that out of aluminum. I might be able to make one for you too if you give me dimensions. Hell, the one I made might fit that. Whats the diameter?
    This is the tool I made to take off this nut. Looks similar to what you've got. (its the four pointed one in the back. I made another tool for the two pointed screw in the front).
    Let me know the dimensions. If this tool will work, I'll ship it out. Otherwise, I'll try and make time to make one for you.
    I Dance With Will
    Oct 2002
    unknown
    already try that, not comming off easily without severe damage. it's 33lb/ft of torque or was it 18lb/ft? anyway it's in the book.
    "fuckit!"
    33ft/lbs isn't that much, especially with a large flathead or small brass drift. Maybe it's threadlocked?
    I Dance With Will
    Oct 2002
    unknown
    size 46mm.
    Alex, COuld you please make me one if Saxman doesn't have it and i'll pay the bill.
    OH WAIT! 46mm is the overall diameter, yea i measured it. the socket size would be based on the inner diameter of the cutoff? i'll have to remeasure.
    "fuckit!"
    I Dance With Will
    Oct 2002
    unknown
    it's aluminum... that's the problem.
    "fuckit!"
    Lifer JohnnyV's Avatar
    Westborough, MA
    Aaaah so I see Mark set up your rear suspension also...
    Jul 2003
    Bozeman, MT
    Measure from point to point, and then from recess to recess. If its a 46mm, I'll need to make something. I think I have barstock large enough. I'll make it out of aluminum so it shouldn't tear up the nut anymore than it already is. I'd reccomend replacing that when your done.
    Honestly though, a spanner wrench should be able to take that off. Maybe try a little heat? Got a mig welder? If you got one, or know someone with one, weld a small bead on the nut. Often the heat from welding it is enough to cause it to shrink slightly and spin right off.
    I Dance With Will
    Oct 2002
    unknown
    Quote Originally Posted by rebelpacket View Post
    46mm is the overall diameter. let me measure all the dimension and draw it out before you make it.
    "fuckit!"
    Jul 2003
    Bozeman, MT
    Cool. 46mm is a big mofo. Also measure the diameter (and height) of that stem so I can bore a recess in the tool to fit over that, and get it high enough.
    I Dance With Will
    Oct 2002
    unknown
    Quote Originally Posted by 02Telefonica View Post
    "fuckit!"
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Water pump channel locks
    also warm it some like 300 F
    Double check your book on the specs/procedure
    most are tighten to 18
    back off, tighten to like 1 ft pound
    prepare to porpoise
    Glen Beck is John the Baptist
    youre not hitting it hard enough...
    Lifer Rye's Avatar
    Nov 2002
    Behind Enemy Lines
    Rebelpacket's suggestion is the right way. Do not hit it with a hammer and drift. Get the dremel out and go buy a socket from sears that is the same ~diam. I just made two swingarm castle nut removers for my XR doing the same thing. Honda wanted $90 for the tool. I made the tool (capable of torqing, for under $15).
    '95 ZX7/9
    '02 XR650R
    '78 KZ1000
    Hey...I said "special tool" didn't I?
    Oxx used a "special tool" getting Amanda's seat off her bike.....
    I didn't want anything to do with it.....Cheers Oxx!
    Just grab a spanner, you can get them in all different sizes.
    Cut a pipe that goes over the spanner tool, and measures a total of 1 ft.
    Get a scale that measures 50 lbs, strap it onto the end of the pipe, and pull until it reads 18 or 33 lbs....
    If you actually go out and do this........nevermind....
    Have Rebel make up the tool for you, so you can put a real torque wrench on it....
    Lifer Wishbone's Avatar
    Jul 2006
    get a pair of 442 series channel locks and your done
    hit it harder....
    I Dance With Will
    Oct 2002
    unknown
    hit it harder....
    i'll hit it harder. just give me your forhead.
    "fuckit!"
    I Dance With Will
    Oct 2002
    unknown
    hey Rebelpacket, is this good enough?
    correction: the thickness is 5.5mm not 5.0mm
    "fuckit!"
    Jul 2003
    Bozeman, MT
    Thats plenty good. Got a few things to do, but I'll do my best to get something together by this weekend.
  1. need 32mil socket
    By k_cotter in forum Pit Area
    Last Post: 10-04-12, 06:00 PM
  2. Would like to borrow Head/Tripple tree stand.
    By DoyleOil in forum Bike Maintenance
    Last Post: 08-13-12, 03:32 PM
  3. Waterproof 12v USB socket
    By scubasteveRR in forum General Bike Related
    Last Post: 04-20-12, 01:07 PM
  4. Replies: 23
    Last Post: 09-03-09, 07:32 AM
  5. socket question
    Last Post: 12-12-07, 09:40 PM
