Results 1 to 17 of 17
A " is this normal" question.
    I am relitivly new to streetbikes, so bare with me.
    I have notice if I attempt to put my bike into 1st gear from nuetral, slowly, it seems to kind of not go in at first. Almost as if the gears are still moving around, and the clutch hasn't fully engaged.
    The bike doesn't move at all when its in gear, and I am holding the lever. So the cable doesn't need to be adjusted.
    Other times it just goes in real hard.
    The bike only has 3k mile's. That leads me to believe it is just normal. I know what a worn, or slipping clutch feels like on a car, and it doesn't feel at all like that.
    Any input?
    Bruce O.
    03 600rr.
    95 Talon TSI AWD project.
    Member jimaug87's Avatar
    May 2007
    Peabody
    My clutch is fine and my bike does the same thing. I'm not sure why it is happening, but I just kick it firmly and quickly and it will pop right into 1st.
    I am also curiouse to why you can't slowly slide it into first.
    I should also mention my bike is a 03 600rr
    Quote Originally Posted by jimaug87 View Post
    Well, at least that makes me feel a little better.
    Bruce O.
    03 600rr.
    .... naked-daytrader's Avatar
    May 2007
    Why would you want to slide it into 1st gear slowly??? It's not meant to do that....so son't do it.
    CCS|LRRS EX#49
    2006 KTM 560 SMR - 2006 Yamaha R6
    LRRS Rookie of the Year 2002-2006
    99.99% of all shifting and falce neutral problems can be solved with (not in any special order)
    1> more positive shifting techniquue
    2> clean and lube shift linkage (take apart if necessary)
    3> shift linkage adjustment
    4> clutch adjustment ( the real clutch adjustment, not just fiddling with the cables)
    5> chain tension (too tight a chain will bind transmission, and wear countershaft bearings)
    6> OIL..... most bikes share oil in transmission , clutch & engine, dirty oil will affect shifting
    Member Ri_De_bike's Avatar
    Jun 2005
    Road Island <lol>
    add to randys list
    your idle is too high.
    Apr 2004
    boston burbs....
    you're related to firefly i bet...
    hmmmm......
    IWOK Prez. bigred875's Avatar
    Manvile, RI
    Quote Originally Posted by naked-daytrader View Post
    It wasn't done intentionaly. It just happend. So it got my attention.
    Bruce O.
    03 600rr.
    Lifer JohnnyV's Avatar
    Westborough, MA
    I've found that shifting from neutral to first while standing still is not going to be as smooth as shifting while riding, no matter what bike you're on.
    With clutch lever 'in', blip the trottle a touch WHILE you shift into 1st. It'll go in smoother than your.......well, you know...
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Also if the oil is thick then things are spining or has pressure through fluid friction.
    If the clutch throw out rod is adjustable ..do it
    Glen Beck is John the Baptist
    Lifer Currently's Avatar
    Ooltewah, TN
    Speaking of OCD .... where the hell is he?
    Haven't heard from him in a while.
    Walpole
    +1
    2018 Harley Road Glide
    2000 Ducati 900ss
    2003 Harley Softail Deuce
    Quote Originally Posted by Currently View Post
    hes still cleaning off that nail polish
    May 2007
    Peabody
    Quote Originally Posted by Mindgame View Post
    Same here. I usually go from neutral to 1st after lifting my foot off the ground, so I use my whole foot to kick it in. One time I was in neutral with my foot on the peg, and my other foot on the ground, so I rotated my foot forwards and it wasn't quick enough.
    nanu nanu
    May 2007
    Keene
    I used to have the same problem. I found if I just let the clutch out a tiny bit in neutral, just to rotate the internals a smidge, it'll shift right into 1st.
    I think I might try the little throttle blip. Sounds like a similar function. Save wear and tear on the clutch cable if it works.
  1. From "Sunuvabitch" to "Hell yes" to "WOOT!"
    Last Post: 05-16-12, 06:46 PM
  2. Someone just said "fine art" and "straight line" in the same sentence!!
    By butcher bergs in forum General Bike Related
    Last Post: 03-02-09, 03:17 PM
  3. Question about "Product Updates" aka Recalls
    By VinceF2 in forum General Bike Related
    Last Post: 05-03-04, 12:47 PM
