Results 1 to 3 of 3
Brake questions
    Old School Fool. ZX11D's Avatar
    Jan 2009
    Wilmington MA
    Brake questions
    I feel like i`m rebuilding the Zx one part at a time. Went out for a rip and just as I`m pulling in for gas I noticed a grinding noise. I had just passed a road construction area and figured I picked up some stone or other. Checked the front rotors and sure enough I had a nice grove from something. Took the bike home after some more looking around and without using the front brake. Dropped the calipers down and cleaned them out with some brake cleaner. Pads were replaced this season and looked pretty good. While the bike was up I spun the front wheel and it seemed to rub the pads in one area more so I checked the rotors and I can move them around slightly by hand.There is also some small measured variations between the two rotors in various points. I`m thinking the rotors are warped and moving around a bit although I don`t feel it in the brake lever. Don`t know anything about floating rotors but I`m thinking EBC HH sintered pads with new EBC PRO Light rotors will make me feel safe again. Anybody had anything like this happen and what was the outcome?
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Re: Brake questions
    Rotors move if they float but should not just rattle around loose like
    If its just a single groove, just ride the bit*ch
    See if the lever pressure is much more than you remember
    Glen Beck is John the Baptist
    Jan 2009
    Wilmington MA
    Re: Brake questions
    I`m gonna ride to work tomorrow am. Right now things seem fine except when I`m almost to a complete stop. Then I get funny creaking noises and sometimes a scraping noise. I have new pads but dont want to use them on bad rotors. My problem is I really don`t know how to tell if the rotors are warped . i thought measuring the distance between rotors was a start. I read somewhere in a zx forum that the rotors have a tendency to warp around 30,00 miles so . No fade if they were on a car I was working on I would definitely turn them down a bit on the lathe. Back brakes are fine and look about the same. I wish I knew more about bikes in general. This sucks. I ride fairly spirited most of the time but don`t ever remeber these brakes even fading much.
  1. brake questions
    By feralchimp in forum Bike Maintenance
    Last Post: 04-22-16, 11:25 AM
  2. SV chain/sprocket and brake pad questions
    By Petorius in forum Bike Maintenance
    Last Post: 05-25-15, 12:11 PM
  3. Replies: 0
    Last Post: 02-27-12, 10:34 AM
  4. Front brake lever microswitch + brake bleeding
    Last Post: 05-05-11, 07:52 AM
  5. Tire and brake questions
    By Fitz in forum Pit Area
    Last Post: 11-19-09, 10:54 PM
