Results 1 to 13 of 13
broken swingarm on my vstrom
    25 miles away from home in downtown Dover NH, my brakes said "CLUNK" I was heading to Red's Shoe Barn to buy a new pair of boots, coming to a stop at the end of New York Street at Broadway right across from Red's
    in Reds' sparking lot, I inspected the area of my rear caliper, didn't look right the caliper had rotated, memories of the drag link on my SV650 several years ago ensued when my caliper flew thru my wheel and made a 6" gash. Thankfully better design on the Vee, it appeared that scenario is unlikely
    I bought my boots and proceeded home without using any rear brake, easier said than done, a thundershower broke out and rained buckets, visibility so that cars were stopping and pulling over, those that keep going had wipers on super high speed.
    halfway home, I stopped at my son's house in Rochester and waited for the rain to let up
    after an hour or so, it had let up, now dark I continued home. Ack! started raining hard again, about half way, as I am accelerating out of a corner I spot a deer out of the corner of my eye closer to the other side of the road, decides to continue to cross in front of me, plenty of time I say, but as my headlamp comes out of the lean and the bike is more upright, not 1, not 1, but 3 deer, a doe and 2 spotted fawns taking there time then the third one stops, as a matter of habit in emergency braking, the rear brake went clunk again
    seems as though I have sheared the brake caliper stop off the swingarm
    new swingarm is over $1k, luckily there are several on ebay for under $100
    Re: broken swingarm on my vstrom
    REAR BRAKE IS DANGERISS!
    All is good, I freaked out, in rain in dark, I was feeling wrong place on the swingarm for the tang, the detent slot on the caliper mount was out of place, probably for the last year when I last had tires changed
    Is the tab for the carrier gone, or is somebody just a goon and assembled it wrong??
    the tab is there, last night in the dark, I though it was gone, I think it was gooned a year ago (last time wheel was off), never noticed it cause the caliper never walked backward till yesterday
    bearings and axle was tight, spacers were in correctly
    dealer fixed it this morning
    Was gonna say... I don't think I've ever heard of that caliper tab shearing off. Coming off of it, on the other hand...
    I haven't either, but it wouldn't be the first unique thing that has happened to my Vee due to salt corrosion, I have also had ethanol corrosion downstream from my fuel tank overflow
    Lifer jwm2k3's Avatar
    Mar 2004
    Lynn, MA
    How many miles on the strom, Randy?
    only 80,500
    I'm slacking, average just 9k/yr my SV had 125k in the first 4 years
    Mar 2004
    Lynn, MA
    only 80,500
    C'Mon man, let's see that map of the US you've got in your signature get filled in.....
    How many miles on the SV when you got rid of it?
    I still have my SV,
    135,006 wanna buy it ? frame w clean title, tank no dents no dings, extra set of wheels, motor out and ready to rebuild
    Permanent N00b -Dutch-'s Avatar
    Feb 2014
    Pawtucket, RI
    That is legit the number one item one my bucket list. What site is the map from?
    Quote Originally Posted by -Dutch- View Post
    http://www.visitedstatesmap.com/
    http://www.visitedstatesmap.com/view-provinces-map.php
    https://www.gasfoodnolodging.com/vis...tes/us-canada/
    MapLoco! - Web Visitor Map - Visited States Map
    I should pick up 8 more states that I don't have when I attempt an IBA 50CC ride, or I may go for the 48 in 10 or 49 in 10 ride
    so far the only Canadian province I have been in on my bike is Quebec, so I haven't bothered making a Canadian map yet
  1. Vstrom OEM Side Bag
    Last Post: 04-24-11, 04:33 AM
  2. VSTROM UP
    Last Post: 03-26-10, 10:59 AM
  3. Vstrom 1K 04 to 07
    By richw in forum Wanted
    Last Post: 02-28-10, 11:56 PM
  4. VStrom dirtbike!
    By Karaya One in forum Dirty Bastards
    Last Post: 05-07-07, 09:23 AM
  5. TLS/TLR/SV1k/Vstrom 1k owners
    Last Post: 12-16-06, 11:20 PM
