Results 1 to 25 of 32
Before I start spending my daughter's college money....
    Littering and........
    Jul 2004
    Vermont
    Does anyone know where I can buy a kit to convert a Suzuki DRZ400SM to the off-road carb cheaper than this?
    Fallon thanks you.
    Nov 2004
    Boston, MA
    I wouldn't mess around with this mod. If you are going to do it, go with the TT kit and get it set up right the first time.
    However, if you want to hold off on the new carb then go with a full RS-3 or ti system and the correct jetting as well as the airbox mod and see where you are. Its a pretty good bang for the money, although Im sure the fcr is as well.
    EVERYTHING is a repost
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
    Jul 2004
    Vermont
    I've thought of trying to piece it together from e-bay stuff, but by the time I'm done, I'm not sure how much cheaper it would be.
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    Im going to fix my carb,
    lean POS takes three days to warm up.
    www.bostonmoto.com
    Forum Rules
    May 2002
    Meriden CT
    Put all this shit in your carb
    This kit includes:
    - 016-925 Keihin 39mm FCR Carb with choke (no TPS)
    - 021-216 FCR Adapter 2 3/8", carb to S airboot
    - 021-439 Adaptor O-Ring
    - 017-262 EMN Needle
    - 021-012 Airboot adapter bolts (2)
    - P/N 13111-29F00 OEM Suzuki E Intake Manifold
    - P/N 09402-58208 OEM Suzuki Clamp
    - P/N 13685-29F00 OEM Suzuki Vacuum Port Nipple
    Carb comes standard with the following:
    - 200 Main Air Jet
    - 160 Main Jet
    - 45 Pilot Jet
    - 100 Pliot Air Jet
    - EMR or EMS Needle
    except choke
    www.bostonmoto.com
    Forum Rules
    KB KB's Avatar
    Manchester NH
    Chris I told you what you need to do cheaper than all that shit.
    Listen fool.
    Beet is on the right path dood.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    I've used a "cobalt" jet kit on a couple bikes I've had and had the best results with them. And they're cheap too, I think a bit...eeer jet is less than 2 bux
    Nov 2004
    Boston, MA
    What have you done to it so far?
    Do you know what your current jet sizes/needle/clip positions are?
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
    Jul 2004
    Vermont
    Listen fool.
    Didn't you tell me to trade it in for a Honda?
    I can't very well put an FCR 39 carb *in* my current carb....I dont get it.
    Jul 2004
    Vermont
    It has a stage one jet kit (I dont know what manufacturer) and a K&N air filter. This didn't do very much, I'd recommend skipping it if you are thinking of doing some work to yours.
    The chronology works like this:
    1. Bought bike and ride it for a while - ran fine but slow.
    2. Had mechanic install jet kit before a track day.
    3. Let bike sit for about three weeks; bike suddenly ran like crap.
    4. brought bike back to said mechanic; the bike now runs ok, but backfires and seems to run out of fuel at weird times. Runs good enough to ride around, but cuts out an inopportune moments.
    I knew these bikes came with crappy carbs, and I figured I would have to spend about $1000 on a carb and a pipe to make it have decent power; I just haven't gotten around to doing it yet. And I am planning on running this bike at VIR in April, so I want to get things sorted out before then.
    KB KB's Avatar
    Manchester NH
    We can make your carb work well for your bike. The crappy carb saying is a cop out for guys that don't want to spend the time to tune the bike.
    You need to
    Find a DRZ forum and tell me where it is so I can check out some "other" peoples results.
    1 Pull the carb
    2 Pull all the hets
    3 Write down the jet sizes
    4 Go buy all the stock jets
    5 Call me and say you did
    6 I'll come for a ride
    7 Install stock jets
    8 Let me take it for a spin
    9 We go buy new jets
    10 Pull carb again
    11 Install new jets
    12 Test ride
    13 Re Jet
    Viola!
    LRRS/CCS EX #13
    GMD COMPUTRACK
    KB KB's Avatar
    Manchester NH
    Yeah really. I have been told that a Motard wouldn't be fun. Have I been misled? I wouldn't mind VIR.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Dec 2003
    Ma
    Martard at VIR = BLAH
    I will however rent both of my 6 double R's if I still have both when it rolls around.
    VIR is a fast track but I will guarantee you, you will have just as much, if not more fun on your Motard than you will on a sportbike. I had a grin from ear to ear when I was running my YZ450 down there
    Just keep in mind on the front straight, you'll be wide open at pit in..with another half mile of track (maybe more? ) to go before you let off so the sportbikes are going by pretty fast.
    I had the best time ever, of any trackday or race weekend while at VIR on the Motard, it was awesome!!
    Nov 2004
    Boston, MA
    If you really want to make the bike run well do the following. Ive done a bunch of stuff (including everyhting on this list) to mine over the last 6 weeks and I think I will be very happy with the results.
    1. cut a 3x3 (exactly) size whole on the top of your airbox.
    2. replace the stock exhaust with a yosh rs3 or ti full system. Not a slip on, it does crap. The rs3 can be had on ebay for in the 3's, and new for 4 something.
    3. remove the spark arrestor
    4. make sure the kandn is in good shape and clean
    5. pull the carb out and clean it. then swap the main jet and pilot jet and possibly the needle and clip positions and maybe the spring. If you email me your elevation and the mods you plan to have Ill get you the settings for the carb you need from TT forum, or you can ask yourself over there.
    6. when jetting the carb replace the stock fuel screw with an adjustable one.
    I can get you all the part #s and stuff from the TT store. It shouldnt cost you more than 500 for everything, and you can still do the fcr later if you want.
    This is what everyone who has the bike and wants it to run well does. If you want the fcr, go for it, but be prepared to have to smooth out the gliches in the settings unless you feel confident you can sort through the TT threads on how to actually make it run well. Im sure the airbox mod is still required for the fcr carb.
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
    Oh have you?
    Nov 2004
    Boston, MA
    Originally posted by Degsy
    Oh have you?
    In a manner of speaking?
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
    LOL, Just bustin' on ya.
    Just Registered Doc's Avatar
    Jericho, VT
    Chris, If you want you can take my Ducati to VIR.
    Psych!!
    Chris, you can ride my Ducati at VIR.
    Jericho, VT
    and his F4i too!
    Originally posted by Doc
    and his F4i too!
    LOL
    Jul 2004
    Vermont
    Riding R7's YZ450 at VIR is what made me want a motard. For the 3-4 seconds you are bored on the front straight, the rest of the track is a blast.
    I'll go buy the stock jets and show up at your place with the bike in the back of my truck. I'll bring beer.
    Jul 2004
    Vermont
    Psych!!
    If I wanted to ride a cave-tool, I'd buy myself an Ascot. Oh, wait....
    Jericho, VT
    Cave tool? My Ducati? I mean Ya it is old but... I think you hurt it's feelings
