Results 1 to 23 of 23
Caswell coating in Boston area
    Lifer SwiftTone's Avatar
    Norwood, MA
    Ducati has approved gas tank replacement due to swelling on my SF1098S. I'd like to have it coated before it gets installed. The dealership has offered to do the coating themselves but I don't think they're experienced in doing the task.
    Who in the Boston area specialize in this?
    Re: Caswell coating in Boston area
    Literally you mix up some goop and put it in the tank, move it around so it coats everything. It ain't rocket science, just messy.
    CCS/LRRS #83
    Lifer NPDCPA's Avatar
    Mar 2011
    Robbie Nigl at Peachpit. THE BEST, hands down. Tell him Nick D sent ya.
    Norwood, MA
    Typically I prob would do it myself but I'm moving and time and space is limited now.
    Quote Originally Posted by NPDCPA View Post
    How much does he charge?
    Mar 2011
    Not sure. I had him do a few project parts for me and the overall total seemed reasonable so I don't have an itemized list. Give him a buzz and ask. He's super friendly and a straight shooter. Does your bike need a NEW look f
    Lifer Falko's Avatar
    MoonTown
    I did my last tank, it is messy and difficult to get good coverage. It goes in thick and dries quickly. Granted I had a fairly large tank but seemed to take forever to get it covered on everything.
    go faster cdovego's Avatar
    Weymouth
    Thanks for asking, reminds me I need to do the same with the S4 tank.
    Anyone know if an already lumpy tank can be shrunk back to nearly or like new? I don't care about aesthetics as much as I care about the upper triple tree not hitting the tank.
    Central Mass Powersports #123
    MoonTown
    Supposedly a tank left to dry for a few months will return to size.
    Lifer jwm2k3's Avatar
    Mar 2004
    Lynn, MA
    I agree with Falko, although Ive never experienced it, the Ducati boards are filled with guys whos tanks have returned to size after expansion, if they are removed and left dry for a while.
    Mar 2004
    Lynn, MA
    Oh, by the way. I solved this issue by buying an 1198S Corse with the alum tank
    Caswell coating in Boston area-132-jpg
    Branford CT
    My 848 has not had a problem. My sport classic has. Leave the gas cap open so it can vent when you are not riding.
    Weymouth
    Good stuff, I'll go open it now and I'll plan to pull it and empty it over the winter. Thank you!
    Sep 2007
    When I bought my used SF848 I was told by the dealer to fill to within an inch of the filler neck and not more. Will that take care of it or are there any other tricks I need to know for a tank that is not yet affected?
    Mar 2004
    Lynn, MA
    I believe its not just the pressure, but the ethanol in the fuel that affects the composite of the tank, weakening it and thus it expands.
    As always, I could be wrong. But thats how I understand the issue.
    The ethanol doesn't weaken the plastic, think of it more like a sponge taking on water, expanding as it fills. When it expands it distorts the shape, but when given time for the ethanol to migrate back out it returns back to it's original size and shape.
    Norwood, MA
    Pretty sure pressure is not what makes the tank to expand.
    Also, leaving it slightly empty will not prevent it from expanding. There is a guy from another forum who drains the tank after every ride and he still has this issue.
    MoonTown
    What I read on the subject is that the ethanol in the fuel facilitates the plastic to absorb water. The plastic used in the US machines is different than the plastic used in the Euro spec units. I think the US tanks are an ABS based resin, but not positive. We all know that ethanol attracts moisture, but once entrained that moisture permeates into the plastic causing it to swell. The ethanol somehow or other facilitates the absorption of the water. If they used a different resin to make the tanks, this would be a non-issue. But the USDOT or NTSB or some other .gov dictated the use of the resin at hand for safety sake. Swelling tanks is for the children it would seem.
    I do he same with my Aprilia. Since I only use it once or twice a month, I use a shaker to drain the tank and leave the cap off. No issues, even when it's parked for months in the off-season.
    Where did you hear that plastics are different? I find that incredibly hard to believe they make two types of tank for different markets. FAR more likely, is the Ethanol (that is only mandated here in the US) causes the problems on the same tanks that are fine elsewhere that only uses straight gasoline.
    Every single one of you gits should be calling your representatives telling them to repeal the E10 mandate.
    CCS/LRRS #83
    I solved my Italian tank swelling issue by selling it, and buying an R1..couldn't be happier
    Weymouth
    Perhaps but first tell me what a git is.
    CCS/LRRS #83
    Weymouth
    Pretty much sums me up, learned a new word today. I'll draft my letter now.
  1. Exhaust pipes ceramic coating shop in the Boston area?
    By xxaarraa in forum Bike Maintenance
    Last Post: 08-04-15, 09:44 AM
  2. Caswell Coating Ducati Plastic Tanks
    By NPDCPA in forum General Bike Related
    Last Post: 05-27-14, 05:38 AM
  3. Looking for powder coating in Brockton area
    By Big R 508 in forum Business & Product Reviews
    Last Post: 10-31-07, 03:00 PM
  4. Bike shops in the area(NH/Boston area)
    By Hittman in forum General Bike Related
    Last Post: 11-23-05, 09:08 PM
